930 BOV/Bypass Valve Question
I've been noticing a boost spike when I shift while on boost.
For example, If' I'm at .8Bar when I shift, when I let off the gas, the boost will spike for a split second to 1-1.1 Bar.
I'm running stock turbo w/ factory bypass/diverter valve (new seals) and my boost gauge is tapped into the wastegate input.
The tach boost gauge doesn't spike and I havent hit the boost cutoff switch.
Is this something I should be concerned about or is it normal?
Thanks!
Mike
1986 930 Turbo (Stock) 39k
Huntington Beach, CA
Old 07-08-2009, 03:14 PM
spike
Is your waste gate feed plumbed into the manifold or the intercooler ?
Mike
The two most useless things to a driver are the braking distance behind you and nine-tenths of a second ago.
Old 07-08-2009, 07:04 PM
Certified User
billjam's Avatar
If you shut the throttle while you've got the turbo working hard, the inertia of the turbo and the inertia of the air passing through it will cause pressure to increase in the intercooler in the short time interval that it takes for the BOV to open.
You can easily see this at each gear change on the log below.
I have since upped boost to 1 bar (with a manual boost controller) and changed my gauge connection to the manifold side of the throttle body, so I don't see this spike any more because I'm measuring on the downstream side of the throttle, but I'm sure it still exists on the upstream side. Physics!
Bill
1988 Carrera - 3.6 engine with ITBs, COPs, MS3X
2024 Macan S
Day job ... www.jesfab.com.au
Memories: '68 912, '72 911T, '80 911SC, '84 911, '85 930, '86 930, '87 911, '21 Macan S
Old 07-08-2009, 10:08 PM
Bill,
Thanks for the explanation!
Mike- The WG input line comes from the intercooler (stock)
Mike
Old 07-09-2009, 07:17 AM
spike
Thats what I thought, as Bill explained you will get better readings without the spike before the throttle, Just move it to the intake manifold, closer to the middle the better that way its not influenced by a single cylinder.
Mike Bruns
Old 07-09-2009, 08:36 AM
Mike,
I've tried the brake booster line but I may just run a dedicated line for the gauge..
In in other news, I'm pretty sure my A/C compressor kicked the bucket this week.. ACK!
Thanks for the input guys!
Old 07-09-2009, 05:44 PM
I am also experiencing this on my 930.
If I am not mistaken, this is called "compressor surge" and can be cured with a more responsive BOV, like a Synchronic valve (at least that is what they are aiming for). I have not tested them but thought I should report.
http://synapseengineering.com/cart/products/Synchronic_BOV_Weld_Steel_Silver_Black-7-2.html
Mathieu
Old 07-10-2009, 08:31 AM
Interesting development.. I replaced the manual boost controller that runs inbetween the wastegate input and the wastegate vent with a 15PSI pressure regulator (vs. the original 60PSI regulator) and the compressor surge spike seems to have been reduced by about 75% (per the gauge).
Old 07-10-2009, 04:16 PM
A930Rocket's Avatar
Sounds like the new controller gives better control.
Old 07-10-2009, 07:10 PM
mark houghton's Avatar
Mike Bruns
That's where mine is hooked to...manifold side of the throttle body. Very little spike if at all. Note that the stock boost gauge sender is located dead-center in what I think is referred to as the secondary intake manifold (the one with the boost recirc valve incorporated into it).
Mark H. 1987 930, GP White, Wevo shifter, Borla exhaust, B&B intercooler, stock 3LDZ.
Old 07-10-2009, 07:51 PM
