930porsche
930 porsche's Avatar
Tach not responding
On my 1978 930, my tach quit a few months ago and my mechanic try troubleshooting and could not find the problem. He then hooked up a white wire with the BLK/Purple wire and worked fine since but I do not know what the white wire is for and also i rather find the problem and get the BLK/Purple working properly without depending on connecting other wire to it. What are the steps for me to do in order of getting this tach working again. I need education of where it is getting its power and how does it respond. A wiring diagram from the acual back of the tach connections to the ICU will be really helpful.
Old 08-03-2009, 06:54 AM
Was the white wire located in the engine bay or near the gauge? I don't recall seeing a white wire at either point.
Is the ignition unit stock (Bosch 6-pin) or aftermarket?
Jim
Old 08-03-2009, 09:31 AM
930porsche
In the engine bay.
Old 08-03-2009, 09:33 AM
930porsche
Stock 14 pin.
Old 08-03-2009, 09:40 AM
930porsche
Jimmcc I am sorry I was thinking of something else, the ICU is Bosch 6 pin.
Old 08-03-2009, 05:32 PM
930porsche
Tach not responding
I tested the tach wire at the back of it with the one at the harness connection to the ICU and no continuity. Where does the tach go from the ICU harness? Is it going by the side of the door then to the dashboard or where? Or is it better to run a new BLK/PUR wire from the harness to the tach?
Old 08-07-2009, 09:25 AM
930porsche
Tach no power
Could I run a new wire from the tach to the engine harness of the ICU?
Old 08-10-2009, 10:50 AM
A930Rocket's Avatar
Yes.
Old 08-10-2009, 01:04 PM
930porsche
Tach
Does anybody have the tach and speedometer back diagram that I could use to understand more about the connections?
Old 08-12-2009, 11:22 AM
930porsche
Tach
I have hooked up the coil to my digital tester and no reading on my tester. Could the car still be working and driving if I had a bad coil?
Old 08-12-2009, 11:25 AM
Happiest when Tinkering
gsmith660's Avatar
Looking at the wiring diagram the white wire from the bosch 6 pin is the coil trigger which is why it gives a tach signal. Where did he tap in to your blk/purp wire? from there to the tach is good. To answer your email the blk/pur wire goes from the ign. to the tach directly thru the harness in the tunnel so look for a break between the white wire the mech. hooked up and your ignition box if it is in the harness then you can run a new wire to the tach and the box.
" Porsche there is no substitute" I always liked that saying. Air cooled is the only way to go!
76 911 C.R.A.P. Gruppe #2 BIG time TURBO C.R.A.P. Bitz EFI/EDIS Now MegaSquirt 3
76 Blazer also restored by me
Old 08-14-2009, 05:33 AM
gsmith660's Avatar
You can use the sc ele. dia. on pelican it is similar to what you should have.
Old 08-14-2009, 05:35 AM
gsmith660's Avatar
It goes thru the 14 pin so I would start there.
Old 08-14-2009, 05:38 AM
gsmith660's Avatar
I had to do that with the switched power to the ignition its not as clean but works fine.
Old 08-14-2009, 06:10 AM
930porsche
Tach Problem
Do you have a diagram of the back of the tach and also the speedometer?
On the coil is the A the positive side and - negative? If I run a white wire from the Bosch 6 pin to the positive side of the coil, we will see what happen also I will check on the iginition side there should be a BLK/PUR wire correct?
Old 08-14-2009, 06:17 AM
gsmith660's Avatar
http://www.pelicanparts.com/911/911_Parts/Electrical/911_electrical_82SC_Part1-2.jpg
Look at this.
Old 08-14-2009, 06:19 AM
930porsche
Tach Problem
Thank you. This is a great schematic. I could try to work out of that. I let you know.
Old 08-14-2009, 06:38 AM
A930Rocket's Avatar
You could check continuity with an ohmmeter for the black/violet wire. If it fails, you could run new wire temporarily to determine which wire is not working and then install it permanently.
Old 08-14-2009, 08:50 AM
930porsche
I think I understand. BLK/PUR wire goes from the 14 pin to the Bosch 6 pin then to the iginition then to the tack?
Old 08-17-2009, 05:09 AM
A fellow Pelacanite
NathanUK's Avatar
Hope these might help
Here are some pics and resistances
At the CDI connector with it unplugged
Coax to dizzy (green cable) is 570 inner to outer wire.
Brown to White (coil primary) is .7
Coil secondary (coil HT to either + or -) is 649
At the CDI box
31/1 to 31d is 0 (closed circuit)
31d to 15 is 672
31d to TD will charge briefly and then go to infinity (open circuit)
31/1 to TD also charges briefly and then goes to infinity (open circuit)
My CDI is a 930.602.702.00
Bosch number 0 227 300 004
1981 UK 930. G50/01 shortened, 964 3.8RS Fibreglass Body Kit, 18" Alloys 8.5" F & 10" R, 225's F & 285's R, Special Colour Metallic Blue Paint, FIA Sparco Evo's, A/C and Air Pump removed, Electronic Boost Controller, GHL Headers, Tial46 WG.
Fitting - New service kit.
Needs Fitting - Innovate XD-16 Kit, Kokeln IC. Stephen's K27 HFS, EVO Intake Assy & his Modded USA Fuel Head.
1983 UK 911 3.2 Carrera Sport Coupe. Black, Black Leather with Red Piping, Black Alloy Gear Knob, K&N Air Filter Element, Turbo Tie rods.
Needs Fitting - K&N CO Sensor, Round A/F Dial Gauge, Factory Short Shift Kit.
http://www.danasoft.com/sig/Iamnotanumber.jpg
Old 08-19-2009, 09:54 AM
