sprbxr's Avatar
Send a message via Yahoo to sprbxr
Need source for Flame rings
Two flame rings on my race engine are broken and I need replacements. I am not the original owner/builder of this engine and I don't know where these were sourced. If you know of a good source please let me know ASAP. My heads and cylinders are already cut for my current set so the replacements need to be the same specs.
Justin
Old 10-24-2009, 09:14 AM
Canucks Fan
Whats a flame ring?
Old 10-24-2009, 10:47 AM
onboost's Avatar
I would try JB Racing in Fla or Ollies in CA.
You will have to supply them with percise measurements of maybe even send them the cylinders and have them spec & press them in. Oh, or sned them the broken rings for spec.
Paul
RGruppe #180
Old 10-24-2009, 11:54 AM
I am quite certain they're simply a metaphor for the ever deepening love Johnny Cash held for June Carter, even wrote a song about them if I'm not mistaken! Can be downloaded nowadays with little or no cost!
82 930 Pearl White 3.3 964 cams, K27 HF, Kokeln, fuel enriched, IA fuel head mod, wur mod, crankfire, 2X plug, Aase worked heads. 1bar, GHL, zork, 23/33 bars, low, loud
Old 10-24-2009, 11:57 AM
Infidel
JBL930's Avatar
It's most likely a Nirist type ring used, there is tons of info on Rennlist if you do a search for either head sealing or flame rings
Jonathan.
87 930, 993 turbo engine, RS Tuning 520PS/515lbf-ft, Arrow Rods, ARP hardware, Solid lifters, G50-50, RS Flywheel, 890nm Sachs clutch, RSR coil overs all round, 993 C4 calipers front, 930 fronts on the rear, Ruf Speedlines.....
Old 540 BMW, XB12S Modified, for being a total hooligan
Old 10-24-2009, 12:03 PM
I use rings in my race car on block side and head side holding 42 lbs boost and its only wire thats tapped into reciever groove nothing special any machine shop should have it and its cut to fit
Old 10-24-2009, 02:19 PM
Wo ist die Rennstrecke?
DonE's Avatar
JB Racing did mine, but like most all shops, you'll need to provide your heads and cylinders so they can match your existing cut-outs or cut new ones. In any event, choose a shop that has done them with success - it's a very precise part and you cannot afford to experiment (material used, affects on squish, cutting into your heads and cylinders to name a few).
Old 10-24-2009, 05:22 PM
onboost's Avatar
Very well said Don!
RGruppe #180
Old 10-26-2009, 08:14 AM
930gt-40r's Avatar
I would use Verdan tool in Jersey- thats who I have always used with success. Im sure that JB would do just fine as they do stellar work, I am just throwing out another suggestion...
Kris @ Tech9
86' 930/GT-40R Sold
94' Rustang GT daily (long gone)
2008 C6/Z51 Corvette
Old 10-26-2009, 08:21 AM
JB racing did mine. Ask for Mike he will take care of you. I used Verdan for my crankshaft repair, and had it repaired again by JB racing Car running good Kris?
Old 10-28-2009, 06:01 PM
930gt-40r's Avatar
Runs like a top
Kris @ Tech9
86' 930/GT-40R Sold
Old 10-28-2009, 06:37 PM
sprbxr's Avatar
Just found out Verden previously did the mod on my heads. I am going to send them back to them since they have the original specs.
More bad news though: Magnafluxed my crank and it is cracked. More money I wasn't planning on spending.
Justin
Old 10-28-2009, 07:11 PM
DonE's Avatar
Wow, but what a good catch. Imagine the cost if you didn't....
Old 10-29-2009, 05:30 PM
sprbxr's Avatar
Yep. It was the best $38.50 I have spent in a long time even though the results were less than exciting. LOL
Justin
Old 10-29-2009, 06:26 PM
