what is the % power drivetrain loss...
Hi got a type of gtech for my Iphone and it need to know the power drivetrain loss in % anyone know?
Thnaks |
I've always used 15% on a Dyno.
i had a mustang dyno back in the 90s and i saw 18-20 %
Why is there always such a high percentage of drive train loss quoted for a Porsche when the engine is almost attached to the wheels themselves? I would figure this kind of percentage loss for a front engine car where the drive shaft travels way back to the rear end and then to the wheels.
I believe 12-15% depending on the weight of the rear wheels and the weight of the clutch... but as a rule of thumb we usually use 15%.
Thanks all
I saw 16% on my car - so, as a rough rule of thumb, when I see a RWHP figure, I divide by 0.84
I can't remember, but are the Porsche quoted HP figures for RWHP or flywheel HP? I think my '87 is rated at 282 bone-stock in the book.
Mark H. 1987 930, GP White, Wevo shifter, Borla exhaust, B&B intercooler, stock 3LDZ. |
Anyone else have feedback on drivetrain loss estimates?
Scottsdale Arizona USA
13-15% for most 2wd wheel dynos.
Day @ Euro Parts West, LLC, Scottsdale, AZ USA // Automotive Part Connectors & EPW MODE : Motorsport Design +1 (844) URO-PART // modepw@europartswest.com |
Smart quod bastardus
Anyone know what to expect from a typical Dynapak dyno that bolts right to the hub? It should be lower than a wheel dyno.
Is there a way to calulate the loss on the dyno by running the car up and then putting it in neutral and measuring as it runs down? Never having run a dyno this seems logical to me.
1979 930 Turbo....3.4L, 7.5to1 comp, SC cams, full bay intercooler, Rarlyl8 headers, Garret GTX turbo, 36mm ported intakes, Innovate Auxbox/LM-1, custom Manually Adjustable wastegate housing (0.8-1.1bar),--running 0.95 bar max ---"When you're racing it's life! Anything else either before or after, is just waiting" |
