Time to consider a new engine?
Spent the past 2 years rebuilding my 3.0 turbo engine, only to see major failure after only 800 miles, starting with light tapping from left cylinder bank soon followed by complete failure. It felt as if there was a firing issue followed by oil dripping then a loud tapping from centre of engine, Will spend tommorow investigating problem any thoughts would be appreciated, I have posted video on youtube.
YouTube - 102_2796.MOV
Old 04-17-2010, 01:20 PM
Canucks Fan
Thats a bummer, let us know what happened, sure sounds ugly
Old 04-17-2010, 02:05 PM
Sounds and looks like one or more of your rocker shafts on the left side have moved out of their bores in the cam tower.. among other possible things
If you used certain aftermarket rocker arms that are less than half the price of OEM thats a given.. because they are about .0001" too narrow in diameter and won't expand enough to lock into the cam tower bores.
Then the ends will eventually crack making another slower oil leak when tightened more to try and lock them in place.
Old 04-17-2010, 03:22 PM
Ouch, Sounds like the cam box spray bar is plugged up.
Cole
Cole - 80 930 "The Old Sled"
Mods: TurboKraft Custom IC, 934 Headers, GSX 61, Zork, Port Work, SC Cams, Air Mod Fuel Dist Relocated, Water Meth Injection, BL WUR, MSD 6530, Greddy EBC, Synapse Bov, Short 2nd & 3rd with 8:37 R&P, Wevo Shifter, Coupling, and Mounts, MTX-L SSI-4, Big Brakes, Rebel Coilovers, Bilstein Sports.
Old 04-17-2010, 07:22 PM
Wo ist die Rennstrecke?
DonE's Avatar
Let us know what happened. Knowing failures is as important as knowing successes.
Old 04-17-2010, 07:23 PM
