cam broke during install
How is this even possible? I was not even near the 110 ft lbs while tightening the nut and then it started getting loose again and then...
Wow!!!
Is it a stock cam?
2014 Cayman S (track rat w/GT4 suspension) 1979 930 (475 rwhp at 0.95 bar) |
Infidel
Sorry to see that, i guess one bonus is that it didn't happen with the engine running!
Jonathan. 87 930, 993 turbo engine, RS Tuning 520PS/515lbf-ft, Arrow Rods, ARP hardware, Solid lifters, G50-50, RS Flywheel, 890nm Sachs clutch, RSR coil overs all round, 993 C4 calipers front, 930 fronts on the rear, Ruf Speedlines..... Old 540 BMW, XB12S Modified, for being a total hooligan ![]() |
SAIGON 68
my 2 year old grandson broke my wifes' bowling ball.
It was an SC profile from web cams. It was in the engine for years and then I sent it to web cams to get reconditioned and I was installing it again. They said they have never heard of this happening.
I had the torque wrench set for 110 but I am guessing I had about 75 on it at the time it broke. Yeah I guess it is better it broke now instead of later. So I will be getting a new SC cam from them. I will need to pay the core charge since I don't have a good cam to send them now. Does anyone have a SC cam good or bad I can send them for a core? |
That's scary! I'd think about replacing both of them to be safe.
Navin Johnson
Send both cams out and have them machined for the later style bolt?
Don't feed the trolls. Don't quote the trolls ![]() http://www.southshoreperformanceny.com '69 911 GT-5 '75 914 GT-3 and others |
It's possible it was overtightened by someone before you got the car and was tweaked.. and then let go on you.
Looks like black sand on the inside.. |
Wo ist die Rennstrecke?
Wow - I wouldn't do anything with those. Looks like new cams for you. Thank your lucky stars that happened now and not on the street. Think thousands of $$ repair....
yep, im slow in the head
wow thats nuts, i work on a lot of vw's and have seen 2 different guys snap cams in built VR6 motors but never any other car. sucks but good thing to happen before u started the motor.
1978 911sc Targa - CNC plasma/router cut parts, tig welding, sheet metal work, VAG-COM, LM-1. let me know if u need something |
Drive it like u stole it.
First time I have heard of one breaking like that. I had the old style but changed to the later style with my current build. The later style has some challenges to getting the cams timed with a high lift cam though. Here is the thread on the topic
____________________________ Bill Jones Jupiter, FL 77 Euro 911 3.0 Wide Body - under construction http://www.flickr.com/photos/rennsport/collections/72157618856489537/ |
Navin Johnson
I actually had a cam break in the same fashion, was not too concerned regarding machining to the later style. Those cams ( the ones with modified nose) are still in use, and I'm not losing sleep over them
Figured after numerous installs and uncertain history of the cam a break from the root of the thread might possibly happen... Timing the cams is always a sort of zen like experience..... I'm posting from Huangshan, China so I figured I could say something like that ![]()
