DWUR Fitted but doesn't start
Hello,
Fitted my DWUR UTCIS-PT from Unwired but the car doesn't start. It started the first time I turn the key but for only three seconds or so. I discovered a fuel leaking fitting on the Dwur body and fixed it. The car is a '92 3.3 964T. I went for the Dwur because the original WUR died. Any ideas? Thanks in advance. |
an idea. . .
![]() 0 438 140 160 965-606-105-00 Porsche 911 3.3 Turbo 12/90 to 8/92. 964 also in data base. 30.69 engine both US & Euro. Exchange $369.95 Porsche Parts-Special T auto.com,Porsche CIS fuel injection parts, fuel distributors, warm up regulators- bottm of page. |
when I have these ran for a second and then no start problems I usually start diagnosis by removing the air cleaner and depressing the air meter plate and turning the engine over. If nothing else you should be able to hear the fuel pumps running. This will get fuel flowing through the system. Does the dwur arrive set up for your application or is it set up for stock? And grounds grounds grounds!
82 930 Pearl White 3.3 964 cams, K27 HF, Kokeln, fuel enriched, IA fuel head mod, wur mod, crankfire, 2X plug, Aase worked heads. 1bar, GHL, zork, 23/33 bars, low, loud Last edited by slyguy; 09-12-2010 at 12:38 PM.. |
What does "grounds" mean? Electric ground¿? Last edited by DA VINCI; 09-12-2010 at 12:51 PM.. |
Tinkering Pays!!
That's exactly what I did... You're just 9-mos behind me...
LIVN80S - - Red '79 Porsche 930 Steel Slant Nose Conversion [in 1987] w. 46k miles 3.3L; 964 Cams; K27HF @ 1.0 BAR, with Garrettson Intercooler; Rarly Zork; CIS Flowtech Fuel Head & BL-WUR. |
Yes, electrical grounds. The dwur is powered, good clean grounds can make the difference between operating and not.
82 930 Pearl White 3.3 964 cams, K27 HF, Kokeln, fuel enriched, IA fuel head mod, wur mod, crankfire, 2X plug, Aase worked heads. 1bar, GHL, zork, 23/33 bars, low, loud |
I positioned the black box on top of the air filter box. I got the ground from an standard porsche ground spot (two wires are connected to it) on the right side of the engine bay, just next to the oil dip stick. So I suposse this is not a problem...
Make sure you have good power at the "switched power" lead. I think you can basically just use the power that went to the regular WUR. Not sure how the new versions are wired (I've had 3 and each had some changes in the wiring), but you also need a good tach signal, I believe, so make sure that is solid. Aside from that you just need a ground or two.
Have you checked to make sure all the various 930 relays are OK? Taking off the intercooler to set up the WUR, you could have nudged the connection to the boost shut off sensor, etc. I have had simialr symptoms (fire/no start) due to the yellow relay in the rear fender being bad and/or the boost sensor being diconnected. Also, check your fuel pump relays.
Emery 1988 930 coupe - Silver Metallic TurboKraft 3.3L 8:1 CR, SuperSC Cams, GT35R, B&B Headers, TK intercooler, Tial WG, ARP, tecGT based phased sequential EFI & ignition, Wevo shifter/coupler, ...
Ok, thanks.
I'm goint to verify all that things. It's interesting this info for the people fitting this device. You can learn a lot about the car. I'm in contact with UT as well. |
