tops911's Avatar
headers or intercooler???
So I'm thinking what should be the next bolt on mod? I'm thinking ether Rarlyl8 headers with heat or a Turbokraft intercooler, the price is sorta the same. What would the brain trust here choose first? I'm currently in Germany but will be moving to Ft Bliss (El Paso TX) this summer, would location change what you'd do first (intercooler over headers)?
Thanks for your opinions, Frank
1982 930, K-27, BL adj. WUR, Rarlyl8 Headers and Hooligan muffler, PK CDI, 22 and 30mm torsion bars, poly bronze bushings 30mm raised spindles and custom valved Bilstein shocks (by Elephant Racing), monoballs front and rear (by Rennline), Alton 17" Fuchs, Fred Cook fuse panel
Old 02-27-2013, 03:45 AM
Crotchety Old Bastard
RarlyL8's Avatar
El Paso TX? Do the IC first. I know sounds crazy coming from me but a hot environment dictates priorities in this case.
Old 02-27-2013, 04:33 AM
El Paso, I'd invest in A/C service 1st thing
Old 02-27-2013, 04:52 AM
tops911's Avatar
Rarlyl8 I was thinking intercooler first, but thought I'd see what others thought, thanks
Turbo owner, I'm all over the AC thing, that's what is preventing me from doing headers and intercooler at the same time. I'm sure I need more than an AC service, I'll be using some Griffiths stuff to get better AC.
Old 02-27-2013, 05:16 AM
Chain fence eating turbo
Wow, that does sound crazy from you. I was going to say headers first.
For a data point, I have a full bay IC and in the 100+ degree days here in San Antonio, I'd only see about 10 degrees above ambient increase in air temps after rowing through the gears.
It would only take about 1-2 minutes post boost for the air temps to get back to ambient.
Old 02-27-2013, 06:17 AM
xbmwguy's Avatar
+1 on intercooler
Old 02-27-2013, 08:09 AM
mark houghton's Avatar
+3 on intercooler
Mark H. 1987 930, GP White, Wevo shifter, Borla exhaust, B&B intercooler, stock 3LDZ.
Old 02-27-2013, 08:38 AM
klefroid's Avatar
you need IC and headers!!!
Old 02-27-2013, 09:18 AM
Sorry Brian, but why your headers? I am not looking to draw the ire of the faithful here but don't you do single wall tubes for your headers? I need to get some clarification on the benefit of your pieces v. that of B&B, Fabspeed and the holy grail Holcombe.
Lincoln Phillip
87 930 Motec EFI M600 G50/50 TurboKrafted Hell Hound.
Jeep, Chrysler, Dodge, Ram, SRT & AEV Dealer pm me for your Mopar needs.
"the 930 is THE CAR that started my PORSCHE love affair..." Magnus Walker
Old 02-27-2013, 10:01 AM
M5guy's Avatar
IC. it's easier work and there are no studs to break off. ��
SR
86 930
x: 62 356, 64 356, 76 930, 84 911 Targa, 85 ROW 911, 00 996, 07 Cayman S, 00 M5, 02 G500, 66 Shelby GT350 (x2), 64 Corvette.
Old 02-27-2013, 10:25 AM
RarlyL8's Avatar
I voted IC because the fellow is going to Texas. If you don't track the car it probably doesn't matter much but heat soak is no fun on a hot day.
We've done dual walled headers and are glad to if someone wants to pay the price. Most don't. Can't compare tuned headers to generic short tube, whole different deal.
Old 02-27-2013, 06:13 PM
I've gone native
Tt surgeon's Avatar
Agree with brian, heat isn't going to be fun, I'd go IC first.
Even my big Andial IC soaks on a hot day.
Re the headers, I'd love to see an indep dyno same day, same car, btb BB vs fs vs rarlyl8. If there is a difference, my bet is its minimal and not noticeable/relevant on a pure street car, jmo, no flames please.
Remember, the 935 race cars used short tube headers fwiw, can't be all bad, and there is some history of success.
When I shopped headers, I looked at all the ones mentioned, went w fs bc I have a history w them, got a nice deal, needed heat big time.
Off my soapbox.
C
Old 02-27-2013, 06:45 PM
This!
Been there and done that..do not want to ever go down this road again.
Old 02-28-2013, 03:40 AM
RarlyL8's Avatar
Broken studs are an issue. If you have rusty studs one option is to take the car to your mechanic and have him break them free and replace any that snap. Drive the car home and you'll have the new system on in no time.
Dyno work comparing mine to short tube was done long ago. Building short tube elephant nose 304 headers is easy and cheap, which is why everybody does it. Mine addressed all the issues of the short tube design. I wouldn't bother with such a complex system if it were not a huge benefit. If I needed awesome heat I'd stay with stock exchangers. Nothing can compete with the real estate inside those huge exchangers.
Old 02-28-2013, 04:02 AM
tops911's Avatar
Thanks for all the comments. I was pretty sure the intercooler first would be the way to go. I have to pace my modifications or I could have issues with my wife ;o) I don't think headers and an intercooler at the sametime is doable. I've put a set of SSIs on the SC I used to own so I'm well aware about the stud issue, I was lucky and had no problems (using a lot of heat and PB Blaster of course). I think the AC improvements will be an easy sell after her first ride there in El Paso.
Again thanks, Frank
Old 02-28-2013, 06:11 AM
TT Gasman's Avatar
I'll strongly endorse the B&B IC, easy bolt on and very efficient.
Old 02-28-2013, 10:08 AM
Allow me to confuse the issue; this is an Internet forum after all.
Granted TX is hot and AC will be an issue. Search under my name for a one and done AC update.
However, intercooler first on otherwise stock setup? No mention of track days or extended Silver State Mile bonsai boost blasts. lets face it, in about 12 seconds you are traveling at make-the-local-news speeds in these cars. Stock intercooler can keep up without costing power for a few of those.
Whereas headers of nearly any kind can free up HP and lower boost threshold in any scenario, something you will feel every time you drive it.
The inevitable larger turbo and higher boost waste gate you will install someday will lead you to an aftermarket intercooler in time. But before then... headers.
Ken
1986 930 2016 R1200RS
Old 02-28-2013, 10:42 AM
Richard930's Avatar
Without good AC, driving the car would be unbearably uncomfortable at any speed on a really hot day, and I think El Paso gets a few of those.
I'd upgrade the AC first, headers second, and then the IC. AC and headers will pay you back with smiles every time you get in the car.
Richard
1982 930, K27-7200, Ruf wheels, Leask WUR, Tial WG, RarlyL8 headers & single out muffler, SC cams, TK I/C
2018 GTi, 2020 AMG E53 wagon ski car
2004 BMW R1100S
Old 02-28-2013, 11:25 AM
R.I.P.
drmatera's Avatar
I disagree with most here. I think you are better off with headers and a good exhaust long before needing an intercooler. With better exhaust you will make more power at the same boost level you run now.
A new intercooler will only help when running more boost. The lower inlet temps will be negligent and since the CIS can't recognize the cooler air it can't add timing so no real power gain will be had...
Old 02-28-2013, 11:33 AM
1986 930's Avatar
Hey its a dry heat!
Don't forget that come winter, you WILL need heat in El Paso. Could be important when you do that header thing.
But hey, it is a dry cold too!!
Another mod you might want to look at for the desert is the front mounted oil cooler. I see a real difference in Florida and cooking your engine internals in heat is worse than a heat soaked IC in the long run.
Mark
1986 930 Ultra-Smith/RUF Slant Nose conversion, 3.4 BTR Spec, K-27HFS, RUF IC, TIAL .9 BAR Waste Gate, 930 4 speed transmission, RUF Front Oil Cooler, RarlyL8 Headers, RUF 4 Pipe Exhaust
Old 02-28-2013, 04:56 PM
