ornas's Avatar
Location: Vilnius Lithuania (it's in Europe and it's not Russia)
sketch of 3,2 intake adaptes to 3,3 engine needed
hi, maybe someone has sketches of adapters to fit 3,2 intake on 3,3 turbo engine?
Old 12-20-2010, 11:23 AM
A930Rocket's Avatar
Your English is better than my Lithanian!
I don't think you need adapters, but you do need the 3.2 spacers. See the "930 EFI Candy"thread. You can see the runner ending in a small spacer.
Old 12-20-2010, 01:51 PM
David's Avatar
The best thing to do is open the head intakes to 40.5mm. If you don't want to do that or don't want to pull the heads and option would be to make 3.2 spacers with a 4.5mm radius change from 41 to 32mm.
Old 12-20-2010, 02:35 PM
R.I.P.
drmatera's Avatar
we used 1/2" thick aluminum. Port matched the top to the carrera intake and the bottom to the 930 head port. Then ported the spacers to make the transition "funnel like". works great, i have no wierd dips in the power curve
Old 12-20-2010, 09:46 PM
David's Avatar
Since changing from 41 to 32mm over such a short distance would require a large angle which would cause a lot of turbulence, it seems like a radiused spacer like the picture below would flow better:
Old 12-21-2010, 07:42 AM
R.I.P.
drmatera's Avatar
David, I don't think the radius would be good. Seems like it would cause the air to tumble as it hit the radius
This is what we did
Old 12-21-2010, 08:33 AM
David's Avatar
A radius causes a stagnation point where the fluid (air) stops and then stays attached to the surface as it goes around the radius. A large angle acts as a ramp to launch the fluid out into the flow causing turbulence. Or at least that's what I remember from my Fluid Dynamics class.
Old 12-21-2010, 08:38 AM
R.I.P.
drmatera's Avatar
I'm no fluid dynamics expert, but i would like to see the results
Old 12-21-2010, 10:39 AM
TurboKraft's Avatar
A set that may help simplify things...
TurboKraft : Catalog Home : Carrera Intake Maifold Adapter Set [930 110 459 TK] - $274.00
Chris Carroll
TurboKraft, Inc.
Tel. 480.969.0911
email: info@turbokraft.com
http://www.facebook.com/TurboKraft - http://www.instagram.com/TurboKraft
Old 12-23-2010, 04:26 PM
Max Sluiter
Flieger's Avatar
This sounds right but I think it would be even better if you had a concave (to the air's point of view) curve transition into a convex curve.
Old 12-23-2010, 04:56 PM
Max Sluiter
Flieger's Avatar
Like this:
Old 12-23-2010, 04:57 PM
David's Avatar
Actually, at higher velocities even the concave to convex will cause turbulence. It's having the stagnation point that keeps the fluid in contact with the walls and not jetting out into the air flow.
Look up some flow measurement devices for some examples of low head loss designs.
Old 12-26-2010, 08:46 AM
9dreizig's Avatar
Send a message via AIM to 9dreizig
David is probably right on this one (quick ask him an electrical question,, that always confuses the mechanical guys ..
"Todd"
98 Tahoe ,2007 Saturn Vue
86 930 black and stock, 80 930 blue tracdog
91 Spec Miata (yeah I race a chick car)
"life"ll kill ya" Warren Zevon
Old 12-26-2010, 08:53 AM
Max Sluiter
Flieger's Avatar
Well, I am an ME student but I have not had Fluid Mechanics yet, just plenty of rigid body dynamics, materials stuff, and some other misc. physics courses. I would like to take some basic Aero stuff.
Old 12-26-2010, 11:23 AM
David's Avatar
D...that always confuses the mechanical guys ..
That's an understatement!
Old 12-27-2010, 01:13 PM
