Clunking noise driving me crazy cant find it
OK i thought it was the front wheel bearing which was loose and the inside one was scored a little bit, but that wasn't it. Then maybe bad CV joint jacked car up one side at a time and rotated and shook the rear wheels nothing, then crawled under( this with it jacked up on a screw jack since i am out of town). They are all very tight. Maybe the trans, was a little low on fluid. Topped it off. I am thinking possibly a rear wheel bearing? It is quiet for about the first couple miles then starts clunking and gets progressively louder. The clunks match wheel speed and are very loud and then occasionally just goes away. there also appears to be wheel vibration from the real associated with the clunking. Sound like a rear wheel bearing?
88 turbo Guards red Targa slant nose, and yes I am a horsepower junkie, 3.4liter,7.5 to 1 JE pistons, Adjustable WUR, Imagine fuel head, 1 bar waste gate headers,allthe cis toys. Now apart to become the next EFI monster. fabbing my own intake, headers Individual throttle bodies, MS-3, pauter rods, Xtreme twin plugged heads, gt-2 evo cams cop's. 2019 Silverado 6.2L |
emerg. brake pads
possibly a pin has become dislodged on you emerg. brake pads, and they are flopping around. This happened to me, and I also did the checklist your going through. good luck.
87 930 GHL/Rarlyl8/Garretson/GT3582R/1 Bar/Wevo shift, mounts/Meth inj/LM-2/Custom Fuchs/Carrera intake manifold/Xtreme Carrera heads P&P/3.4/DR 993SS cams/ Mahl/Pauter/JE/Niresist/ARP/twin COP/8.25:1/KEP stage 2/twin tials/close 2,3,4th. MS3Pro Evo 500+ HP, BTSOMP Dyno
sudo apt-get purge 930
Those were my symptoms exactly. Loud clunking and mild grinding that would randomly start and follow wheel speed then stop for a few miles only to start again. My rear driver side bearings bit the big one. The cage shredded in one spot and the rollers would work themselves out and start tumbling causing the grinding and clunking then would align themselves and be quiet again.
Mark 1979 930 Euro ***GONE AND DON'T MISS IT AT ALL*** "Worrying about depreciation on your car and keeping mileage down is like not ****ing your girlfriend so her next boyfriend finds her more appealing" --clutch-monkey |
check the all links bushings (sway bars, A-arms, shocks...).
It got a lot worse on the way from work tonight, Pretty sure it's the bearing. Bumming a ride tomorrow thankfully i only have a couple more days up here. I 'll have to find a trailer to get it back home.
I was out of town when mine went. The cheapest route I found was to rent a U-Haul and trailer because I didn't have a truck and trailer.
i have a truck but no trailer but a friend of mine has a racecar trailer in miami.
