j930's Avatar
speedometer is way off
I installed some new tires last month and they are a bit smaller than what was on there. while driving today I flipped on the GPS on my cell phone to check my speed as I thought I was about to be pulled over(I dod not get pulled over thankfully) and my speedo is off by 10 mph. how does one adjust that?
84 930 Slant
15 Sonata 2.0T
08 Ram 1500
15 Ram Eco Diesel
Old 02-06-2011, 08:44 PM
j930's Avatar
smaller in width but larger in height
84 930 Slant
15 Sonata 2.0T
08 Ram 1500
15 Ram Eco Diesel
Old 02-06-2011, 09:03 PM
The same deal with my old 911, a bit wider but less tall than stock. measured the circumference of each and found the shorter size was 10% smaller. So, if you are reading 60 on your speedo you are traveling at about 54, 70=63. 80=72, ect. Seems to work, never been tagged.
930 is different. If it feels like 50 MPH, your probably doing 75.
Old 02-07-2011, 05:30 AM
Infidel
JBL930's Avatar
The stock speedo on stock tires WAY over reads, mine was around 13% over. 100mph on speedo was actually 87mph on AX22 'and' satnav....
Jonathan.
87 930, 993 turbo engine, RS Tuning 520PS/515lbf-ft, Arrow Rods, ARP hardware, Solid lifters, G50-50, RS Flywheel, 890nm Sachs clutch, RSR coil overs all round, 993 C4 calipers front, 930 fronts on the rear, Ruf Speedlines.....
Old 540 BMW, XB12S Modified, for being a total hooligan
Old 02-07-2011, 07:40 AM
RichardE's Avatar
I agree Jonathon. My standard set up is way too optimistic by about 10mph at 70. Actually, come to think of it my 944 is a bit the same way but not as bad as the 930. Do these things come out of the factrory accurate and just go off over time? Weird.
89' 930 LE stock standard
90' 944 S2 also original
75' 914 2.0
Old 02-07-2011, 11:24 AM
Install a 8:41 R&P instead of the 9:36 and it will be off the other way. Seriously, I think there are company's that can recalibrate ( California speedo and others) or just get a different speedo face plate to adjust the difference. I noticed the speedo being way off on a 1978 930 I have, however on the 87-89 930's I have tested in the past, seemed to be right on. Seems like some same year cars are accurate and some not as I have a stock 77 930 and it is right so the age seems not to be a factor from my experience.
Anthony @ Voitureltd Bayside WI.
Old 02-07-2011, 12:03 PM
j930's Avatar
but the consensus is that the mileage is ok but the speedometer is off. I have not checked my odometer yet?
84 930 Slant
15 Sonata 2.0T
08 Ram 1500
15 Ram Eco Diesel
Old 02-07-2011, 06:36 PM
I had North Hollywood Speedometer recalibrate mine.
RGruppe #79 '73 Carrera RS spec 2.7 MFI
00 Saab 95 Aero wagon stick
01 Saab 95 Aero wagon auto
03 Boxster
90 Chevy PU Prerunner....1990
Old 02-07-2011, 07:36 PM
schmidlapp
My 84 euro spec 930 is right on the button.
Have 245 50 16's on the rear on BBS wheels.
Old 02-08-2011, 04:18 AM
lin7310948's Avatar
i put Livorsi gauges in my 930. the speedometer is a GPS. have not had it on the street but it is supposed to be very accurate.
69 bronco..... 91 mustang ssp santa clara county sheriff's office ...2017 focus rs tuned on 93 400 chp
Old 02-16-2011, 04:55 PM
Tinkering Pays!!
mooney265's Avatar
Neat...
Where's the boost gauge?
LIVN80S - - Red '79 Porsche 930 Steel Slant Nose Conversion [in 1987] w. 46k miles 3.3L; 964 Cams; K27HF @ 1.0 BAR, with Garrettson Intercooler; Rarly Zork; CIS Flowtech Fuel Head & BL-WUR.
Old 02-16-2011, 05:45 PM
lin7310948's Avatar
converting to a modified LS7...most of the info is fed directly to the gauges from the ECU.
Old 02-16-2011, 05:48 PM
Banned
Every Porsche I've driven seems to provide 'this' - I call it not MPH but Miles Per Porsche 8-).
Although, I've ran past a number of them speed signs on the roadside in mine and it was dead nuts accurate @ 35-40 - I think the issues start thereafter...
Old 02-18-2011, 05:37 AM
