02fly's Avatar
kokeln intercooler help
So I'm adding a Kokeln intercooler and it looks like there is no were to put the overboost switch do people just go with out one? Any help with this would be great. Thanks Don
Old 03-08-2011, 11:49 AM
Eh? Do you have a 930 Kokelyn? Pretty sure the pressure and overboost sensors just swap over: Kokeln intercooler
'77 S with '78 930 power and a few other things.
Old 03-08-2011, 12:13 PM
02fly's Avatar
Yes 930, but I can't see anywere to put overboost switch
Old 03-08-2011, 12:20 PM
oilonly's Avatar
I am installing a Kokeln also and it has a threaded area for both over boost switch and boost sensor. Can you drill and tap a fitting for it? Plus I have read here on this forum some people just ground the wire that went to the overboost switch. I am not recomending that.
'87, Modified WUR, Billet valve, 965 downpipe, Kokeln intercooler, GHL headers, Garrett T04B K27 hybrid, Tial w/.8 bar, WEGO IV, RarlyL8 dual out, LSD
Old 03-08-2011, 04:23 PM
02fly's Avatar
there is no place to put the over boost switch I think I'm going to try and adapt the place for the sensor since I don't use it anyway. Does everyone just plug off the lines from the BOV that goes to the manifold?
Old 03-09-2011, 09:57 AM
Does yours not look like the Kokelyn in the link I sent you? Mine has a place for both the overboost and boost sensors. And so does the other one I bought.
Old 03-09-2011, 03:48 PM
02fly's Avatar
everything looks the same but I don't have the one port to the far left
Old 03-09-2011, 04:15 PM
oilonly's Avatar
Here are some threads on that topic, I plan on using one for the decel valve and plugging the other one.
Kokeln intercooler
need a option for decel valve after BOV install.
Decel valve delete and idle
Installing B6 IC with removal of BOV
Old 03-09-2011, 04:21 PM
