panel's Avatar
Adding a fan to my intercooler
Has anyone added a fan to their intercooler? What would be the best way if wanted?
1)on top and blowing?
2)on top and sucking?
3) underneath and blowing?
4)underneath and sucking?
I just don't want to run out of air or disturb the air flow if you know what I mean.
2275T MS EFI '65 VW Panelvan http://www.vvwc.ca/minstone/
Old 03-24-2011, 06:39 AM
Panel !!!!
Take a look at the thread above: "Boost loss when hot"
Cole - 80 930 "The Old Sled"
Mods: TurboKraft Custom IC, 934 Headers, GSX 61, Zork, Port Work, SC Cams, Air Mod Fuel Dist Relocated, Water Meth Injection, BL WUR, MSD 6530, Greddy EBC, Synapse Bov, Short 2nd & 3rd with 8:37 R&P, Wevo Shifter, Coupling, and Mounts, MTX-L SSI-4, Big Brakes, Rebel Coilovers, Bilstein Sports.
Old 03-24-2011, 08:50 AM
Alan L's Avatar
If you are going to do it, the logical answer is on top, blowing - you have room to fit it there and the airflow is in right direction.
Alan
83 SC, 82 930 (track) - Stock except for RarlyL8 race headers, RarlyL8 Zork, K27-7006, 22/28 T bars, 007 Fuel head, short 3&4 gears, NGK AFR, Greddy EBC (on the slippery slope), Wevo engine mounts, ERP rear camber adjust and mono balls, Tarret front monoball camber adjust, Elgin cams, 38mm ported heads, 964 IC. 380rwhp @ 0.8bar Apart from above, bone stock:-)
Old 03-25-2011, 03:00 PM
sudo apt-get purge 930
equality72521's Avatar
Alan
Pull through is always more efficient. That's why refrigeration systems use pull through. Room, as you point out, is the issue though.
--clutch-monkey
Old 03-25-2011, 03:39 PM
David's Avatar
When the cars moving, my intake temps cool off pretty fast when I get off the boost so it seems like there's good air flow without a fan.
Old 03-25-2011, 03:40 PM
According to this thread Engine Fan Drive Ratio, the 3.2 fan moves 1500 litres/second. Over 3,100 cubic feet per minute.
Which, apparently, takes about 10HP. That would be a pretty substantial 12V motor.
So why not just make sure your engine bay seals are good like the factory intended, shroud/seal the I/C like the factory intended and use the very large fan you already have?
'77 S with '78 930 power and a few other things.
Old 03-25-2011, 04:25 PM
Panel,
Here you go Summit Racing:
Cole
Old 03-25-2011, 04:49 PM
