how to disable the ignition delay relay?
does anyone know which of the 4 terminals on the ignition delay relay you jump together to disable the thing?
i am sick of the annoying stumbling run on in my 930 and i've read you can jump 2 of the wires at the ignition delay to stop it. the pins are lettered and numbered: L, S, 30, and 31. does anyone know which ones you jump or connect together to disable it and stop the run on? don't want any opinions on it, don't care if the injectors are leaky, just want it to stop. thanks in advance for any helpful information. |
7.0:1 > 11.3:1 > 7.0:1
Hey Jim, I recall looking inside one of those relays and there was a capacitor between the legs of the coil. Try taking the cover off the relay and see if you can snip one leg of the capacitor then reinstall the relay.
