What oil?
Hi everyone ,
I know it maybe a contentious subject but do any of you guys have an oppinion on the best engine oil for a 930 turbo 1983? Im looking to do an oil change some swear by mobil some shell ,what do you guys think ? |
brad penn 20w50
87 carmine red 930 | 57k | B6 modified IC | GHL headers | custom exhaust | VEMS EFI | carrera intake w/ flipped TB | LS2 coils | EBC | K27-7200 (soon to be replaced by GTX3071 |
I use Brad Penn.
89 930.
+1
Registered Driver
Daily driver, occasional track day or full race spec.? Factory oil separator still installed?
20w50 is good for a daily driver but remember to always get the temps up and give it the occasional WOT while at operating temp. otherwise you will more than likely get the dreaded milky substance others have posted about. Also inspect the oil you remove as it will give you the best indication of how your engine and oil system are performing. I like to also drain the turbo oil tank too.
Ben '85 930 - Black on Black '95 993 Turbo - Silver |
+ 1 on brad penn
84 930 Slant 15 Sonata 2.0T 08 Ram 1500 15 Ram Eco Diesel |
Contentious?? Man, that's an understatement.
Easily available Valvoline VR1 Racing 20/50.
Mark H. 1987 930, GP White, Wevo shifter, Borla exhaust, B&B intercooler, stock 3LDZ. |
Banned
another Brad Penn'er
and I ALWAYS get it warm, anytime it's started up AND I ALWAYS get it WOT once warm at least 1x 8-) still get some milkiness under the filler cap - annoying, esp 'cause I never don't run the bejeezus out of it... |
Mobil1 vtwin fully synthetic 20w50.
1986 911 Turbo 3.3L, K27HFS, Tial 46mm, TurboKraft Intercooler, 964 Cams, Monty Muffler, MS3Pro Evo, M&W Ignition, Zietronix WBO2 Data Logger, Wevo shifter, coupler and motor mounts. |
Brad Penn grade 1 20-50
or the Valvoline VR1 their about same , google them
1986 944 turbo -first car 1997 993 Cab 6 speed-sold 1992 964 C2 turbo SOLD, 911GT ,CIS, 428 fwhp 450 trq, Carrillo rods, 964 cams, TT retainers,7.5 comp 1.1 bar boost 320 ml black fuel head 009 injectors, 044 pumps, 60-1 T4/T3 dual scroll turbo |
Chain fence eating turbo
I've been using Valvoline VR-1 and the main/rod bearings looked perfect after 5 years of use from the previous rebuild.
I still use good old Castrol 20-50 and change it every 3K miles like clock work.
Stephen 94 3.6Turbo 6-speed AWD |
Porschephd:
Which Castrol blend are you using (full synthetic)? How many miles have you run using Castrol? Are you running Castrol in all of your Porsche's? Also, how are your cam lobes looking after significant mileage? I'd like to hear about your experiences with this oil.. I'm running Mobil 1 Turbo Diesel Truck 5W-40 and everything is looking very nice inside thus far. 90k miles on the clock. I've been buying it from Amazon and using free shipping The previous owner also was running Mobil 1 full synthetic.
Thank you, HFR_Racer '87 930, 3.3 liter, K27 hybrid, Kokeln IC, Andial, B&B, Borla, 17" Supercups. Last edited by HFR_Racer; 06-11-2011 at 08:04 AM.. |
guys thanks for all your suggestions just to clarify the vehicle is NOT a daily drive vehicle its a sundays and high days vehicle for fun .The oil ive taken out looks dark in colour but not to bad ,i will send pic soon so you can check out .
The oil in there is mobil 1 15w/50 but as its a 930 turbo ive got a few little niggly oil leaks but nothing massive im aware that certain viscosities are better at helping this? additionally im in London UK so our winters tend to be cold and summers sometimes get into high figures which if im honest will most likely be the only time im driving her .I had thought about track days in the future so any updated comments taking into consideration this info would be appreciated . I dont know if i can getg "pen" oil here in uk? thanks |
im also confused about the fully synthetic argument ?
Driver
Anecdotally some people have noticed that if you switch from dino oil to synthetic, oil leaks may appear (or worsen). Conceptually the slipperiness of the synthetic is so good, it slips through cracks and crevices that dino oil would not have.
I used to run Rotella, but as I can't find it with the old formulation any more I've switched to the Valvoline VR-1 that was on sale for $2.50/qt a couple months ago. I've got a few cases in the garage for the future. I've also got a case of Brad Penn sitting on the workbench. All 20w-50. Of note, the regular Mobil 1 is not considered "good enough" anymore. The V-twin stuff is acceptable, but I think it's almost $10/qt. edit: Ultimate Motor Oil Thread or Why we hate CJ4/SM oils
1987 Venetian Blue (looks like grey) 930 Coupe 1990 Black 964 C2 Targa Last edited by Noah930; 06-11-2011 at 11:18 AM.. |
Forced Induction Junkie
50%/50% blend of Mobil 1 20-50W/Mobil 1 V-twin 20-50W
Dave '85 930 Factory Special Wishes Flachbau Werk I Zuffenhausen 3.3l/330BHP Engine with Sonderwunsch Cams, FabSpeed Headers, Kokeln IC, Twin Plugged Electromotive Crankfire, Tial Wastegate(0.8 Bar), K27 Hybrid Turbo, Ruf Twin-tip Muffler, Fikse FM-5's 8&10x17, 8:41 R&P |
The Pumpkin lives on a steady diet of Brad Penn 20-50. I get it from the Vavoline distributor in KC.
Bob Past President KCRPCA 1982 930 Track Car "The Pumpkin" 1986 911 Cab 2002 996tt X50 Lapis Blue Street Machine |
Mobil 1. Let's the war continue...
