1986 911 Turbo 3.3L, K27HFS, Tial 46mm, TurboKraft Intercooler, 964 Cams, Monty Muffler, MS3Pro Evo, M&W Ignition, Zietronix WBO2 Data Logger, Wevo shifter, coupler and motor mounts. |
Porsche changed the pressure trying to force more fuel through too small a hole, to much back pressure reduces pump efficiency requiring a second pump. Fuel starvation should not be a problem if the nozzles are sized correctly on a 400 HP engine, fuel requirement can be calculated based on HP. Nozzle sizes can be determined by fuel requirements. 75 PSI is plenty for proper fuel atomization. |
NA engine - 5 bar Turbo at 1 bar boost requires 6 bar system pressure minimum to maintain 75 PSI at the injector.
1986 911 Turbo 3.3L, K27HFS, Tial 46mm, TurboKraft Intercooler, 964 Cams, Monty Muffler, MS3Pro Evo, M&W Ignition, Zietronix WBO2 Data Logger, Wevo shifter, coupler and motor mounts. Last edited by WinRice; 07-03-2011 at 10:12 AM.. Reason: clarify |
Yes the lambda regulation is triggered by the (3 positions) throttle switch. ( as you said no RPM reading) ![]() As soon as the throttle butterfly is opened by more than 6°, the lambda regulation is triggered off and the freq valve duty cycle is fixed to 50%.
965 C2T / 1991 3.3 TURBO |
USA and Canada cars had smaller injectors to meet EPA regs, cars with serial numbers WPOZZZ have the proper injectors for a stock or mildly modified engine. |
Cool, this is good to know! You called it a 3 position switch. I assume the 3 positions are closed (idle), 6 deg for open-loop crossover and open (WOT)? If so there would be no simple way to raise the open-loop threshold. Can you tell me the part # for the fitting you bought from Summit to install the 044 pump up front? Ahhh, the joys of CIS tuning - most of my WOT testing has been in ~60F ambient temps. Today it is ~80F and I can't get the car to go leaner than 12.0 above 60000rpm, which IMO is perfect! The boost level is almost exactly the same. Once I burn through this tank of 94 octane w/10% ethanol I will try a tank of Shell 91 octane (no ethanol). Regardless of what other steps I take, the front fuel pump will be replaced with an 044. Mine is already 19 years old so I don't mind spending the money to replace a part that will die one day. Maybe this change alone with get me enough extra fuel for the 1/2 point of WOT fuel I am looking for ![]() Water/meth is a very interesting option with quite a few benefits but I am always reluctant to add another "system" to a car. Just more stuff to go wrong... Having said that, a simple kit with a small nozzle that activated @ WOT above 5500rpm would surely cure my issue. Last edited by Ringmaster; 07-03-2011 at 12:33 PM.. Reason: 1 |
I never tested the - 009. But once again, I am 100% sure the 057 outflow the 017. Attention, the 057 provide more fuel everywhere on all the RPM range.
I found the formula, 400 brake HP at the crank needs 42 LBS of fuel per cylinder per hour at WOT or about 5 gallons per hour per cylinder. These are forced air induction fuel calculations. Pump and nozzle requirements can be figured from there |
However, if you have some tools (pressure gauge etc) in your hands, you could do some investigation prior to buy it. At least you could check your usual "static" fuel system pressure. If still @ 6.8 or 7 b , you can try to add a single washer to the fuel pressure regulator, rise about 7.6b in static and see what happen. By the way, are your injectors new or professionnaly cleaned recently ? if not, this is a "must do" prior to do anything else ! If your injectors are not flowing correctly, the entire range of RPM , fuel saving and even the reliability of the engine are compromised.
Bonjour Thierry25
![]() Quote:
In an earlier post you said: Quote:
I have been given some good advice that the stock fuel filter might be a restriction when trying to get max flow out of the high-pressure CIS system. Has anyone successfully fitted a billet race-type fuel filter in place of the stock fuel filter? Any improvement? |
We've had some nice mid 80F weather this week and the WOT AFRs are spot-on but when it gets below 50F it is too lean above 6000RPM. Since lots of 911 turbos only venture out in nice warm weather maybe this is why some owners don't need to get as creative with the CIS system as others? Still hoping that installing an 044 pump up front to work in conjunction with my rear 044 pump will do the trick ![]() |
Well I have to eat all the words I said earlier in this thread and I admit my opinion was wrong because with internet searches I found a definately genuine new bosch made in czech republic 044 pump in the sealed plastic bag inside the black multi language box with the usual bosch red multi folded sheet of paper instructions in many different languages for $188 shipped from a genuine Bosch dealer and installed it.
I already have the CIS Flowtech 20% over modified fuel head and Brian Leask adjustable control pressure regulator installed and the CPR is adjusted well for my car and the AFR's I want. I have the innovate MXT-L AFR gauge with built in controller installed and it is accurate and consistant. I did nothing else other than install the bosch 0 580 254 044 pump in place of the front bosch 0 580 254 967 pump that was installed around 40,000 miles ago by the previous owners mechanic and the AFR'S went from about 12.5:1 at 1.1bar boost around 6400 rpms down to around 11.8:1 I havn't logged AFR's, I just glance down at the AFR gauge while driving. At idle I had the CO screw adjusted so it was around 13.5:1 with the old front pump and idle went down to around 12.8:1 with the 044. A small adjustment to the CO screw put it back to 13.5:1 at 750-800rpm idle speed. Steady warm cruise AFR at 75mph on flat Florida interstate moves around between 15 and 15.2:1 and it runs great. I'm also glad to find the new 044 pump is no louder than the little bit smaller one that was in there. |
Must have been one tired 967?
1986 911 Turbo 3.3L, K27HFS, Tial 46mm, TurboKraft Intercooler, 964 Cams, Monty Muffler, MS3Pro Evo, M&W Ignition, Zietronix WBO2 Data Logger, Wevo shifter, coupler and motor mounts. Last edited by WinRice; 07-19-2011 at 11:46 AM.. |
This...
![]() JFairman and WinRice, are you running dual 044 pumps or just the 044 up front? Thanks |
Do I back off the fuel enrichment 1 notch? And richen up the idle?
'24 Tesla Model 3, '22 Tesla Model Y '19 Tacoma '06 Carrera, '79 930 '06 S4 Avant |
Turbofrog
Bryan: Yes, you leave a lot on the table running 10.5AFR. Mine almost dies when that rich but I have my spark plugs at 0.4.
15.3AFR is the best for fuel economy so maybe aim for that. IIRC it also run cooler that 14.7AFR. RM: I think the front 044 is enough. I'm running two 044s but then again I had major lean running problems that I tried to cure with pumps to no avail. I now have 11.5AFR at 4th gear 6000rpms (shorter gears) and 1.1bar boost. It does still seem sluggish at speeds (compared to my audi) so I'll finally add the WMI pump with a simple pressure switch I've had in the shelf for two years. I wanted to get the fueling sorted first. |
Thanks, I'll richen up the idle and turn down the fuel enrichment a notch. I'm also thinking about getting WMI as well. Any recommendations?
Turbofrog
My BL WUR enrichment didn't do much on upper rpms and I have it blocked now that I run AIC1.
044 front, stock rear at that time. I'm currently upgrading the fuel system for EFI and the potential use of E85, so I have another 044 on the shelf for the rear.
