930 slant nose authenticity question-help!
so i've had the car inspected-steel hood check, oil cooler, single motor, etc check...
i have a factory certificate of authenticity that say it had the factory slantnose option... BUT vin number is WP0JB0938HS051192 this reads as an ordinary 911 -am i making a mistake-don't factory slant nose VIN's start WP0EB..? help! thanks |
What year?
JB - BreitWerks www.breitwerks.com 321-806-8664 Engine Rebuild & Restorations |
here is a factory slant...same vin..hope this helps
1987 Porsche 930 Coupe for Sale 1952 | Truspeed Motorcars |
83 911 Production Cab #10
Here is your VIN breakdown. At the bottom under "unable to find" is code is I505. As you probably know M505 is Slantnose.
Model year: 1987 Model ID: 911 Engine Code KW HP Liter Cylinders Model 930.68 210 286 3,30 6 911 TURBO (USA) 930.68 221 300 3,30 6 911 TURBO USA Transmission Code: 930.36 Options found on your vehicle. M220 Locking differential 40 % M533 Anti-theft device M650 Electrical sliding roof The following codes were found, but the description may not be accurate. I383 Vertical seat adjustment, right I387 Carrera GT bucket seat xt, right We were not able to find definitions for any codes below this line. I158 I505 I975
Who Will Live... Will See ![]() ![]() ![]() 83 911 Production Cab #10, Slightly Modified: Unslanted, 3.2, PMO EFI, TECgt, CE 911 CAM Sync / Pulley / Wires, SSI, Dansk Sport 2/2, 17" Euromeister, CKO GT3 Seats, Going SOK Super Charger |
it's a 1987..it seems as though 87's had a J in the vin, and 88's an E...
but that's not good news re finding the 505... here's the certificate of authenticity...
try this for codes Porsche Option Decoder
Hey Phil check out post #3
Anyone has info on this guy "lowmileshasbeens" - Rennlist Discussion Forums |
DP935 member
I looked in my factory slantnose database and most of the 87's I have are J's.
I own 2 factory slantnose coupe's and they start are J's for the 4th digit too. You can call Porsche in Altanta to confirm but from the COA it looks to be legitimate. I have some 88's and 89's with J's too on the database.
Porsche Slantnose M505 M506 group on Facebook. https://www.facebook.com/groups/719995181372494/ |
what is the asking price of the car?
84 930 Slant 15 Sonata 2.0T 08 Ram 1500 15 Ram Eco Diesel |
Driver
I noticed some inconsistency between the "J" and "E" when I was searching for a car. Books would say one thing and the actual stamped VIN and accompanying paperwork would say the other. Also don't freak out if you find a stamped VIN in the front trunk with WPOZZZ... That's one place that all cars--even US models--had the "ZZZ" designation in the VIN, though the rest of the VINs on the car and paperwork should read the proper JBO/EBO/ABO. There's nothing in the VIN, itself, that will tell you if this is a factory slant or aftermarket conversion with proper parts.
1987 Venetian Blue (looks like grey) 930 Coupe 1990 Black 964 C2 Targa |
wow! that's the guy i've been dealing with....he'd be making quite a profit from me... |
Phil
The 3 listed as "We were not able to find definitions for any codes below this line" at post 4 are listed on you COA. I158 (Reno Radio for 1987) I505 (Slant nose for USA) I975 (Velour carpet in luggage compartment) Not sure what the M or I in front are but when you look for option decoding you only use the number Vin: http://www.***********.com/life/vin/vin.php Code: http://www.964uk.com/Documents/Porsche%20Option%20Codes.pdf
Driver
Driver
Sorry phil. Got your car mixed up with someone else asking about pre-purchase advice on a 930.
1972 911S (2.7 RS Spec engine) 1973 911RS (2.8 RUF rebuild) 2014 GT3.1 Now available... 2018 GT3.2 Miami Blue, 6 spd... ![]() ![]()
I've gone native
Did you get the car?
'07 997.1tt Blk/blk 600hp, bad to the bone |
Factory Slant
You can contact Marc Noack at marc.noack@porsche.de.....He works at Porsche in Stuttgart. I recently went through this when I purchased a 1987 930S Slant....it indeed was a factory car. My car is a Sunderwunsch...or special wishes and it does not have the 505 designation on the sticker...so that does not mean that just because your car does not have the 505 option code that it is not a factory car. A few features to look for are boxed rockers, one headlight motor, additional oil cooler under the front valance (usually found only on Euro cars), the vanes in the inlet behind the door are made of wood....hope this helps....DR
+1 for Marc he is the man...
'73 914 2.0, '74 911 Coupe, '74 911 Targa '78 924, '84 944, '86 944 Turbo, '84 911 Coupe '84 944 (current), '96 993 Coupe (current) '73 911T Coupe (current) '88 930S M505 (current) |
