What do you think of this intercooler for a twin turbo?
I have a 1985 Porsche 911 twin turbo and i have been thinking of replacing the intercooler
I found these two. How do you think they fit on a 1985 911? One thing is that i would like to have the outlets to the turbos pointing down instead of to the sides On th first one i would like to have the inlet pointing straight forward to the engine as well. The first picture of the intercooler is upside down. Measurements is 27"x13"x7" ![]() ![]() Or this one. Measurements is 29"x13"x7" ![]() ![]() Last edited by MrShades; 09-02-2011 at 09:15 AM.. |
After the next project
As long as the inlets or the turbos were facing down you should be good.... But have others measure the width of there's to be certain you are not too wide.
I know nothing about the companies quality, flow rate, or efficiency either... Mybe someone else could help with that. Bryan
Current cars: 2012 Cayenne TT, 1997 993TT, 1912 Buick Model 34, Audi S8, 1976 912E, 2016 Cayenne Diesel |
Infidel
The 'Just Intercoolers' one has a lot more cores, and the fins 'look' tighter packed.... My money would be on that one having better cooling ability.
This thread is a good read 9M Prototype intercooler test report - Rennlist Discussion Forums Results on different coolers, and as you can see the better performing ones has more cores and really tightly packed fins. These are high end coolers, the best one being a Secan, i'd look to copy it as best as possible
Jonathan. 87 930, 993 turbo engine, RS Tuning 520PS/515lbf-ft, Arrow Rods, ARP hardware, Solid lifters, G50-50, RS Flywheel, 890nm Sachs clutch, RSR coil overs all round, 993 C4 calipers front, 930 fronts on the rear, Ruf Speedlines..... Old 540 BMW, XB12S Modified, for being a total hooligan ![]() |
Crotchety Old Bastard
I thumbnailed the GodSpeed unit several years ago but never got around to finishing that project. You have to wonder what the difference is between a $300 intercooler and a $3000 intercooler. Besides being made by slave labor in Asia what is the structural difference that drives up this cost? How much more efficient are the expensive units?
RarlyL8 Motorsports / M&K Exhaust - 911/930 Exhaust Systems, Turbos, TiAL, CIS Mods/Rebuilds '78 911SC Widebody, 930 engine, 915 Tranny, K27, SC Cams, RL8 Headers & GT3 Muffler. 350whp @ 0.75bar Brian B. (256)536-9977 Service@MKExhaust Brian@RarlyL8 |
Banned
well, good note ah, ha ha
I suppose there is quite a difference but it would be fun to check out the cheap intercooler.
I can easy convert the intercooler so the outlets points down to the turbos I suppose the to outlets goes to the turbos and the inlet to the engine ![]() Have a look at the picture and tell me what you think. Note that the overall lenght will be shorter because the outlets to the turbos wil be on the underside. I have tried to mark it with grey arrows This is the info about the intercooler: ![]() Length 29" Length (Core) 24" Height 13" Height (Core) 7" Thickness 3.5" Inlet 2.5" Outlet 3" Compress Air Flow Rate <700Cubic Feet/Min, Rated to 600-700 Max HP Working Pressure: 5~50PSI Pressure Drop 1~4psi@35psi; 0.2~0.5psi@15psi Hot Air Temperature 32°F~302°F (0°C~150°C) Material 100% Aluminum Design Bar and Plate Construction Machine Cut and Stamped, Hand Welded Finish Polished Net Weight 22 lbs Tell me what you think of the description of the intercooler |
Cheap Intercooler versus Expensive one..data here:
Supraforums.com
Ole Skool - wouldn't have it any other way |
Tim Allen is my HERO!
Since no 1974-89 911 turbo engine came from the factory with twin-turbos, that application may be even more ambiguous. Caveat Empor'
1983 911 3.3L Turbo(YES, I know the turbo badge is on the right...had to be different!) 1996 Toyota Corolla(der 'clapper') |
