TurboKraft's Avatar
Originally Posted by mamut View Post
My plan is getting LN engineering 3.4 L cylinder and pistons, GT-2 EVO cam, race valve spring, twin plug, Pauter rods, raceware head studs. up the engine redline to 8000RPM.
IMHO, Still too big for that combination, a pair of gtx3071r's will do much better.,cheers,Stefan.[/QUOTE]
Done both of the above. Booooooooring. German Supra.
Want torque, response, and up to 650rwhp? Run GT28xxR turbos.
Chris Carroll
TurboKraft, Inc.
Tel. 480.969.0911
email: info@turbokraft.com
http://www.facebook.com/TurboKraft - http://www.instagram.com/TurboKraft
Old 09-07-2011, 03:37 PM
++1 on the GT28RS I *think* their compressors flow 35lb/min, so should be good for ~700HP
Sounds like Albert is aiming for BIG (1000+) numbers though
Each to their own... either way, I love seeing these unique configurations
P.S: Chris, have you ever fitted GT28RS turbo's on 993TT heat exchangers? Is it an easy mod?
Old 09-07-2011, 04:17 PM
TurboKraft's Avatar
Yeah, twin GT35Rs did 819rwhp without much effort.
Yes, we have done the twin GT28xxR on 993TT heat exchangers many times:
Turbos & Manifolds Installed
New Header Flange Comparison
That 3.6L did over 700hp on MODE's dyno, later 645rwhp on Dynojet. Huge, wide torque band to work with.
Chris Carroll
TurboKraft, Inc.
Tel. 480.969.0911
Old 09-07-2011, 04:50 PM
WHOA, awesome numbers!
At what boost levels did you net those numbers? On pump fuel, or race?
Old 09-07-2011, 05:18 PM
race911turbo's Avatar
Originally Posted by 911TT33 View Post
What A/R are you running in the hot housing on those GT35R's? 0.63?
What sort of HP are you aiming for? 1000+ HP?
I personally would prefer a twin GT28RS setup to make that car a LOT more enjoyable, and still have excellent response and tonnes of power
Also, the length of those headers won't help response times on those massive GT35R's
Single turbo A/R 0.84, for twin turbo I swap turbine housing to 0.63.
1975 914, 1988 944 turbo S sold.
1986 944 turbo resleeve 2.7, DTA S-60 PRO.
1986 911 Carrera with 965 turbo motor, DTA S-80 PRO.
1989 930 EFI, DTA, Carrera intake, twinturbo,2x GT-35R.
1991 964 convertible, wide body conversion.
Old 09-07-2011, 05:46 PM
spence88mph's Avatar
Damn you do some awesome stuff Chris, I saw he retained the factory lid, did you put intercoolers in the guards? could this be done on a 930 and get enough airflow?
'89 911 M491+Turbo
'90 964 C2
'89 944 Turbo
'88 928S4
Old 09-07-2011, 05:54 PM
TurboKraft's Avatar
Originally Posted by race911turbo View Post
...for twin turbo I swap turbine housing to 0.63.
Major compressor surge!
Chris Carroll
TurboKraft, Inc.
Tel. 480.969.0911
Old 09-07-2011, 05:55 PM
Think about what HP this setup would make at 8000 - 8200 RPM or just looking at the engine bay would make me excited.
GT-28, GT-30, GT-35 use same V-band flange, I can do a swap in 2 hours.
I don't try it I would never know twin GT-35R turbocharger would feel like....
6 individual throttle body on my shelf should look better in the engine bay!!!!!
Old 09-07-2011, 06:35 PM
A/R 0.63x 2 = ?? compare with A/R 0.84x 1 = ??............
At idle air blow like hair drier...
Old 09-07-2011, 06:48 PM
0.63 A/R is a good size for TT's... you can go down to 0.48 A/R and it will be VERY responsive, BUT it will choke the motor at the top end and limit HP output.
All depends how you use your car
Old 09-07-2011, 09:29 PM
Yes, 0.63 is good for 930 twin TT. Half of 3.3 Liter = 1650cc , each turbo with A/R 0.63 handle 1.65 liter.
Old 09-07-2011, 10:53 PM
The problem with running a big compressor wheel is the exhaust turbine has more mass to get spinning, which = more LAG, but once it's get spinning, it can flow huge amounts of air.
Smaller compressor wheel = quicker boost onset = fatter torque/power band = more fun
Chris, how does the boost characteristics differ between the GT28RS vs K16/24 or K16/16G in a TT configuration?
Old 09-08-2011, 12:45 AM
TurboKraft's Avatar
Originally Posted by MrShades View Post
I want a intercooler that looks something like this or this
:-) Thanks!
Getting back to the original topic:
A very nice looking car. Do you have any specifications on the turbochargers? There is a tag on each, between the top oil inlet fitting and the side coolant port, with a part number XXXXXX-xxxx.
Any photos of the exhaust?
The 0.6bar sounds very conservative, but a lot depends on the tuning, and how much your 915 clutch can withstand.
Chris Carroll
TurboKraft, Inc.
Tel. 480.969.0911
Old 09-08-2011, 10:03 AM
MrShades's Avatar
I did not convert the car but it is Garrett M27 AR 48 turbo`s after what i can see
Is that not called the T series turbo?
Yep, on a 3.8 or 4.0 big bore motor they'd be OK, but on a 3.3, they're too big
When do you get full boost, Albert? Way past 4K RPM I would think
MrShades, what size Garretts do you have on your TT setup? T3's?
Old 09-08-2011, 02:15 PM
TurboKraft's Avatar
M27 -- is that cast on the compressor cover? There should also be an ID tag on the bearing housing.
The only reference to "Garrett M27" I find is a small GT15 turbocharger, OEM for 2.0L Saab Turbo, etc.
We've used two for a twin turbo before, but on a smaller displacement engine <3.0L.
Even on the small engine, these turbos were a little too small, too much turbine back pressure. Went with a pair of bigger turbochargers and didn't lose any response, and gains in performance.
Chris Carroll
TurboKraft, Inc.
Tel. 480.969.0911
Old 09-08-2011, 06:31 PM
MrShades's Avatar
TurboKraft
I just wrote down what i could see when the car was taken apart when we restored the car
The turbos on your picture looks a bit smaller than the ones on my car(it might just be the picture)but the turbos works very well
I will have a better look when i have the car on a lift
There is no turbo badge on the car and even if i put in bigger turbos it still will not have turbo badges. I might go for a 911 badge but that is all.
Never thought about the turbos but now i have to see what the tag says. If i remember right it is a blue tag on the turbos and the tag was hard to read without taking off a turbo but
i need to know even if that mean to take one off
The brakes on the car i Brembo big reds
One qustion about the length of the exhaust pipes i have seen some that use long exhaust pipes and some that use short pipes. What is the best on a 911?
This is how the set up looks(i need to wipe/sand off the the dirt and surface rust on the exhaust) It is the only picture i took before painting of the car
You can see the intercooler under the masking paper. It for sure sound loud when you use the car
Old 09-08-2011, 08:10 PM
I assume you mean the exhaust pipe before the turbo?
If so, shorter exhaust pipes are best to minimize lag.
Old 09-09-2011, 03:58 PM
MrShades's Avatar
No i have heard about the length after the turbos will affect the cars performance.
After what i understood is that there is some benefits with long pipes and also some other benefits with short pipes
Old 09-10-2011, 12:26 AM
AFTER the turbo, a shorter pipe is better as it results in less back-pressure on the turbo, and maximises boost response. You want to get rid of the exhaust gas as quickly as possible out of the exhaust.
BEFORE the turbo, you want shorter exhaust pipes (i.e. the primaries on the headers) to maximise exhaust gas velocity, which spools the turbo up quicker.
That's the theory anyway
Old 09-10-2011, 01:06 AM
This is my theory..
Longer equal length header will give out smoother exhaust energy to turbocharger.
Heat = energy, longer pipe = heat lost before turbocharger, some use thermal barrier coating or header wrap to keep heat in the piping. Some use thicker 3mm stainless steel pipes.
Short unequal length header give out fast respond, but cancel some of energy between cylinders.
Long equal length header = higher HP number.
Short equal length header = faster turbo respond.
Old 09-11-2011, 02:50 AM
