-   -   Another rust combat (http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/634616-another-rust-combat.html)
proffighter 01-19-2012 02:06 PM
Found some time for another drilling session:
http://forums.pelicanparts.com/uploa...1327010781.jpg
proffighter 01-23-2012 12:45 PM
Until the thub returns, I use the time to work on everything else:
Door cut-outs are to small and don't look that good:
http://forums.pelicanparts.com/uploa...1327351241.jpg
As I decided to remove stereo I will increase and change layout of the opening. Here is the result of about 20 versions I created and compared:
http://forums.pelicanparts.com/uploa...1327351369.jpg
...And I received my new steering wheel today:)
http://forums.pelicanparts.com/uploa...1327351508.jpg
steven c 01-25-2012 06:43 AM
Incredible Roland! Keep it going for sure. BTW...nice rabbit! We have a dwarf Netherlands.
proffighter 01-25-2012 02:34 PM
Today I received new rear light housings. I decided to buy aftermarket plastic ones, lighter and cheaper then stock. My old ones had almost no more shiny chrome inside. I spray-painted them a few years ago with chrome effect, but it did not last long and was not really shiny either...
http://forums.pelicanparts.com/uploa...1327530531.jpg
http://forums.pelicanparts.com/uploa...1327530857.jpg
IMR-Merlin 01-25-2012 02:37 PM
interested in these, the factory ones are HEAVY, how much and where did you source them?
rsrfan 01-25-2012 02:41 PM
Originally Posted by imr-merlin (Post 6517394)
interested in these, the factory ones are heavy, how much and where did you source them?
+1
proffighter 01-25-2012 02:49 PM
Bought them here:
911 1969-89 Rear Light Unit Right - Detailed item view - Type 911
Just saw the price increased. I paid 125 GBP each, now they are 135 GBP
PS: Weight is on the kitchenscale about 300g each without lens like on pic
proffighter 01-28-2012 02:37 PM
First door finished:
http://forums.pelicanparts.com/uploa...1327790185.jpg
And another drilled part:
http://forums.pelicanparts.com/uploa...1327790272.jpg
proffighter 02-02-2012 02:02 PM
Time to drill another part:
http://forums.pelicanparts.com/uploa...1328220161.jpg
Quicksilver77 02-02-2012 02:38 PM
Fanatical! I like it!
proffighter 02-08-2012 01:51 PM
Made some molding tools to cut the foam panel with my homemade cutter
http://forums.pelicanparts.com/uploa...1328737433.jpg
It's a simple construction with a hot wire (made for this application) using a power supply (not on pic). Costs about 100 USD all in all
http://forums.pelicanparts.com/uploa...1328737673.jpg
And that the result, a nice moulding that is pretty precise to use for laminating
http://forums.pelicanparts.com/uploa...1328737870.jpg
proffighter 02-10-2012 02:02 PM
Dr. Drill is back
once more...
proffighter 02-10-2012 02:05 PM
Oops forgot the pics:D
http://forums.pelicanparts.com/uploa...1328911479.jpg
IMR-Merlin 02-10-2012 03:02 PM
Man, you are amazing with your patience for drilling.
Ronnie's.930 02-10-2012 04:12 PM
I think you need a therapist - like now! :p
BTW: that steering wheel looks like a Mod 7 but in leather rather than swede/alcantra . . .
proffighter 02-11-2012 03:24 AM
Well it looks like I found my therapy :D
Correct, Mod07 in leather
proffighter 02-28-2012 01:34 PM
Door panels laminated and removed from moulding. Unfortunatly I had issue with parting agent, was too old...
http://forums.pelicanparts.com/uploa...1330464724.jpg
http://forums.pelicanparts.com/uploa...1330464812.jpg
But not a big thing. Only a bit more working on the surface before painting
proffighter 03-07-2012 04:04 PM
edges cut and a short fitting test
http://forums.pelicanparts.com/uploa...1331164912.jpg
http://forums.pelicanparts.com/uploa...1331164984.jpg
http://forums.pelicanparts.com/uploa...1331165052.jpg
proffighter 03-09-2012 02:14 PM
Body has left for a while
Today it was picked up for blasting, body work and painting. Will post some pics of progress from time to time
http://forums.pelicanparts.com/uploa...1331331142.jpg
http://forums.pelicanparts.com/uploa...1331331214.jpg
http://forums.pelicanparts.com/uploa...1331331287.jpg
speednme1 03-09-2012 05:40 PM
http://forums.pelicanparts.com/uploa...1324682757.jpg[/QUOTE]
Great work! But what kind of cat is that with the big ears............just kidding..cute bunny
Ronnie's.930 03-09-2012 06:06 PM
It looks like you need to train that rabbit to **** in one spot! :p
I like the door inserts - you did an excellent job!
proffighter 03-10-2012 10:06 AM
He is trained to recycle newspaper
http://forums.pelicanparts.com/uploa...1331402803.jpg
On this pic he was only 10weeks old
proffighter 04-18-2012 02:01 PM
While the car is still at the body shop, I work on parts. Because I have a lot of selfmade aluminum parts like bushes, spacers and brackets, I decided to anodized them myself. I found a while ago some information and a good source for material and forum.
Here are parts before, whithin anodizing process and after. There are more steps than shown here, but it's mainly:
Cleaning (with removing old coat if there is one)
anodizing
colouring
hardening
Here are the parts before any work, just raw aluminum:
http://forums.pelicanparts.com/uploa...1334782249.jpg
http://forums.pelicanparts.com/uploa...1334782317.jpg
Besides some cans with acid etc. and a steamer this is the main equipment:
http://forums.pelicanparts.com/uploa...1334782488.jpg
Anodizing in progress:
http://forums.pelicanparts.com/uploa...1334782579.jpg
Here is the final result:
http://forums.pelicanparts.com/uploa...1334782694.jpg
http://forums.pelicanparts.com/uploa...1334782797.jpg
proffighter 05-14-2012 01:38 AM
Some more anodizing, went out very nice too:
http://forums.pelicanparts.com/uploa...1336984123.jpg
http://forums.pelicanparts.com/uploa...1336984141.jpg
Also I tried to nickel-coat (chemical, electroless). First removed old coating, which was very easy, only some caustic soda (10%) on night and the steel is clean. After you have to use two different baths, cleaning and acid cleaning until it comes into the Nibor (brand) bath with contains all the chemicals and the nickel-Boron.
Here is the result:
http://forums.pelicanparts.com/uploa...1336984666.jpg
http://forums.pelicanparts.com/uploa...1336984680.jpg
smurfbus 05-14-2012 02:39 AM
You've gone plaid with your drill : 0
I don't even recognize those parts, maybe from throttle or clutch?
proffighter 05-14-2012 04:49 AM
Nor...
Door lock mechanism:
http://forums.pelicanparts.com/uploa...1336996136.jpg
geolab 05-31-2012 07:15 AM
I just ordered some Nibor thanks to you, I hope you are happy with the results
did you acid dip the spring to clean it ? I heard they will break after a short while, if put in acid.
proffighter 06-01-2012 12:11 AM
Yes, I am happy with results, looks really nice. What I can't tell yet is how resistant to corrosion it will be...
I stripped the zinc first in a bath with ca. 10% Natriumhydroxid (easy to get) for about 24 hrs, just look at the bath until no more bubbles will rise. Steel will be blank after, slight corrosion will be removed too. Then into 5% acid sulfur (there are better chemicals but not as easy to get) to remove rest of corrosion (if needed) for a short while, no longer as it's clean. With no rust maybe 2 minutes. this is recommended to prepare for Nibor bath.
It is very important to flush parts between the baths with a lot of water (distilled if possible) and not let them outside longer than necessary, they will start corrode immediately.
I dipped the springs the same way, but did not leave them in the Nibor bath for one hour, but 30min. The thicker the coating, the brittle it will be.
BTW. I had some parts with nickel plating too, this will not be removed by the Natriumhydroxid...
proffighter 06-02-2012 11:27 AM
While I still anodizing a lot of selfmade aluminum parts, I disassembled, cleaned and regreased the steering/beam and fitted new boots.
http://forums.pelicanparts.com/uploa...1338661652.jpg
Note: The spacers of my first anodizing try are for the steering to save some weight here too :-)
proffighter 06-11-2012 12:36 AM
As I am on the way to lighten my car I made some more parts on my lathe and anodized them together with the other aluminum parts of the suspension:
http://forums.pelicanparts.com/uploa...1339400158.jpg
http://forums.pelicanparts.com/uploa...1339400170.jpg
proffighter 07-26-2012 02:12 PM
Update finally!!!
While tube is still in work, I am multitasking since a while:
Working on suspension, brakes, fiberglass etc. A lot of parts are somewhere between start and finished.
For now I show my calipers. Media blasted (where red but ugly made) and cleaned:
http://forums.pelicanparts.com/uploa...1343337054.jpg
And after anodizing:
http://forums.pelicanparts.com/uploa...1343337088.jpg
Now they look like stock. I am unsure if I should make them red again. Like red calipers and it would be a nice contrast to the black center of the wheels.
Recommendations welcome:)
Flieger 07-26-2012 08:08 PM
Black or silver. No red.
herman maire 07-26-2012 08:33 PM
or yellow:)
proffighter 08-14-2012 01:29 PM
Update :-)
As I am working on several parts, there was not much to show. But I found some anyway;)
Front strut cleaned, Nuts and bushes anodized (of course), bump steer kit mounted too:
http://forums.pelicanparts.com/uploa...1344975926.jpg
Front hub before and after anodizing, they a bit darker in real than on pics because of the aluminium alloy. I decided to let it be and not coloring as I like the look:
http://forums.pelicanparts.com/uploa...1344976067.jpg
http://forums.pelicanparts.com/uploa...1344976089.jpg
http://forums.pelicanparts.com/uploa...1344976113.jpg
proffighter 08-26-2012 08:20 AM
Since I mounted the WEVO engine and tranny mounts, I did not liked the golden color that much. Therefore I decided to anodize them black:
http://forums.pelicanparts.com/uploa...1345994145.jpg
Further I worked on my Hargett shifter. The couplers are way to massive for that application and they are raw steel, oxidation will be an issue. Mine started already to show some surface rust. So I machined them a bit to reduce weight and nickelplated (homemade too) them after polishing. They look quit nice now:
http://forums.pelicanparts.com/uploa...1345994344.jpg
Further I drilled the shaft on the front side, where no stress is to expect:
http://forums.pelicanparts.com/uploa...1345994423.jpg
proffighter 09-02-2012 12:32 PM
Guess what... ;-)
As the order from Pelicanparts is still on the way, I found something more to anodize in different color, my Tial, formerly blue:
http://forums.pelicanparts.com/uploa...1346614301.jpg
http://forums.pelicanparts.com/uploa...1346614323.jpg
proffighter 09-05-2012 05:18 AM
Tell me your opinion
I received lot of parts from Pelican yesterday. Among other things I get Tarett sway bars. Now as you know I like to drill and machine almost everything:D
I am suprised, how massive the front sway bar housing for the bushes are (the red round ones), maybe 1" thick! If I compare to others like Smartracing al lot of more material there.
Therefore I thought to machine of some of the material. My thoughts are to remove the red areas on the drawing for about half the thickness. Drawing is a bit somewhat square, would make smoother edges
Please let me know your thoughts about.
http://forums.pelicanparts.com/uploa...1346847506.jpg
proffighter 09-05-2012 06:15 AM
Different, easier to do version, red machined down to half the thickness:
http://forums.pelicanparts.com/uploa...1346850952.jpg
Flieger 09-05-2012 01:22 PM
In the last version - is there clearance for the bolt head next to the center thicker part?
I would say go for it. If it breaks it is not a big deal since it is just the anti-sway bar. So in the spirit of Colin Chapman, machine it until it breaks, then get another one and machine it down just a little bit less. :)
proffighter 09-05-2012 01:39 PM
As I remember, some of Colin's drivers did not survived.... ;)
I tend to the second one, easier to do and a lot of beef there. I think I will remove material on the lathe down half the thickness (still 11mm thick) and reduce diameter to the middle between teflon bush and screw head/shim
http://forums.pelicanparts.com/uploa...1346877561.jpg
http://forums.pelicanparts.com/uploa...1346877582.jpg
