-   -   Another rust combat (http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/634616-another-rust-combat.html)
proffighter 08-05-2023 01:13 AM
Originally Posted by chrisbalich (Post 12060475)
Very cool, Roland. Thank you.
I'm always looking to expand my tool collection and this looks much more precise than a press-brake or just jamming something in my vise.
it's a Swissmade Gressel, one of the tool companies here in Switzerland and well-known allover Europe. There is no better one if you need a vice, especially those for the work bench but also machine vices. Very expensive but last longer than your life.
LJ851 08-05-2023 05:01 AM
Roland,
I’ve been looking for a quality benchtop bender like this for a while now. All I have previously found are the Asian universal benders but they don’t appear very well made. Looking at Gressel’s line of HB benders it appears yours is a HB10 ? Is this correct?
Thanks !
proffighter 08-05-2023 07:57 AM
Originally Posted by LJ851 (Post 12060771)
Roland,
Thanks !
Yes, it's a HB10. I worked also with HB14and HB20. The 20 is what I would buy but the price...
proffighter 09-05-2023 11:33 AM
Today I was able to proceed with the fan. I could borrow the tool to set the rivets. After a few Test rivets I set the "real ones". To have a good solid fixation to hit the rivets, I made an massive aluminum counter part as seat for the hub.
http://forums.pelicanparts.com/uploa...1693937352.JPG
It went easier than I expected. Looks quite nice. Only 3-4 hits with the tool and done
http://forums.pelicanparts.com/uploa...1693938080.JPG
And of course test fit to check how it looks, I like it.
http://forums.pelicanparts.com/uploa...1693938365.JPG
The hub is an aluminum replacement. Nice made BUT the rivets needed are not 72° as stock but 90°. No issue so far, but I expect if someone sells replacement which need different hardware, he should inform. For this reason I have now a lot of both versions ;)
When I want to check the amount of shims needed I fitted a new belt. Bought according parts catalogue 710mm but it's way to long. Checked the old one: 700mm?? How this can be? Checked other suppliers like PP, FVD, all the same. 710mm. The only thing left is the Smartracing pulley on the crankshaft, I thought it's the same diameter than stock, but have no stock one to measure... However it is like it is, have to buy a 700mm.
pkabush 09-05-2023 01:49 PM
Not sure this will help but, I just went through a similar issue with my belt not fitting after installing a different fan.
It turned out that the fan wasn’t sliding all the way onto the alternator shaft. I re-installed my original fan and everything worked fine.
Your parts are looking amazing as usual. Must be nice to be so close to the finish line.
proffighter 09-05-2023 02:29 PM
Thanks for input. But I had the shorter belt with the stock fan hub as well. so issue is not caused by the custom part. I also checked the alignement (housing pushed forward to transmission side). Fan is also all the way onto shaft (can see through the holes it's touching the big shim behind the woodruff key). so left only to check the diameter of crank pulley.
... Thanks, but close to finish? Not at all (unfortunately or not :D) Thousand of things still in my mind. You'll seeSmileWavy
proffighter 08-26-2024 11:33 AM
It's been a while since last post... However, after I had to glue most of the cork insulation once again as they fell off after a while (dammit self-adhesive quality) it had no motivation there for a while. Now I started to fit the aluminum coated tissue. Unfortunately the one I had 20 years ago was not available anymore, thick and solid but very good to drape. All samples I received where stiff almost like cardboard, impossible to glue in there without wrinkles. At the end I bought the least bad. To have at the beginning a little feeling of success, I started at the top. Went out not bad. Still have to cover the edges, but this I will do as last.
http://forums.pelicanparts.com/uploa...1724696729.JPG
gsmith660 08-26-2024 02:09 PM
I like that
krasuskyp 08-26-2024 07:37 PM
Great to see you back here again Roland - and - that you're still havin at it! Lookin good... keep on pluggin away,,,
proffighter 09-04-2024 04:14 AM
Step by step
Such a time consuming thing, so only little (but at least some) progress
http://forums.pelicanparts.com/uploa...1725448342.JPG
proffighter 09-05-2024 01:06 PM
last update before vacation
http://forums.pelicanparts.com/uploa...1725566532.JPG
The tissue us less flexible and drapable as desired. Therefore I had to make smaller pieces. Left over area in the middle will probably not possible in one piece, at least two I guess. But first I am off for two weeks :-)
proffighter 06-10-2025 07:11 AM
step by step
While I regularly continue, I don't do regarding posting... However here a little teaser about wiring harness (I made all new). Pictures are a bit older, more current will follow soon
http://forums.pelicanparts.com/uploa...1749564636.JPG
proffighter 06-10-2025 07:50 AM
Long time ago (check my thread "another EFI conversion") I mounted a BMC airbox and made air tubing from Filter to turbo out of PE-HD tubes. No issues since, but When remounted the box, I noticed the inlet diameter of box seems smaller than stock. So I measured and found about 80mm against almost 100mm of stock airbox... Furhter I disassembled the BMC CDA box to check the surface size of the cone shaped filter. it's not easy to check surface due the wave shape of filter material l left this out and just looked at surface as it would be flat. So BMC Box seems a little smaller than stock...:(
So easy decision: A bigger box has to be fitted. I bought the same CDA Box but bigger version. In- and outlet 100mm. I did not measured surface yet, but quit bigger than stock for sure.
So beside the box, I have to make the whole tubing new. before it was also 90mm reduced to 75mm after 90degrees elbow before BOV connection (and the bottleneck of less than 80mm at box in and out). Now it will start 110mm at box with little 3D-printed adapter (red), reduced to 90mm until after the BOV. Also I made an additional clamp (nothing like on the market) out of SS to take off some weight from the box. Progress so far:
http://forums.pelicanparts.com/uploa...1749567002.JPG
proffighter 06-10-2025 07:53 AM
Because of the bigger measurements of the new air box I needed to replace the Filter bracket (still the K-Jetronic piece) with a new. Made it out of hight strength aluminum, anodized in black. So a little weight saving too:D
http://forums.pelicanparts.com/uploa...1749567158.JPG
BTW: the stock bracket was drilled already (you know me, don't you :-) )
fourblades 06-11-2025 04:19 AM
Great work as always!
I like the bigger airbox.
Glad to see you back posting.
John
proffighter 06-12-2025 05:33 AM
John
Thank you!
Me too likes box :D
proffighter 06-20-2025 01:13 PM
Today I finished the whole inlet tubing from air box to turbo. First I shorten the silicone reduction hose. Easy to do with sharp cutter on the lathe.
http://forums.pelicanparts.com/uploa...1750450054.JPG
PE-HD tubes "welded" using frying pan
http://forums.pelicanparts.com/uploa...1750450187.JPG
Test fit before final cut's to adjust space between the two pieces where reduction hose will be
final version fits like wanted
http://forums.pelicanparts.com/uploa...1750450318.JPG
proffighter 06-20-2025 01:15 PM
hmm test fit picture lost... so here it is:
http://forums.pelicanparts.com/uploa...1750450510.JPG
proffighter 06-25-2025 01:35 PM
Today I startd with making engine wire harness. To get the right lengths of the cable I made kind of Connector bracket to get the correct position of them similar to engine is car. So it's easier to route the cables and test-fit before mounting pins.
http://forums.pelicanparts.com/uploa...1750883678.JPG
Note: As you can see here, I still will use the spacer to lower the engine. Made this to get the B6 intercooler under the wing. The 965 intercooler is not that thick, so no issue for it. Regardless I like the idea of the lower engine (lower center of gravitiy)
proffighter 06-25-2025 01:48 PM
I just saw that I never posted pics of the finished engine bay heat and noise isolation, so here they are
http://forums.pelicanparts.com/uploa...1750884182.JPG
proffighter 06-25-2025 01:50 PM
one more
http://forums.pelicanparts.com/uploa...1750884609.JPG
proffighter 06-25-2025 01:52 PM
hmm. For some reason 5MB does not work.. So a bit smaller now
http://forums.pelicanparts.com/uploa...1750884750.JPG
proffighter 08-12-2025 01:23 PM
Engine wiring almost finished. this time I decided not to pack every wire into one protection hose I made a couple of them, each function/area has it's one hose. This way it's much easier to have access when needed. I also go without rubber grommet at the connectors. Each wire has a silicon seal in the connector, that's enough. I prefer this, as it avoids water inclusion, same as the protection hose. Wires are FLYY, which ist modern standard (finer strands and pvc covering) ecxept the SDS injecton sensor and injector wires, those are high quality as well and supplied with SDS injection.
http://forums.pelicanparts.com/uploa...1755030140.JPG
proffighter 08-12-2025 01:40 PM
Some more pics
http://forums.pelicanparts.com/uploa...1755031038.JPG
On most pics there are still a lot of cable ties, which I only used to route the wiring and get an idea of the final position. After I fitted only two (bigger ones) in this area
proffighter 09-02-2025 05:23 AM
Because my LH Fiberglass Fan Block-off is quite old and brittle and the RH is still steel I ordered some Sheridans from PP. On the first view, they look quite ok, but when started to fit, they turned out as terrible...
RH needed lot of trimming, but that would be ok, even if I think (as the OEM part fit's really nice and is easy to copy) it could be better from beginning. There are no marks where the mounting holes should be. Also the measurements differ from OEM part, what I cannot understand, no variation needed there. All in all, it's ok, but far away from nice. The biggest issue is that there is way too much epoxy (or polyester) in the inner corners, especially at the lower mounting latch and the inner side of the top bar so you can't get close enough to the engine shroud. about 5mm away. When you tighten the bolts on top, you deform the bar (presses down), so there is alway tension on it (or you leave it loose...)
Will post pics, when both are fitted.
LH has same issues but more than that,the are several angle errors (guess they took out to early out of mold and it warped while harden. Also radius to fan housing is bad and the inner lower area to fan bas has a huge gap. Too much trimming here. Also the area for the bolt to fan housing at the side is to short, not possible to make a hole but only a slot.
Angle issue:
http://forums.pelicanparts.com/uploa...1756815694.JPG
Comparison to old FG piece (which fit's 99%):
http://forums.pelicanparts.com/uploa...1756815763.JPG
proffighter 09-02-2025 05:25 AM
For now, I leave them but will make my own copies with FG myself. As it's quite a bit of effort to make good molds, I'll postpone that...
proffighter 09-02-2025 12:37 PM
Here now some pics installed of LH
http://forums.pelicanparts.com/uploa...1756841840.jpg
proffighter 10-12-2025 11:46 AM
Some more DIY hollow screws and vent line for Wastegate.
Tial screws vs DIY, Stock line vs DIY and mounted on wastegate
http://forums.pelicanparts.com/uploa...1760294629.JPG
Chuloway 10-13-2025 01:52 PM
POR-15 is the real deal, especially on Italian cars they can be notoriously prone to rust. You've gotta follow the instructions to the letter, though, and make sure the surface is properly neutralized before applying it. My mechanic uses it on all the Italian cars he works on and swears by it. You're doing a great job tackling this project
fourblades 10-15-2025 04:18 AM
Some more amazing work!
You are really going all out on the weight savings.
Are you getting close to being done?
John
proffighter 10-15-2025 12:16 PM
John
Thank you SmileWavy
Well the "problem" is, that everytime i made something I see the next part that i can customize or DIY like the vent tube.
One done, another ahead:)
To answer your question: No not close, but progress is there. Engine is beside some little details almost ready to fit in the car.
proffighter 10-27-2025 06:19 AM
After weeks of removing old paint off the intercooler I found time to paint. Looks quite nice to me
http://forums.pelicanparts.com/uploa...1761570645.JPG
It was a big mess to get all the the paint stripper residue from the cooling fins. Multiple bathing in nitrothinner, flush with water and compressed air. Everytime there came some flakes of paint. After about 10 cycles it was done...http://forums.pelicanparts.com/suppo...ys/men_ani.gif
Then next "issue" was right around the corner:
When I bought the fuel lines and fittings at Summitracing, I also bought some alumimum plugs, one for the IC M10x1mm thread... BUT what's wrong with them (the supplier)??? Imperial allen size on a metric thread??? WTF... Now I have to borrow that (in Europe not that common) imperial allen key from somewhere. I am gonna ask on of the muscle car owners here.
LukasM 10-30-2025 08:45 AM
Gotta love the engineers that came up with that kind of specification...
http://forums.pelicanparts.com/suppo...leys/shake.gif
Imperials allen keys are about €10 for a set on Amazon however, even the Amazon basics set is not bad at all. ;)
proffighter 11-16-2025 02:22 AM
To support oil inlet tube I set a Tubtara in the camshaft housing
http://forums.pelicanparts.com/uploa...1763288437.JPG
Test fit, looks fine. Spacer is will be anodized later
http://forums.pelicanparts.com/uploa...1763288524.JPG
proffighter 11-16-2025 02:32 AM
When I did my EFI conversion many years ago I was working at the Swiss VCE Market Company and had access to a huge parts warehouse. There I took the hoses for fast idle valve routing. Those are quite old now and I was not that happy with the layout and valve (way too big hose diameter).
So I replaced this
http://forums.pelicanparts.com/uploa...1763288945.JPG
with this (one side is already machined, as I like it more that way)
http://forums.pelicanparts.com/uploa...1763288982.JPG
both sides machined
http://forums.pelicanparts.com/uploa...1763289089.JPG
proffighter 11-16-2025 02:45 AM
To avoid issues when a hose needs to replaced by exotic hose, I decided to use OE 964 Turbo setup, but with after market silicon hoses (OE is way to expensive)
Set contains too much hoses as 964 Turbo is still with K-Jetronic, but is still much cheaper than buying single hoses.
http://forums.pelicanparts.com/uploa...1763289295.JPG
At that time I made also a manifold inlet port due the different hose size. So I had to make another one to fit stock diameter. Removing the old one went fine,just a litte heat and correct choose of tool
http://forums.pelicanparts.com/uploa...1763289582.JPG
http://forums.pelicanparts.com/uploa...1763289728.JPG
New one
http://forums.pelicanparts.com/uploa...1763289776.JPG
Because the valve is not at the same position as stock (and different layout as well) I had to cut the hoses to fit new valve. Also i made the port longer. This way I can use stock hoses if needed.
And this is the result
http://forums.pelicanparts.com/uploa...1763289920.JPG
proffighter 11-16-2025 02:49 AM
one more pic
http://forums.pelicanparts.com/uploa...1763290136.JPG
proffighter 12-09-2025 12:07 PM
When preparing engine related parts like oil lines to be ready for mounting when engine will be back in car, I rembember that I wanted to replace oil inlet tube (the one replacing the oil cooler) by a lighter one.
Steel version i have since decades
http://forums.pelicanparts.com/uploa...1765310249.JPG
So I bought a aluminum tube with aluminum nut a while ago and thought I have only to cut to the right length and make the pipe bead... But then I realized that the old one (like stock) is 28mm OD while the aluminum one is only one inch/25.4mm...
So how to solve this? I decided to make an adapter sleeve and I made it with ID 25.35mm. This way I could shrink it on the tube and it will sit tight on it.
Heated the sleeve and cooled the tube down. Then quick push the sleeve over the tube before heat transfer.
Done
http://forums.pelicanparts.com/uploa...1765310634.JPG
http://forums.pelicanparts.com/uploa...1765310691.JPG
compared to the old one
http://forums.pelicanparts.com/uploa...1765310734.JPG
And a lot less weight
http://forums.pelicanparts.com/uploa...1765310774.JPG
finally test fit
http://forums.pelicanparts.com/uploa...1765310823.JPG
