-   -   Another rust combat (http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/634616-another-rust-combat.html)
Kozmo930 05-21-2014 07:06 PM
Considering you don't like yellow zinc , can't wait to see the color. Something to match the Blue I'm sure :)
Kozmo
proffighter 05-24-2014 04:30 AM
Started to fit the wiring harness, what a mess. Luckily I record the colors, so I can sort it out:
http://forums.pelicanparts.com/uploa...1400930540.jpg
http://forums.pelicanparts.com/uploa...1400930566.jpg
It starts to look like a car inside slowly but truly:
http://forums.pelicanparts.com/uploa...1400930647.jpg
http://forums.pelicanparts.com/uploa...1400930675.jpg
Also I finished and routed the pumps, fuel lines and oil lines:
http://forums.pelicanparts.com/uploa...1400930861.jpg
http://forums.pelicanparts.com/uploa...1400930909.jpg
http://forums.pelicanparts.com/uploa...1400930936.jpg
http://forums.pelicanparts.com/uploa...1400930963.jpg
I could also remount the rear lights:
http://forums.pelicanparts.com/uploa...1400931038.jpg
Kozmo930 05-24-2014 06:54 AM
Looking good , with a little more time you may be driving this summer :)
Kozmo
speednme1 05-24-2014 07:04 AM
Man that is some awesome progress, is it safe to assume that you roll the car out to work on it or do you do most of the work where it sits...cause it looks like such a tight fit...;)
proffighter 05-24-2014 08:39 AM
If have the possibility to roll out the car, but until now, I did not;)
But as soon the front flares are mounted and the doors are ready to add, I will for sure
GJF 05-24-2014 09:21 AM
Beautiful work!
WinRice 05-24-2014 09:37 AM
Nice, Nice, Nice
That wiring harness looks a little fat, surely there are a few extra wires you can remove?........LOL
6771911esses 05-25-2014 03:35 AM
Somebody hide his drill! LOL
proffighter 06-03-2014 02:28 PM
On my way, nothing is save;)
Present horn, was lighter than stock too:
http://forums.pelicanparts.com/uploa...1401830628.jpg
New one, smaller and I made an aluminum bracket and spacer plus used an aluminum nut as well. Result: Saved another 126gr:
http://forums.pelicanparts.com/uploa...1401830773.jpg
For those who want to know how small, that small:
http://forums.pelicanparts.com/uploa...1401830834.jpg
BTW I have no idea how it sounds, but at least it's street legal and over 100dB loud:D
smurfbus 06-03-2014 09:51 PM
Maybe I should downgrade mine too. I only have one now but it sounds like an T ford and people just laugh when I press it at anger : )
Maybe I should install the ductail to go with it for total humiliation.
Did you search for the weight or just grab one that felt light?
What did you do with the rear lights, the heavy anchors?
jsveb 06-03-2014 10:07 PM
Roland, you are ruthless, fascinating to follow. However, I can help wondering, are stainless oil and fuel lines not much heavier than later style "composite" hose?
Ronnie's.930 06-03-2014 10:23 PM
No need for the composite versions when Ruthless Roland has his trusty drilling rig at his disposal - just Swiss cheese those bit@hes!!! Ohhhh what, then he would have to put catch pans everywhere, and if he drilled those, then . . . . :D
PS: Roland, nice touch with the Barbie-sized horn - sweet as always!!! :D
6771911esses 06-04-2014 02:57 AM
I hope you are using improved aero dynamics to keep this paperweight from blowing around. Oh...have you though about a lightweight bra's requirement for female passengers? Or better yet...no bra's allowed :). Your cars are road taxed by weight right? Do you get a chance to reassess the weight once done?
proffighter 06-04-2014 04:14 AM
I searched for smaller diameter and checked when available weight. At same size they are mostly similar weights, so diameter is all you need to know. Steel bracket is also a factor, so I made one myself
Rear lights are plastic now, look my earlier post about here:
http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/634616-another-rust-combat-3.html#post6517390
proffighter 06-04-2014 04:24 AM
Jesper
Fuel lines are a bit heavier than the PVC ones in the tunnel, but they are not useable with my aluminum fittings and were very old. However I did not have any fitting from pump to pump / return to tank, so this save a bit weight at least. Further all fuel lines are Teflon/SS, so I suggest they are lighter than stock rubber. Aluminum fittings allover help to save weight too.
Oil lines are SS/Rubber because they are "smoother" to route in that size, but of course, Teflons would be lighter. Finally I never saw AN-12 PTFE fittings and hoses...
proffighter 06-04-2014 04:30 AM
Big wing I have:D
My girlfriend actually never wears a bra, seriously! And NO I will not show:p
She weights only about 50kg, what she always is woried not to pass. So she fits my concepts very well:D
Switzerland is very federalistic, every canton is different, in my area it's displacement mainly.
Well even there is no goal I will weight once finished. Problem is, it will take a few years until I am finished, as I have thousands of ideas what to do next...
proffighter 06-04-2014 04:33 AM
...and refill every 10km:D
Sorry, but it's Ken's hornhttp://forums.pelicanparts.com/suppo...ys/men_ani.gif
Ronnie's.930 06-04-2014 09:44 AM
Originally Posted by proffighter (Post 8098326)
Big wing I have:D
Pics? I'm sure that Paul would like to see evidence of yer errrr, "big wing"!!! :D
Roland, you are one VERY fortunate man (and a real a-hole for refusing to post pics)!!! :D
I didn't know that Ken even had a "horn" :eek: - really do learn something new every day!!!! :D
proffighter 06-04-2014 10:42 AM
See post one, not new but still big in my eyes
Yes I know, luck with girl - misfortune with car (sometimes)
Pics? In your dreams:D
Please show me Barbie's then...
proffighter 06-04-2014 10:51 AM
Aaaaaarghhhhhhh
I test fitted the rear bumper today, BUT it won't fit anymore:(
Too wide (or body too small) now, further bolting points are not matching the flares and they did before project. If I mounte the 5 ones below reflector as before, none of the bolts on the flare can be mounted, holes not flushing. If I place the bumber best fit, the holes in the middle won't fit:mad:
http://forums.pelicanparts.com/uploa...1401904228.jpg
http://forums.pelicanparts.com/uploa...1401904260.jpg
http://forums.pelicanparts.com/uploa...1401904290.jpg
I seriously have to talk to the body shop. Fit was way better before!
