-   -   Another rust combat (http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/634616-another-rust-combat.html)
proffighter 09-08-2014 01:11 PM
Thanks guys
My drill is ready for action:D
I am on vacantion from 11th until 20th of September, so you have to be patient for updates here... Maybe if I got a little time before, let's seeSmileWavy
proffighter 10-29-2014 04:27 PM
Finally some news
After my vacation I did not made much, at least not to show, so here the first worth to. To save some more weight, I worked on the doors / window frames:
Drilled, shorten and tappered all bolts:
http://forums.pelicanparts.com/uploa...1414624757.jpg
Lighter version of the glass base, this time all aluminum and Tubtaras:
http://forums.pelicanparts.com/uploa...1414624884.jpg
http://forums.pelicanparts.com/uploa...1414624912.jpg
Window frame assembled, little triangle drilled as well:
http://forums.pelicanparts.com/uploa...1414625062.jpg
Installed with belt (Aluminum nut and bolt hollow drilled:D ) Aluminum bolt as lower stop:
http://forums.pelicanparts.com/uploa...1414625231.jpg
Flieger 10-29-2014 05:47 PM
I love it. :)
proffighter 10-30-2014 10:59 AM
Even a little save is a save... I replaced the steel bolts of the front flasher housing by aluminum bolts. Just drilled out the old ones until the head break, removed the threaded rest and the new ones fitted perfect:
http://forums.pelicanparts.com/uploa...1414691927.jpg
http://forums.pelicanparts.com/uploa...1414691955.jpg
http://forums.pelicanparts.com/uploa...1414691976.jpg
JFairman 10-30-2014 11:49 AM
70's BMW 2002's and the E21 chassis 320i that followed it used plastic thumbscrew nuts on the tail light lense studs that should fit your aluminum bolts. They may be a hair lighter than steel nuts and don't corrode.
pkabush 10-30-2014 01:40 PM
I gotta say Roland, your build is amazing. The sheer amount of fabrication work and the level of detail is astonishing.
I'm sure this has been asked but if so I don't recall. Do you have a target weight your shooting for ? If not any idea on the finished weight ?
Keep up the fine work.
proffighter 10-30-2014 02:08 PM
I will use aluminum nuts here as everytime where not that much strength is needed. But plastic nuts are good as well, will check this as wellSmileWavy
proffighter 10-30-2014 02:12 PM
Thank you for the nice words!
Yes this has been asked before but no problem, long time ago since and goals can change... But as there was none there is still none. I just want to follow my principles and see what I get at the end.
I guess it will be below 1000kg.
proffighter 11-07-2014 06:17 AM
Finally I found time to finish the weight reduction on the seat rails. As they are that beefy, especially compared to the FIA aluminum lateral seat brackets, I had no fear to remove some material here. They still are quite massive:
http://forums.pelicanparts.com/uploa...1415369840.jpg
http://forums.pelicanparts.com/uploa...1415369861.jpg
proffighter 01-08-2015 06:32 AM
Long time ago,but still nothing worth to show... be patient fellows;)
However, does anyone bought or had contact with Patrick Motorsports?
Want to buy an oil cooler from them and asked something using the form on their website, no answer since almost two months now. So I wrote again, but this time an email, no answer either since a couple of weeks... I do not expect immediately answer from small companies and one man shows, but this?
Other here, Brian is quick as hell and is alone too...
lite75 01-08-2015 08:42 AM
Talked to them about a month ago, good guys just busy.
speednme1 01-08-2015 11:26 AM
Best is to call them. James is a good dude. I've visited their shop and have purchased from them.
911-2,8-RSracer 01-23-2015 02:56 PM
Hi Roland,
any news?
proffighter 01-24-2015 03:29 AM
Yes indeed, but not big ones. Made some spacers for the rear swaybar for two reasons:
- My engine is 10mm lower than stock, so tranny was really close to the bar.
- After I made my tranny beam Mark II out of aluminum, it was slightly wider than Mark I steelmade,
so I have to move the bar for that reason too.
And that's the way the spacers look:
http://forums.pelicanparts.com/uploa...1422098644.jpg
http://forums.pelicanparts.com/uploa...1422098680.jpg
Present beam, not anodized yet. I am not sure if I should leave it colorless or go black (tend to black for now):
http://forums.pelicanparts.com/uploa...1422098836.jpg
http://forums.pelicanparts.com/uploa...1422098866.jpg
jsveb 01-24-2015 08:43 AM
I'd go black.
Still a pleasure to watch your progress.
proffighter 02-03-2015 01:11 PM
While I still struggle with the finish of my tranny beam, I spent some time on the starter and anodized the raw aluminum flange to avoid contact corrosion. Further the grey stator housing looked so old I painted in black too:
Short said, only some different color;)
http://forums.pelicanparts.com/uploa...1422997853.jpg
http://forums.pelicanparts.com/uploa...1422997874.jpg
Spenny_b 02-03-2015 03:39 PM
Hi Roland, nice work as always....what brand starter is that? Looks trick
Kozmo930 02-07-2015 08:47 PM
been awhile
Hi Roland had to check in ,been awhile ...busy with life in general
But as usual your car just amazes me :eek: had to go back through some pages to catch up , but "WAY BACK" seen your front coil overs mounted. Wondering how much room you have between your brake line and tie rod arm ? could a 3" hoes fit :rolleyes: ??? I almost have the mock up done in fiberglass for the brake ducs . With my raised spindles I'm running my intake hose under the tie rod arm , but hoping I can find someone here to trial fit some on stock spindle height struts . Made some good mods to them to tuck them in real close and wrap around tube very nicely (not to long not to short) final products will be in carbon :cool:
Keep it in mind , I see you still have some time before you hit the road . I need the swiss watch approval :D
Kozmo
Mxeven 02-08-2015 03:01 PM
Hi Roland,
Looks great as always! I like following your thread and check in for updates. I admire your dedication to reducing weigth, it will be exiting when you put it on the scales once finished.
Just a suggestion about the starter bracket, remember that the starter grounds through the bracket and the anodizing isolates the starter from the gearbox. So you need to ground the starter in some other way or remove some of the anodizing to create contact. Saves a lot of tears when trying to find out why the starter does not work :).
proffighter 02-11-2015 04:05 AM
Kozmo
Kozmo
May you post a pic what measurement exactly you want, so I will check for you
