Great topic! like to see more of your progress.
I wish I had a friend like you ... a lot of people are looking up to you! |
You're right, I have RarlyL8 Headers without heat. The heater can be regulated. It's heating performance is 2500Watt, so enough to not have cold and defrost the windows. I doubt if it's enough for deep winter, especially as my car has no isolation etc... But maybe in a stock car it would be ok. It's a Eberspächer B1LC Compact, watch my thread too: http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/566192-gas-heater-installation.html http://forums.pelicanparts.com/uploa...1353970410.jpg |
But maybe I am the only one with the same girlfriend since years:D |
One more item done
Today I anodized the two parts I made earlier this week on the lathe for the trunk lock
A few gramms less here too http://forums.pelicanparts.com/uploa...1354147189.jpg http://forums.pelicanparts.com/uploa...1354147220.jpg Notice: I left the base plate and the rod stock (besides drilling), as they have to take quite a certain amount of load |
you made those 2 Al pieces on the latch?
Some more parts anodized, fuel line banjo and selfmade plug for oil tank (aluminum instead of steel)
http://forums.pelicanparts.com/uploa...1354658018.jpg |
Body shell rust removal
In the UK we have a company who get rid of all old paint and rust by immesing the shell in a tank of chemicals and then after repairs will dip the whole shell in a protective primer which will be much better than any body shop could do.
Technical Process for Paint Stripping, Rust and Underseal Removal for Cars and Industry from Surface Processing Limited I have no relationship with the company but they might get my Austin Healey body when I finish my house building |
Hi Roland
It`s a nice Project from You with many interesting details! |
After I asked about the need of check valve at front pump here
http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/717638-efi-fuel-system-question.html I decided to make one out of aluminum, went out very nice. Was a bit time consuming and I screwed up the first nut (cutting thread was not perfectly angeled), second one was fine. I fitted the stock valve inserts (rubber ball, spring and spring seat), so it's an more or less exact copy of the stock one. http://forums.pelicanparts.com/uploa...1354913786.jpg As the banjo and hose endings are black, I went without coloring this time |
Roland, that is absolutely sweet.
I need one of those end caps as I have just installed a 044 pump in my Carrera 3.0 I wish I had your machine shop :) Keep it coming, it is very inspiring. |
This cap is available from our host, mine is priceless;) look here: http://www.pelicanparts.com/cgi-bin/smart/more_info.cgi?pn=928-110-475-04-M100&catalog_description=Cap%20Nut%20%28M%31%32%20 X%20%31%2E%35mm%29%20%39%31%31%20%28%31%39%37%38%2 D%38%39%29%2C%20%39%31%31%20Turbo%20%28%31%39%37%3 8%2D%39%37%29%20 |
I saw someone drilling his Hargett shifter and I looked at mine and thought:
"Why not":D As it is very massive there is no risk in my eyes to save some weight here too. Here is the result then: http://forums.pelicanparts.com/uploa...1355608068.jpg http://forums.pelicanparts.com/uploa...1355608102.jpg As it is Christmas soon, I made a unique key chain out of aluminum, anodized of course as usual;) BTW it represents me, only my GF knows why... http://forums.pelicanparts.com/uploa...1355608315.jpg http://forums.pelicanparts.com/uploa...1355608351.jpg |
Received some pics from body shop. Could be worse. I bought another 930 body with A-pillar / front crash which is in excellent condition. complete rear section including torsion tube will be replaced by donator body. Front section is about 1cm out of spec, see pic
http://forums.pelicanparts.com/uploa...1356082669.jpg http://forums.pelicanparts.com/uploa...1356082688.jpg http://forums.pelicanparts.com/uploa...1356082704.jpg http://forums.pelicanparts.com/uploa...1356082743.jpg |
Love the mad attention to detail! In the above pic, is that jig for a 911 or 930? The front rack mounts on a 930 are higher than a 911. |
Keychain is Sweet...tail should double as a bottle opener?
Yes they are higher, but here you see LH, RH is sitting on the jig... Whole front is a bit missaligned. But nothing which cannot be solved! |
| All times are GMT -8. The time now is 04:49 PM. |
