-   -   Another rust combat (http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/634616-another-rust-combat.html)
totle 12-21-2012 01:19 PM
Wow Roland.
You are really stripping that chassis down.
And all the details and great work. Nice thread to follow.
proffighter 01-11-2013 12:45 PM
Today I visited my body shop to talk about details, how to go on with the car. you can see how heavy the impact on the donor car was on the RH.
As my car has a lot of deformation, we decided to cut away much more than decided earlier. You can see the roof and rear section, which will be used. Further the outer rear wheel well are open now to see the condition and make some changes.
http://forums.pelicanparts.com/uploa...1357937015.jpg
http://forums.pelicanparts.com/uploa...1357937046.jpg
http://forums.pelicanparts.com/uploa...1357937096.jpg
http://forums.pelicanparts.com/uploa...1357937134.jpg
boostfix 01-11-2013 12:49 PM
Looks like you are the Swiss version of Holmes on Holmes but for Porsches not houses......"making it right!"
Looking good Roland.
proffighter 01-12-2013 05:11 AM
new weight saving:
Oil plug of tank (still with magnet:) ) I switched from wrench size 15 to 17 for less risk of damage by wrench and choose measurement a bit closer for less play to wrench. As oil tank is black, I anodized plug too in black.
http://forums.pelicanparts.com/uploa...1357996178.jpg
http://forums.pelicanparts.com/uploa...1357996208.jpg
http://forums.pelicanparts.com/uploa...1357996278.jpg
http://forums.pelicanparts.com/uploa...1357996306.jpg
MikeD930 01-12-2013 01:15 PM
Wow...your car is cut up! Looks like it will be much straighter once everything's done. It seems you have a lots of free to drill out everthing, anodize and now you made a custom drain plug! Nice!
proffighter 01-13-2013 03:07 AM
No I am working 40hrs a week as most others too, BUT I am not married:D
BTW, a lot of parts I anodize are custom made or at least machined by myself
proffighter 01-14-2013 09:50 AM
Share your expirience please
As I do not need heat piping in the rockers anymore, I want to remove them too.
My goal is to remove them at least from rear to the door rest/ A-pillar area like on pic. Is there any downside you made bad expirience. Some structural strength doubts maybe?
Does anyone did this before?
http://forums.pelicanparts.com/uploa...1358185831.jpg
Ken911 01-14-2013 06:24 PM
well for the sake of the person you eventually sell the car too. thats one thing i would leave in because it cant be undone with out cutting the car back open.
proffighter 01-15-2013 12:26 AM
Not in this life:)
Well, there is everything else missing too, from heated headers to the controls (Black box and in dashboard), piping etc...
Tom Sch 01-15-2013 01:04 AM
hello,
cut it out!
the pipe is not so easy to remove, except you have all other things cut out first.
we have done this on my yellow car - see the elferteam forum ;)
Ronnie's.930 01-15-2013 08:17 AM
Originally Posted by proffighter (Post 7209001)
Not in this life:)
And you use a gasoline heater in this car, right?
proffighter 01-15-2013 12:06 PM
Correct, why?
See my thread about gas heater here:
http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/566192-gas-heater-installation.html
Ronnie's.930 01-15-2013 12:23 PM
Originally Posted by proffighter (Post 7209884)
I just meant that given your means of heat, that car doesnt't need the OEM side tubes.
proffighter 02-02-2013 05:13 PM
On my way to save weight, I worked on the throttle linkage since a while. All parts, except two ball joints are made of aluminum and anodized now, even the hex nut:)
Bracket went dark in cause of it's magnesium alloy, it's anodized colorless.
Further I anodized the brackets for MAP sensor and idle valve and the cap to close the cold start valve hole which I made at my EFI conversion...
http://forums.pelicanparts.com/uploa...1359853841.jpg
http://forums.pelicanparts.com/uploa...1359853980.jpg
herman maire 02-02-2013 06:16 PM
so you can anodize magnesium ?
again, really nice work. The amount of time your spending on all these details is very impressive.
proffighter 02-03-2013 02:01 AM
Thank youSmileWavy
Yes, I can anodize magnesium. Why not? Anodizing works for aluminium AND magnesium and titan.
I don't know the alloy of that bracket. Because I machined it a few years ago and sandblasted it without any coating after, it went dark after some time. This let me think of a high magnesium percentage. Further the bracket i lighter than expected. I saw newer ones, which are different material for sure
proffighter 02-06-2013 09:34 AM
Today I visited the body shop to see, how it's progressing:)
New rear section is fitted, several areas replaced by repair panels and some deformed areas are now flat as new. All chassis checkpoints are now in spec. Next will be A and B pillars "adjusting" to fit door (as the were cut) and adding some reinforcements to avoid cracks due coilover suspension
http://forums.pelicanparts.com/uploa...1360171880.jpg
http://forums.pelicanparts.com/uploa...1360171908.jpg
http://forums.pelicanparts.com/uploa...1360171935.jpg
http://forums.pelicanparts.com/uploa...1360171969.jpg
http://forums.pelicanparts.com/uploa...1360171994.jpg
http://forums.pelicanparts.com/uploa...1360172040.jpg
http://forums.pelicanparts.com/uploa...1360172072.jpg
boostfix 02-06-2013 12:18 PM
......now that has to make a guy feel good! :) Looking good Roland.
911 tweaks 02-06-2013 12:32 PM
great progress Roland...keep her rollin'...
proffighter 02-11-2013 02:47 PM
Huge weight saving!!
I made a new fuel door lock and saved unbelievable 26gr ;)
http://forums.pelicanparts.com/uploa...1360622664.jpg
http://forums.pelicanparts.com/uploa...1360622699.jpg
Further I saved a few gramms with drilling and machining the locking plate, here is the complete unit:
http://forums.pelicanparts.com/uploa...1360622785.jpg
http://forums.pelicanparts.com/uploa...1360622811.jpg
