LinkBack Thread Tools Rating: Thread Rating: 3 votes, 2.33 average.
Porsche Crest 1985 3.2 Carrera turbo build
Hi there,
I'm reading alot on this forum and finally decided to turbo my beloved 1985 3.2 Carrera Targa.
its my first Porsche and owned it now for about 3 years.
My game plan :
ECU VEMS thx @Raceboy
Pulsar GTX 3584RS 0.63AR
Oil feed from Turbokraft
930 J pipe
Custom Exhaust with center outlet
Tial F46P wastegate with 7PSI spring
Siemens Deka 630cc injectors
Small intercooler to fit under the original bonnet
2.5" piping (ebay special)
I might add a 4 port boost controller to manage the boost (not sure yet)
Wish me luck, will need it
if anyone wants to follow on IG : 85_9_1_1_
the car :
The engine atm:
Old 03-17-2024, 12:35 AM
Chain fence eating turbo
You’ll start out at 0.5 bar, but 1.0 bar is where the party really starts. It’s addicting. I’m up to 1.4 now and have ran 1.5 before for fun. Tires must be good or no traction at that point.
Old 03-17-2024, 07:26 AM
With stock internals ? Have a topic of it ?
Old 03-17-2024, 07:58 AM
I have Mahle forged pistons but stock rods and crank except ARP rod bolts.
Old 03-17-2024, 06:02 PM
Jeff Alton's Avatar
We ran our last 3.2 turbo conversion at .6 bar, with an intercooler.... There is tons of more safe power there, but client thinks it has pleny of power as it is....
Cheers
www.turn3autosport.com
Old 03-17-2024, 07:21 PM
First step in the build was to fit the turbo and fab the j pipe ...
So that the turbo goed trough the hole in the tin ..
Some pics :
Now the original exhaust goes back on, car to my garage to start the conversion.
Old 03-21-2024, 04:28 PM
bleachii's Avatar
Kind of sleeper. Kind of not.
'79 930 Minerva Blue/Cork
'98 993 Cabriolet Glacier White/Midnight Blue
Fire - '91 C2 Targa Black/Tan
Old 03-21-2024, 05:01 PM
well, the car is almost finished, i need to install the ic but is is running awesome atm..
0.5/ 0.7 bar boost .
I want to thank @raceboy espacially for taking the time to tune the car and have the patience for all my questions.
some pictures :
Old vs new (deka 630cc injector)
Vems stealth unit in place
Check valve inplace, removed venturi for brake booster
intake breather hose replaced by this small breather/filter
injector in place
Vacuum line(wastegate)
Backside view
Old 04-27-2024, 06:13 AM
wastegate + screamer pipe
sideview off the turbo intake side
Oil feed line going thrue the tin
Oil feed line hooked up-turbokraft (awesome quality) you need the 930 adapter to engine block to install this (expensive thrue turbokraft but ordered one online)
engine view
Turbo sitting nicely thrue the hole in tin..
Small video :
https://www.youtube.com/watch?v=tYR_itnbr-4
Old 04-27-2024, 06:21 AM
How did you attach intake to throttle body and plumb the idle valve?
Always learning.
www.aircooledporsches.com.au
See me bumble my way through my first EFI and TURBO conversion!
https://youtu.be/bpPWLH1hhgo?si=GufVhpk_80N4K4RP
Old 04-27-2024, 06:42 AM
Hey Michael, i attached it using a 90 degree elbow reducer.. 83mm to 63. Idle valve is plumbed with a quick tap 20mm connection.
Btw guys, Michael here is truly a man with many knowledge, he has answered many questions that i had. He was helpful to me .
Old 04-27-2024, 03:24 PM
Turbonut
Raceboy's Avatar
Nice to see your car running great! Couple of observations though: first thing you should install proper air fitler Not only due to dust entering engine (and severly reducing engine life) but the mesh actually flows worse than air filter.
And secondly definitely proceed with intercooler install, intake temps will be skyrocketing when true summer arrives.
May I ask why you removed brake booster check valve? Boost should not enter the booster..
'83 924 (2.6 16v Turbo, 530hp),'67 911 hot-rod /2.4S, '78 924 Carrera GT project (2.0 turbo 340 hp), '84 928 S 4.7 Euro (VEMS PnP, 332 HP), '90 944 S2 Cabriolet
http://www.facebook.com/vemsporsche
Old 04-29-2024, 03:11 AM
Calm Peep, calm 😉
Brake booster is not getting any boost thats why i installed a check valve it flows towards the engine not away from it .
Old 04-29-2024, 03:19 AM
I think we need a longer video and maybe some in car footage!
Always learning.
Old 04-29-2024, 05:29 AM
Thanks for sharing. I’m at 1 bar with conservative timing and it’s a blast to drive.
Old 04-30-2024, 05:30 AM
Update:
Old 06-27-2024, 01:29 PM
Brando
quattrorunner's Avatar
Fun! But watch your intake temps
Turbo powa!
1977 911s. it's cool
Old 06-27-2024, 05:23 PM
greglepore's Avatar
Yeah, that IC is pretty small for .7. I get that it fits under the stock lid. Nice install though.
Greg Lepore
85 Targa
05 ST3s (unfinished business)
Old 06-28-2024, 04:31 AM
would 2 small fans help with IC/intake temps
Old 06-29-2024, 07:18 AM
