I have a stroked motor to 3.5 with 8:1 on CIS with a meth injection kit and I run 16lbs booost with no problem.. with plenty of fuel.. Motor runs so good and no issues so I dont even think about efi the motor..
Jakob |
N.A. is not a vacuum, it is pressure - atmospheric pressure. Following your logic where should one stop at C.R vs. boost? Why not go to 11.5:1 and boost it to kingdom come....absurd? yes. You get my point? Besides intake manifold pressure is not the absolute measure of power. Regarding the chart it has several data points of interest known to many on this site. Both Les-garten and Don E are modern fully built 930 based motors and each is at the edge on pump premium with 12.5:1 effective C.R. Last edited by copbait73; 12-10-2011 at 06:00 PM.. |
Now you make me laugh....sorry...Come on....talking NA on that chart just expose yourself… Atmospheric pressure is 14.7 psi at sea level....you are talking funny stuff in all different directions...to follow your thinking on this matter you would need to draw yourself a nice chart-painting... put 14.7 psi for sea level in the middle of the y-axe and then paint mountains on top and deep canyons beneath that … only then your argument makes sense and you get reference points to plot from. You are wasting time. Sorry. You can get absolutely ZERO out of that specific boost chart for NA. It tells you have understood very little about CR. If you really think so, and serious, then please…… try and write a post here to us all describing how to determine CR on a NA build application from that specific boost chart... I will read it!
Back to reality on this thread ... Time has moved on and what 35 years ago was 6.5-7.5 in CR is now days 8.0:1 > 8.5:1 > 9.0:1 with EFI (two valve twin plug depending on application). Back then some also learned that cooling inlet charge air could improve combustion control and CR and porsche started using intercooler OEM and left CR 6.5/7 behind. Yes, believe it or not a "CR milestone" was moved forward. We are now in 2011. Among others we now have EFI at our disposal. To me you clearly haven't understood what has moved and limited CR TODAY with proper EFI tuning and ignition setup. That is why you IMO are off target and back in history in your answer to this persons question in regards to EFI + Twin Plug = CR. Anyway looking much forward to a “in depth” description from you how you use and determine CR on a NA engine builds from that specific boost chart...maybe you could post that picture with reference points to the y-axe. |
Inspiration for your mountains Y-axe painting - Look at this video The BEST rally video you will ever see(No music, RAW sound) - YouTube
That is pikes peak 0-4000m That ECU has 1 bar internally atmospheric pressure sensor mapped to correct ignition, fuel and boost on its way to the top (by the way +2 bar forced induction) Such internally 1 bar atmospheric pressure sensor is standard in all professional aftermarket ECU EFI today for such use among others. |
I know what altitude is, I lived the entire month of August working turbo issues at 4300METER in the Antamina Mine in the Peruvian Andes. Look it up. I didn't go 4300M on YouTube, I lived there. Take the time to open your mind and read the chart. Pressure is pressure, this chart starts at atmospheric pressure so it is valid to set N.A. engines on the bottom line. By doing this you have additional data points reflecting the effective compression Porsche found gives reliable engine usage. It shows gains made by their addition of EFI, knock sensors, CHT and twin plug. Besides there are some on this site who know boost isn't everything. They set their intake pressure at a reasonable level then start working down exhaust backpressure and intake manifold temperature. This is the correct method of producing reliable turbo power. EFI has it's place but better spark advance and A/F ratio control cannot replace inadequacies in the basic engine architecture and systems. |
Now you go the funny direction again. Now you say you work in a Mine and argument that this chart tells you how to set CR 4300m beneath sea level on what would be expected to be industrial turbines. I dont think any porsche ever been down there or set up as turbo engines in Mines. Or do you have a NA race track down in that Mine? Totally BS.
By saying so you leave out that no NA Porsche is ever driving above sea level AS no less than 14.7 psi is on that boost chart. That is why I asked you to do the painting. I repeat, no less than 14.7 psi is on that boost chart. Go figure... Going up hill means less than sea level atmospheric pressure (and big surprise it is not figured on the chart) As 99% of all roads are above sea level it equals quit easy up that you are talking diffuse BS and Porsche did not make that boost chart for you to plot NA engines as answer to CR on forced induction application. Now please I kindly ask you again....do the magic and try and show us all in a post how you would plot on the Y-axe for NA engine above sea level. Show us... |
Crotchety Old Bastard
A little background info; copbait has a lifetime of experience as a turbo engineer for one of the most prolific turbo manufacturers on the planet. The chart applies to the basic technology of the engines' 40 year old design. It's a great tool. I think the point copbait is trying to make is you can throw all the EFI technology you want at a 40 year old engine design and it won't do a thing to change the basic design contraints.
RarlyL8 Motorsports / M&K Exhaust - 911/930 Exhaust Systems, Turbos, TiAL, CIS Mods/Rebuilds '78 911SC Widebody, 930 engine, 915 Tranny, K27, SC Cams, RL8 Headers & GT3 Muffler. 350whp @ 0.75bar Brian B. (256)536-9977 Service@MKExhaust Brian@RarlyL8 |
R.I.P.
I hate to hear " it can't be done". The person making that statement assumes he knows everything which in turn proves he knows little. I respect the thoughts and opinions of everybody on this board, but forward thinking is what pushes technology not looking back |
@Copbait... that was expected
The point is -> You can NOT use that boost chart to determine NA CR applications. Period. And second, that chart is for ooooold veteran forced induction setups. This post is (or was) about EFI + Twin plug. CR are not to be compared when using such different instruments to control detonation. Totally different ball game! @Copbait.. quit the funny talk ... you now ask for others background before you expose the NA nonsense futher. I have (just as many others) a long history within NA and forced induction both commercial and in practice and besides that, articles (not in english) and speaking of CR ... I did a "Configurator" to easily set up individually ignition startup maps. It has it purpose to drive from EFI garage to the dyno/bench for tuning against MBT. It has been used and proved working in real life by EFI customers, competitors and users on EFI forums for many years (http://powerpage.dk.web26.wannafindserver.dk/tuning_ignition-filer/Ignition_timing_konfigurator_opstartsmap_v106.xls). You wont run "dry" on experience here. Try and get serious - Just try do the chart plotting of an real life "above sea level" NA on that boost chart. Jakob Last edited by JakobM; 12-11-2011 at 01:43 PM.. |
I don't think anyone said "it can't be done". There is a big difference between "can't be done" and "probably shouldn't be done if you expect your engine to live a long life".
I fail to see how EFI is going to change the piston/head design on a 930 or turn air cooling into water cooling. Those are the design constraints I am talking about. Jakob you are probably not going to get an answer. One of the things that is great about this board is that most folks are not hostile or confrontational. That type behavior runs off good folks who are long on knowledge and short on patience when it comes to abuse. They share what they know as a courtesy and have no reason to stay and take any crap. Everyone has the option to take the advice or to not.
Brian, what usually is so great about this board is non-confrontational knowledge sharing where no one is placed on a statue spreading repeated mistakes without people at some point start question it. It might be (not intended) understood as confrontational from those seeing them self up on such statue.
I agree on focusing on backpressure rather then manifold inlet pressure, temperature etc. I personally look at and plan forced induction engines as near NA setups as possible in order to have the boost vs. backpressure positive. Only by that you have an effective reliable and "cold" running turbo engine. That is why you should never build your twin scroll manifolds with one open wastegate due to backpressure issues on cam overlab (I know you offer two seperate WG solution and looks good). Anyway...to say one can determine CR on a NA engine from that boost chart is nonsense. My posting ends here with the requested NA vs. pressure plot on that specific boost chart above sea level. It will expose no way possible and the talking nonsense in regards to that specific argument. It is very simple and easy, just try and plot it...nothing confrontational in that. To get "back to the future" on track on the original CR twin plug efi question -> this thread hold most of the simple answers and opinions to that question by now. If you want to study further about using full potential of squish design, then there is respectable books available out there about squish and combustion behavior controlled by modern engine management. Last edited by JakobM; 12-11-2011 at 06:28 PM.. |
1986 911 Turbo 3.3L, K27HFS, Tial 46mm, TurboKraft Intercooler, 964 Cams, Monty Muffler, MS3Pro Evo, M&W Ignition, Zietronix WBO2 Data Logger, Wevo shifter, coupler and motor mounts. |
IMO 8.5:1 is safe under normal circumstances for this 3.0L 95mm bore twin plug + EFI
Sorry guys, I didn't mean for this to become a full on argument. I was just after some opinions from people who've BTDT
![]() I think what we'll do is start with wastegates preset with 0.8bar springs, and then use the Engine Management System to regulate the boost up to the highest and safest limit to see exactly where it's happiest at 98 Octane. I would think with twin plug, full bay IC, and very fine/granular control over the fuel and ignition maps, we should be able to push it to ~1.0 - 1.1bar at that CR whilst maintaining excellent pre-boost responsiveness. Thanks for ALL your input and advice. |
Max Sluiter
According to Car and Driver's cutaway of a modern Hemi, Chrysler looked to a 993 for head architecture.
1971 911S, 2.7RS spec MFI engine, suspension mods, lightened Suspension by Rebel Racing, Serviced by TLG Auto, Brakes by PMB Performance |
Smart quod bastardus
Fredmeister
1979 930 Turbo....3.4L, 7.5to1 comp, SC cams, full bay intercooler, Rarlyl8 headers, Garret GTX turbo, 36mm ported intakes, Innovate Auxbox/LM-1, custom Manually Adjustable wastegate housing (0.8-1.1bar),--running 0.95 bar max ---"When you're racing it's life! Anything else either before or after, is just waiting" |
Metal Guru
1. Cylinder head design - on the "33 year old" 911 engine, there is a spark plug off to the side so the flame front has farther to travel, not much quench (squish) area so swirl during compression isn't the best and an intake port that doesn't swirl real good either (that's why there's bowl pistons in the SC/Carrera n/a engine). 2. Fuel - a higher octane rating is a measure of a fuel's ignition temperature. Higher ignition temperature is better because it's the end gas (an ever-changing fraction of unburnt gas during combustion that's being squeezed by the combusted gas, changing chemical composition and becoming a compound with a lower ignition temperature) that will auto ignite and damage the engine. 3. Combustion chamber heat rejection - not the best on an air cooled engine; certainly not in the same league as a water cooled engine. and way down in 4th place is EFI. EFI will allow tuning very close to the ragged edge of detonation, closer than CIS, but it's ability to allow a cylinder head that was designed without the aid of CAE to run compression ratios seen on contemporary engine designs is just about nil. Since we're discussing dynamic compression ratios on 930 series engines, the chart is valid IMO. Stray from it at your own risk.
Paul B. '91 964 3.3 Turbo Port matched, SC cams, K27/K29 turbo, Roush Performance custom headers w/Tial MV-S dual wastegates, Rarlyl8 muffler, LWFW, GT2 clutch & PP, BL wur, factory RS shifter, RS mounts, FVD timing mod, Big Reds, H&R Coilovers, ESB spring plates- 210 lb |
I've heard Juan Ruiz runs 1.4 bar+ on his Carrera motor with 930 P&C's. He's way off the chart
![]() I've run 1.25bar on my turbo Carrera with 930 P&C's too! |
