82 930
Loud noise on higher acceleration
Guys, I have a stock 82 930 that is making a loud noise when accelerating above 4000 rpm. Is this the way the car is supposed to sound when really stepping on it? If I accelerate slowly and let the rpms climb slowly, it doesnt make this noise. Also, no noise present when in Neutral either. It looks like there is/was some rubbing going on and I was wondering if this could be the noise? Thanks, don't have much experience with these cars so wasn't sure if this is just how it sounds or not. If its normal, what makes this noise?
Old 12-10-2011, 10:53 AM
oilonly's Avatar
Is your airconditioner pump and bracket bolted down good?
'87, Modified WUR, Billet valve, 965 downpipe, Kokeln intercooler, GHL headers, Garrett T04B K27 hybrid, Tial w/.8 bar, WEGO IV, RarlyL8 dual out, LSD
Old 12-10-2011, 10:57 AM
mark houghton's Avatar
Would be happy to help, but you need to be a little more descriptive on what the loud noise sounds like. Is it like an exhaust roaring noise, metal on metal, knocking noise, squealling noise, whatever.
Mark H. 1987 930, GP White, Wevo shifter, Borla exhaust, B&B intercooler, stock 3LDZ.
Old 12-10-2011, 11:29 AM
82 930
Well, I found a screw is missing from the coil... Although it seems pretty tight, I can move it a bit. The pump is solid. Is this coil for ac only?
82 930
It's a quick, deep flapping noise...kind of like a kids noise maker that you spin on a stick? I'll try and post a video, thats a pretty lame description. Is there a valve that could be struggling on an air intake somewhere?
Old 12-10-2011, 11:39 AM
jsveb's Avatar
Maybe a stupid suggestion, but could it be the waste gate that's opening. The way you describe it, it seems to be when the engine is
Loaded, boosting.
Old 12-10-2011, 11:48 AM
82 930
Jsveb,
That's when it happens, pedal slammed down hard.
Old 12-10-2011, 11:59 AM
Wayah Road Warrior
Shadetree930's Avatar
Is the noise coming from the left rear side?
02 996tt White
87 930 GP White (Sold)
87 911 Targa Guards Red(Sold)
Old 12-10-2011, 01:26 PM
jsveb's Avatar
If not the WG, then maybe an exhaust leak that becomes audible when exhaust pressure builds under load.
I believe a single cyl could create what may sound as a flapping kind of noise.
Old 12-10-2011, 02:13 PM
82 930
I don't believe it's coming from the bottom left, sounds like it is coming from the top vents on the tail possibly? Can i see the waste gate from underneath the car, where is it located? Newbie guys, sorry. I have to say, it's actually sounding better now. I took it out last eve, filled the tank an added som octane boost. Drove it pretty hard for about an hour. The car sat for 5 years with maybe 500 miles driven over that time. The more I run it, the better it is sounding. I do have a faulty tach now too, looks like a windshield wiper when I let up on the gas. Time for a new one, of just a loose connection?
Old 12-11-2011, 11:33 AM
j930's Avatar
check the silicon or whatever the material the boots are that sleeve the turbo to the intercooler. THe 4000 rpm makes me think its the turbo? I know lsat year when the mechanic put everything back together he had the bot a bit crooked and it left a small gap where it connect to the up pipe to the intercooler. he had tightened the clamp down and on the back side of the sleeve it was pinched. or maybe your sleeves are shot? just a idea.
84 930 Slant
15 Sonata 2.0T
08 Ram 1500
15 Ram Eco Diesel
Old 12-11-2011, 01:07 PM
Banned
The tac needle bouncing like you describe is a classic symptom of alternator/voltage regulator problems . . . you need to measure the outout voltage with a multimeter at the battery (should be around 14 volts with engine running) . . .
Old 12-11-2011, 01:40 PM
82 930
Ok, the noise I had mentioned is definitely a rattling noise for sure. I'll keep you posted, going to break out the tools finally.
Old 12-17-2011, 07:30 PM
With your tach symptom, I'm guessing the rattlin noise may be a bad alternator bearing (although a bad bearing itself wouldn't normally be associated with tach problems, but a bad regulator will). Pull the belt off, see if you can wiggle the fan. If bad enough, it may be contacting the fan housing. Just a thought....
Old 12-17-2011, 08:12 PM
How much boost are you running. Has the timing been checked? Detonation
maybe ???
Cole
Cole - 80 930 "The Old Sled"
Mods: TurboKraft Custom IC, 934 Headers, GSX 61, Zork, Port Work, SC Cams, Air Mod Fuel Dist Relocated, Water Meth Injection, BL WUR, MSD 6530, Greddy EBC, Synapse Bov, Short 2nd & 3rd with 8:37 R&P, Wevo Shifter, Coupling, and Mounts, MTX-L SSI-4, Big Brakes, Rebel Coilovers, Bilstein Sports.
Old 12-17-2011, 09:02 PM
82 930
Same car, another problem. The steering is locking up on low speeds on hard right hand turn. Any ideas? Also, when removing key from ignition switch, steering wheel does not lock. Thanks for the help guys, Merry Xmas.
Old 12-24-2011, 05:54 PM
totle's Avatar
Could it be worn out gaskets for the BOV housing?
This is a plastic gasket that tends to crack and would give a ratteling sound
Look at this thread for more info
Bye Bye Clicking Sound..A Slow'N'Rusty Pictorial - BOV Housing
Trond R.
1979 930: Garret GT35r turbo, EFI, carerra intake, Link EMS, custom GT2 cams, 98mm JE P/C, 964 crank (stroker), custom valves & ported (XtremeCylinderHeads) etc..etc..
1972 914-6 GT replica project
1986 944 Turbo
Old 12-24-2011, 08:00 PM
82 930
A quick update.
I'm not sure how much boost the car is running yet, I should probably take it in to find out because the boost guage is not registering at all either. The tach is operating fine now after I spent some time tightening up wire connectors, fuses,etc. I haven't had the timing checked either, I don't know to do this myself and need to save up $ prior to having someone really go through this beast. However, per j930 suggestion I checked the seal to the intercooler and noticed it had been installed incorrectly. I will reinstall this weekend and try to line up correctly. But... I also noticed quite a bit of oil was on the pipe connecting the IC and covered all over the turbo? How common is this issue, what causes it, and am I damaging anything by driving the car hard/or at all? Sorry for the rookie questions' guys, I appreciate the help!
Old 02-20-2012, 12:55 PM
oilonly's Avatar
No that is not normal looking plus the bottom of your turbo has an oil leak problem from the looks of it. Maybe the feed line going to the turbo or the line coming from the turbo to the catch can is leaking at the very least. Or oil is getting into the cold side from a failed seal in the turbo at the worst.
Old 02-20-2012, 04:28 PM
82 930
Thank you, I've been sorting out all sorts of things, mostly electrical, and finally about have it licked...such a shady rats nest of wiring! Who does this ****?
Old 03-05-2012, 06:04 PM
