can I use this gauge to test WUR.....
Hi guys
can I use this gauge to test WUR, or do I need the more expensive type
Old 02-12-2012, 06:38 PM
jsveb's Avatar
I think you need a gauge that you can hook up in-line with the wur and the fuel head.
You also need to be able to close the valve from the gauge to be able measure system pressure.
That one look neat though. Where to buy?
Jesper
Carrera 3.0 1975
930 1978 OEM Matte Schwartz, ANDIAL IC, BL WUR, SC cams. LMA-3 w. XD-16 and CP transducer
www.stauningwhisky.dk
Old 02-13-2012, 08:22 AM
Tinkering Pays!!
mooney265's Avatar
Unwired Tools has that...
LIVN80S - - Red '79 Porsche 930 Steel Slant Nose Conversion [in 1987] w. 46k miles 3.3L; 964 Cams; K27HF @ 1.0 BAR, with Garrettson Intercooler; Rarly Zork; CIS Flowtech Fuel Head & BL-WUR.
Old 02-13-2012, 05:45 PM
That is where it is from at only 45 $. Needed to know if i could use to adjust the wur
Old 02-13-2012, 06:00 PM
mark houghton's Avatar
I believe you can hook that gauge in one location or the other, to read either system or control pressure, but not both at the same time. Seems I've seen a picture or two of similar guages being installed permanently on the WUR.
Mark H. 1987 930, GP White, Wevo shifter, Borla exhaust, B&B intercooler, stock 3LDZ.
Old 02-14-2012, 05:40 AM
Certified User
billjam's Avatar
I bought a few fittings, a valve and gauge and put this together. You need to be able to close the valve to measure system pressure. Cold control pressure is measured with valve open.
It's all in the manual, but if you want something easier to follow, I can email you my version of an idiot's guide to measuring fuel pressures and flows.
Bill
1988 Carrera - 3.6 engine with ITBs, COPs, MS3X
2024 Macan S
Day job ... www.jesfab.com.au
Memories: '68 912, '72 911T, '80 911SC, '84 911, '85 930, '86 930, '87 911, '21 Macan S
Old 02-14-2012, 06:02 AM
