-   -   Information about the 934 CIS Injection (http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/665600-information-about-934-cis-injection.html)
Grupp-A 03-14-2012 06:21 PM
Hi there!
Iīve read some posts here and I can see great interest in the 934 race cars CIS system and some frustration due to lack of information so maybe I can give you some help.
The system are race parts from Bosch motorsport. Usually Bosch product numbers starts with a "zero" but motor sports products and prototypes starts with a "B" or includes an "E"
Volvo motorsport used exactly the same system on their Volvo 242 Turbo Group-A race car and Peugeot on their 205 T16 Group-B rallycar as well.
I have a complete race CIS system so letīs take a closer look.
I will borrow some pictures that I found here.
We start with the air flow meter. Take a closer look on these two pictures and you will see that the housing differ a litte bit.
http://forums.pelicanparts.com/uploa...1331769573.jpg
http://forums.pelicanparts.com/uploa...1331769603.jpg
The race car used a specially designed air flow meter with changeable cones with different sizes to suit different tracks, height and power output.
The Number on this unit is B 438 120 363 928 001
http://forums.pelicanparts.com/uploa...1331770213.jpg
http://forums.pelicanparts.com/uploa...1331770234.jpg
http://forums.pelicanparts.com/uploa...1331770256.jpg
The fuel distributor. V8 heads modified by Bosch with bigger metering slits and nozzles. Early ones cast iron and later aluminum heads.
Volvo used the aluminum model and it can support fuel for over 400 Hp with only 4 outputs and over 600 Hp with 6 outputs.
http://forums.pelicanparts.com/uploa...1331771932.jpg
http://forums.pelicanparts.com/uploa...1331771953.jpg
Here you can see the different size of the nozzles between the stock 911/930 head and the race head. I donīt have any pictures to compare the metering slits.
http://forums.pelicanparts.com/uploa...1331772401.jpg
http://forums.pelicanparts.com/uploa...1331772421.jpg
Greetings from Sweden!
Daniel
willtel 03-14-2012 06:45 PM
Excellent first post and welcome to Pelican. Thanks for checking in.
Can I ask where you got these parts?
Grupp-A 03-14-2012 06:55 PM
http://forums.pelicanparts.com/uploa...1331774754.jpg
Control pressure regulator no. 4 on the drawing.
Manually adjustable 3-5 bar. Volvo run with 3.8-4.2 bar. The number on this unit is B 280 500 049
http://forums.pelicanparts.com/uploa...1331774806.jpg
VDO Pressure sensor no. 2 on the drawing.
Connected to the control pressure regulator and a gauge in the compartment to measure and read the control pressure, the most important pressure.
http://forums.pelicanparts.com/uploa...1331775401.jpg
No. 7 on the drawing is the return from the recirculating relief valve.
Daniel
mark houghton 03-14-2012 07:05 PM
Daniel, where have you been hiding? I am fascinated by the interchangeable "cones" on the fuel head (more appropriately, I would call them venturies). Those would definitely change the air flow characteristics and metering arm deflection. I think we're on to something here....
cole930 03-14-2012 07:54 PM
Danial:
Welcome and a million thanks !!!!!!!!!
I was familiar with the fact that the 934 CIS was different and that
the fuel heads would flow more fuel as well as having a different air
metering assembly. The problem was I could never find any information
about either. The information you have provided is priceless. And your
pictures are worth a thousand words. I know the 934 unit would
be serious overkill for a street car, as well as being way out of my price
range, but the pictures and information provides much clarity.
That is my 930 CIS in your picture and as you can tell I am a die hard
934 fan. My build is, as I stated, a street car but I tried to make the
modifications from the 934 that I felt could be incorporated into a street
car and would enhance performance while being true to the 934 Marque.
I installed the 934 headers and relocated the turbo and CIS in an effort
to reduce lag and shorten the intake track. The CIS itself has had the
the tapers inside metering cone modified to change the fuel curve.
The issue I have been trying to solve is the optimization of the metering
plate arm travel to insure we are getting all the fuel available in the stock
unit. A builder in Oregon " Jeff at Rothsport Racing" discovered, with a
stock 930 engine on the dyno, that at full throttle you could reach in and
push the air metering plate down further and actually find more fuel that
was previously unused. Jeff found that modifying the top of the metering
plate allowed full travel of the arm and resulted in more HP. Jeff felt that
the stock air filter was not allowing enough air to completely get all the
travel out of the metering arm. We were trying to further investigate the
934 air intake configuration to see if we could solve the issue.
Again I thank you for the incrediable information and if you have any
insight on the extra arm travel I would greatly appreciated.
Cole
WERK I 03-14-2012 08:29 PM
Cole,
I've been thinking about this a lot since the recent threads on the Bosch metering units. Regarding what Jeff at Rothsport Racing discovered; if the metering plate will travel further down after pressing on it, why wouldn't lowering control pressure do the same thing? Afterall, when there's 0 psi control pressure, doesn't the plate naturally lower to the bottom of the plenum due to gravity?
cole930 03-14-2012 09:02 PM
Dave:
Good to hear from you !!! Hope all is good with you and yours !!!
As a matter of fact I have. I have a DWUR that I have never installed and with the issues they have had I don't feel comfortable doing a fresh start up with it so I sent my WUR out to Brian to get it modified to adjustable. I saw Leask's plug on this new RPM controlled solenoid valve and it got my wheels turning about
possibly using it to chop the control pressure at high RPM. Thought I would get my feet wet with the new WUR and then give Leaks a call and pick his brain about using the RPM Solenoid to quickly drop control pressure up top.
Cole.
Alan L 03-15-2012 12:16 AM
I had one of those B280 500 049 gizzmos on my beast when I got it - between my WUR and fuel head on the CP line. Could never work out what for. Took it off.
My part # search told me it was a Mercedes fuel enrichment device - mine is fractionally different and has Bosch # 0 280 161 007.
But it looks like it allows another adjustment to the CP. It is basically a spring loaded/adjustable diaphragm which the CP fuel runs across.
Cole, I KNEW you would be dribbling over this post. Wipe your chin.
Daniel - TELL US MORE. Don't leave us hanging here. Where does Cole get this stuff?
Alan
Grupp-A 03-15-2012 07:49 PM
willtell:
Thanks! Very hard to find but I found it here in Sweden itīs meant for the Volvo race car.
Mark:
Yeah I like it too!
Cole:
You are welcome Iīm glad to help!
Why do you need that exta fuel is it running lean?
Do you need extra fuel on all rpms or just on full throttle?
If you just need it on full throttle then I can give you a tip, a trick Volvo did.
They took a frequency valve but instead of being connected to the lower chamber on the fuel distributor like normally they coupled it in parallel with the control pressure regulator, or in your case the WUR. Then when itīs operating the control pressure will drop. You just have to find a way to trigger it, for example a pressure switch, rpm switch, nock senor, manually etc.
Picture of it installed on a Volvo race car.
http://forums.pelicanparts.com/uploa...1331865706.jpg
Daniel
cole930 03-15-2012 08:40 PM
Daniel:
The reason there was so much interest in the 934 set up is that above about 350 HP the stock 930 runs out of fuel and goes exceptionally lean.
It was found that during a recent 930 dyno pull at full throttle the metering plate could be pushed down further using a long screw driver. In other words the metering plate will not go to the end of it's full travel and thus is not allowing all the full fuel available to be used. On this particular 930 build they added a flap of some kind to the top of the metering plate, which allowed full metering arm travel, and gained significant HP without a lean condition. The tuner attributed the fuel shortage to the intake air not being sufficient to get full travel of metering arm. I am trying to make sure I get full travel of the metering arm and accessing all the available fuel.
The interest in being able to get full fuel by getting full metering plate
travel led us to trying to find out what modifications were done on the 934 CIS that might give us the answer. Due to the fact there was never any definitive
information on how the 934 CIS supported 480 HP we were speculating until
you posted.
The frequency valve addition certainly gives us another viable option !!!!!
THANKS !!!!!!!!!!
Cole
cole930 03-15-2012 09:09 PM
Alan:
You are correct, I've been drooling over all this since Danial posted. This
clears up all the questions we have had about how a 934 got more fuel.
I realize the 934 CIS is impractical for a street car but also now
understand how it got more fuel. The multiple air metering heads tell us a
lot because we know more air means more fuel as long as more fuel is
available.
What we have seen with Daniel’s kind contribution is the lengths the factory went to in getting enough fuel. Obviously the air metering modifications are the answer. Which also lends credence to Jeff’s statement about more inlet air. I pulled the next few paragraphs from my old files and they are interesting reading when you look at the 934 CIS mods. The recontouring of the funnel
That Steve Wiener has done for years now makes a lot of sence. Steve did mine for me a couple years back.
The intake air quantity serves as the main actuating variable for determining
the basic injection quantity. It is the appropriate physical quantity for deriving
the fuel requirement, and changes in the induction characteristics of the
engine have no effect upon the formation of the air-fuel mixture. Since the air
drawn in by the engine must pass through the air-flow sensor before it
reaches the engine, this means that it has been measured and the control
signal generated before it actually enters the engine cylinders. The result is
that, in addition to other measures described below, the correct mixture
adaptation takes place at all times
The basic adaptation of the air-fuel mixture to the operating modes of idle,
part load and full load is by appropriately shaping the air funnel in the air-flow
sensor If the funnel had a purely conical shape, the result would be a mixture
with a constant air-fuel ratio throughout the whole of the sensor plate range
of travel (metering range). However, it is necessary to meter to the engine an
air-fuel mixture which is optimal for particular operating modes such as idle,
part load and full load. In practice, this means a richer mixture at idle and full
load, and a leaner mixture in the part-load range. This adaptation is achieved
by designing the air funnel so that it becomes wider in stages. If the cone
shape of the funnel is flatter than the basic cone shape (which was specified
for a particular mixture, e.g. for ė = 1), this results in a leaner mixture. If the
funnel walls are steeper than in the basic model, the sensor plate is lifted
further for the same air throughput, more fuel is therefore metered by the
control plunger and the mixture is richer. Consequently, this means that the
air funnel can be shaped so that it is possible to meter mixtures to the engine
which have different air-fuel ratios depending upon the sensor-plate position
in the funnel (which in turn corresponds to the particular engine operating
mode i.e. idle, part load and full load). This results in a richer mixture for idle
and full load (idle and fullload enrichment) and, by contrast, a leaner mixture
for part load.
I was thinking if we take the information here there are several things
that could be done to improve stock 930 CIS performance.
Cole
Grupp-A 03-15-2012 10:05 PM
Cole:
Then I have important information for you!
The metering arm only needs to travel 37 +/- 1 mm down to open the hole metering slit. Thatīs about 8 mm before full travel.
If it travels more than that the control plunger goes upp too high and starts blocking the fuel from entering the barrel.
One old engineer at Volvo motorsport told me that, and I have checked it by my self, and Iīm pretty sure itīs the same with standard Porsche and MB units.
see pictures.
Have you tried to increase the fuel flow by adjustning the spring tension on each outlet on the distributor?
If thatīs not enough then you have to raise the system pressure.
http://forums.pelicanparts.com/uploa...1331874157.jpg
http://forums.pelicanparts.com/uploa...1331874176.jpg
http://forums.pelicanparts.com/uploa...1331874205.jpg
Daniel
JBL930 03-16-2012 04:24 AM
Cole.
Hi Cole, that's not what the RPM solenoid is for, see it as an on/off valve cut into the vac/boost line from your manifold to your WUR. Let's say you put a 4200rpm chip in it, this means it will open at 4200 RPM. The point being is that vac/boost line going 'unrestricted' to the WUR allows to WUR to enrich the fuel FAR too early, hence the huge 'fat mid range' fuel curves we see on a lot of CIS cars.
Main reason being, the stock system had that lazy old 3LDZ turbo, restrictive exhaust etc etc etc..... So it did a decent job on a stock engine.
With a quicker spooling turbo, a freer flowing engine all round, direct manifold pressure to the WUR will see premature dumps of fuel in the mid range.
The RPM solenoid irons this out. When you first Dyno the engine, you may see it getting pig rich at a little over 2000 RPM, then start to come good again up around 3800 RPM. So you fit a 3800 chip in the solenoid and it stops the manifold pressure getting to the WUR, hence preventing the diaphragm moving and dumping all that unnecessary fuel in, until of course you need it, then the solenoid opens, you may get a simigin of over richness for a second, and then you are back on track.
Look at leask's graph below, The blue line on each graph (the fuelling bit at the bottom of each Dyno sheet obviously) shows the run without the solenoid connected, just unrestricted manifold pressure going to the WUR. Then the red line shows the RPM solenoid holding off that manifold pressure until the fuel is actually needed....... You couldn't really ask for a better fuel curve really, without EFI that is about as good as you can get, and frankly as good as it ever needs to be, more power, less fuel, happy days ;-)
http://i139.photobucket.com/albums/q...0/7faf66a2.jpg
mark houghton 03-16-2012 05:54 AM
They took a frequency valve but instead of being connected to the lower chamber on the fuel distributor like normally they coupled it in parallel with the control pressure regulator, or in your case the WUR. Then when itīs operating the control pressure will drop. You just have to find a way to trigger it, for example a pressure switch, rpm switch, nock senor, manually etc.Daniel
That's what the old Andial fuel enrichment systems did. I had one, it worked pretty well actually, but adjustable WUR's enable a better fine tune.
JFairman 03-16-2012 12:07 PM
"Have you tried to increase the fuel flow by adjusting the spring tension on each outlet on the distributor?"
If you do that with a painted cast iron euro fuel head be very careful and only turn the 6 individual 3mm allen heads (that are under the 4mm allen head button screw covers) that adjust spring tension pushing down on the stiff stainless steel individual injector final fuel metering diaphram a tiny bit clockwise at a time or the metal diaphram will possibly be dented or dimpled and that'll damage it's ability to accurately and consistanly meter fuel against the small fuel orifices above it permanently.
You also have to do an injector flow test on the motor while you have the injectors inserted into 6 individual bottles to collect the fuel sprayed from them. 8 ounce plastic water bottles work good for that.
Then measure the fuel in the bottles while adjusting so all injectors flow equal amounts. If 2 flow more than the others put those injectors in #2 and #5 because those heads and combustion chambers run hotter than the rest.
It's a slow tedious process because you have to remove the injector line banjo fittings to remove the 4mm plugs underneath and adjust the 3mm spring tension adjusters over and over a little at a time until you get them as close to each other as possible.
With an aluminum lambda fuel head the diaphram seperating the upper and lower chambers is made of a very flexible synthetic material instead of stainless steel and it has 6 round fuel metering discs bonded to it under the upper chamber fuel metering orifices that lead upwards to the injector line banjo fittings.
That means you have alot more final and individual injector fuel metering adjustability with a lambda head and it is why the aluminum lambda fuel heads used from 1986-1994 can flow more fuel than a cast iron euro fuel head.
The aluminum fuel heads also weigh alot less than the cast iron heads and they won't rust in the bottoms of the lower chambers when water gets in there and stays there because water is heavier than gas.
That's where the rust people find in the conical CIS injector fuel screens is probably coming from. The stock fuel filter would stop rust particals coming from the gas tank and any that are small enough to pass through it would go right through the 6 fuel screens around the control plunger cylinder that fuel flows through entering the cylinder and also the conical fuel screens in the injectors.
"If thatīs not enough then you have to raise the system pressure."
I know hydraulic control pressure and lower chamber pressure have nothing to with each other and are isolated from steady system pressure by small fuel orifices but hydraulic control pressure fuel pushing down on the top of the control plunger will go up at the same time fuel system pressure is raised so the control pressure regulator will have to be adjusted to return more fuel to the tank to lower hydraulic control pressure.. if you want more fuel from the injectors.
Another modification along with the rest of them to get more fuel is enlarging the 6 fuel metering slits in the control plunger cylinder wall that lead to the 6 individual upper chambers. They can be enlarged in a tapered fashion. I don't know if anyone actually does that but it would probably require CNC machining to enlarge them all the exact same amount.
Thierry25 03-16-2012 04:39 PM
Originally Posted by Grupp-A (Post 6626613)
Cole:
The metering arm only needs to travel 37 +/- 1 mm down to open the hole metering slit. Thatīs about 10mm before full travel.
see pictures.
Daniel
Daniel
Great inputs and pictures from you !
I am also agree with your information concerning the metering arm travel . There is no any "hidden" fuel flow additionnal capacity by trying to get more excursion !
Grupp-A 03-16-2012 05:37 PM
Yes I agree with Jfairman the later aluminum distributor is a much better choice!
Thierry25:
Thanks!
I changed my post, I did a control today it is 8 mm before full travel measured from the center screw and straight up or 37 mm down from its rest position.
Volvo did this on some cars. They drilled one of holes that holds the distributor in place straight through and installed an adjustable stopper against the counter weight so the arm only could travel 37 mm.
http://forums.pelicanparts.com/uploa...1331943876.jpg
Picture of a very early car they used a Porsche 928 air flow meter and a MB V8 aluminum distributor with two outlets connected to one injector to get enough fuel. Same here.
http://forums.pelicanparts.com/uploa...1331944207.jpg
Daniel
cole930 03-16-2012 10:09 PM
Daniel:
One thing for sure is with all this information I can forget everything
I read, herd, supposed, or was previously told about 930 CIS. I sincerely
appreciate all your help with this. I at least feel I have a valid starting
point. I can set the correct metering plate travel, dial in all the pressures
correctly and then work from there. I have an Innovate LM-1 logging all
the pertinent engine parameters so I should be able to make sense out
of all this, finally.
While we are here have you got any information on that metering plate
cone that can be seen on top of the metering plate on my motor ( the pic
you posted earlier) ?
THANKS !!!!!
Cole
911nut 03-17-2012 07:50 AM
I ran across this issue when tuning my CIS last year. I increased the system pressure to max but no changing of boost control pressure would allow the system to run in the sweet spot of 11.0 - 12.2 afr. It was pig rich all the time. My engine is stock so I couldn't use the extra fuel. When I dropped the control pressure to minimum spec all was well and now runs like a raped ape.
WinRice 03-17-2012 08:52 AM
Man, this is good stuff! Thanks for sharing!
Out of curiosity, what system pressures have you tried, and what do you run now?
