Architecture & Porsche's
Paging Dr. Leask: will the real Brian Leask please stand up :)
Brian you here?
I'm trying to locate Brian: misplaced my Leask WUR adjustment instructions: does anyone have a copy/digital copy?? I'm not having any luck with the .Cox email address. Mine has the upgraded diaphram for higher HP if that makes any difference. Mark.
Porsche Club Racing National Scrutineer '89 Andial 951 '82 928R '74 911 RSR 3.6 |
Crotchety Old Bastard
If you bought it through me I'll have a record of it and send you a copy. If not email me your information and I'll help however I can.
RarlyL8 Motorsports / M&K Exhaust - 911/930 Exhaust Systems, Turbos, TiAL, CIS Mods/Rebuilds '78 911SC Widebody, 930 engine, 915 Tranny, K27, SC Cams, RL8 Headers & GT3 Muffler. 350whp @ 0.75bar Brian B. (256)536-9977 Service@MKExhaust Brian@RarlyL8 |
I had sent it to him directly back in January 2011. I remember emailing him a question in regards to tuning hardware that wasn't returned, back in March of '11 or so. Is he ok??
Mark
Metal Guru
When I was having an issue with my wur last year he got back to me within a couple of days so he will respond if you have a problem.
Paul B. '91 964 3.3 Turbo Port matched, SC cams, K27/K29 turbo, Roush Performance custom headers w/Tial MV-S dual wastegates, Rarlyl8 muffler, LWFW, GT2 clutch & PP, BL wur, factory RS shifter, RS mounts, FVD timing mod, Big Reds, H&R Coilovers, ESB spring plates- 210 lb |
i cant find my manual either so if anyone has a copy...
Ive emailed him lots this week and he responds almost immediately. If I had my manual I wouldnt have bothered him so much. btw anyone know how to set cold start afrs.? Ive gotten the other adjustments down but now on cold start/early am , it runs rough with afrs in the 14.5-15.7 range......
1984 ROW 930 turbo with rarly8 exhaust, waste gate pipe and HEADERS K27HFS TURBO, B&B IC, 1 bar spring,LEASK WUR with rpm solenoid, fab speed intake filter, front strut brace rennline. MOMO wheel, Innovative afr 16-1 gauge, custom 930 ELGIN cam |
Changing CCP can also affect WCP (my CCP setting originally got screwed up by someone adjusting it to raise WCP on the dyno - because they didn't know there was a separate adjustment for that on a BL WUR), so check/re-adjust that separately.
'77 S with '78 930 power and a few other things. Last edited by spuggy; 04-26-2012 at 12:22 PM.. Reason: fix the gibberish. |
Brian ran across this thread & sent me the manual: thanks Brian!
Cold start afr's: mid, mid-low 13's are best for the strongest idle with a cold engine, & produces the strongest vacuum numbers as well. 14's are too high for a cold engine. Once warm, mid 14's. On cruise, 14.7-15.0 for mileage. For soft/mid acceleration, mid 13's. WOT: 11.8-12.0
