Thanks, I found some of these as a starting point so much appreciated. I have an 86 930 that I'm trying a haltech e6k to start playing with.
My 3.0CIS Turbo Map
Here is my initial ignition map.
Stock 3.0CIS engine but with 9.5:1 compression. Stock SC Cams. Single plug. Stock headers with J Pipe. Turbo is a Pulsar 3076 0.63a/r. EFI using 3.2 manifolds and Ecumaster Emu Black. Wastegate is Tial F46P with 0.5 Bar Spring Engine starts and runs well. Drives OK but I have been very gentle and not seeing boost often. Would appreciate some pointers on where to go from here (yes, a dyno and pro tune is on the cards) ![]()
Always learning. www.aircooledporsches.com.au See me bumble my way through my first EFI and TURBO conversion! https://youtu.be/bpPWLH1hhgo?si=GufVhpk_80N4K4RP |
That is a really good link and editorial and there are more good ones down at the bottom of the page.
It's a 914 ...
@mikedesilva thanks for sharing your map. One q - I see you’ve got the timing increasing right up to 7250. Some level off the advance or even taper it a bit. Curious to know your thinking in doing it that way.
![]() Any other takers willing to share ignition tables? In particular, Im trying to understand where to advance in order to increase spool up earlier in the rpm range... 3.0SC engine with 3.1 kit (9.7 Max Moritz pistons, SC cam, 3.2 manifolds, aftermarket ecu,COP, std heatexchangers with J pipe, Pulsar 3076R,no intercooler yet!
Always learning. www.aircooledporsches.com.au See me bumble my way through my first EFI and TURBO conversion! https://youtu.be/bpPWLH1hhgo?si=GufVhpk_80N4K4RP Last edited by mikedsilva; 05-27-2024 at 05:20 AM.. |
Fear No Rust
I am going to be starting to work on this too soon.
Using a Haltech Elite 750. John
http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/1105122-driver-survivor-black-1987-930-build.html Real IMSA 914 restoration: http://www.914world.com/bbs2/index.php?showtopic=91937 Basket Case 914 restoration: http://www.914world.com/bbs2/index.php?showtopic=79106 |
Any others willing to share ignition tables???
Retarding the ignition on tip in should speed up spool, unfortunately I have not gotten to the tuning portion of my engine, so I have no map to share.
Interesting... might give it a go. With the number of people running converted turbos that used this forum for their guide, I'm sure there are a bunch of lurkers that could share there maps!
Brando
Here is mine but why do you think my advance number is higher than specified? I do have mat and oil temp adjustment but at the temp at the time it should have been out of the equation. Thoughts?
Turbo powa! 1977 911s. it's cool Last edited by quattrorunner; 10-03-2024 at 01:40 PM.. |
Brando
Turbo powa! 1977 911s. it's cool |
Brando
Who pays attention to egt?
![]() Here is my Megasquirt Pro Ignition Map. Idles well, 1st is very short, pulls strong through 2nd, 3rd and 4th. Would like to play with retarding timing to spool earlier. Thoughts on where to adjust my map. Engine is Twin plugged. Thanks John |
Brando
Interesting. Who wants to show the afr table as well?
This is me..
9.5 compression. intercooler maybe Im too conservative? ![]() ![]()
Thread Tools | |
Rate This Thread | |
