Bbs rs
I p/u a set of BBS RS wheels in 928 offsets, these I will rebuild with 17" wheel barrels and hopefully end up with 9.5"x 17" and 11"x 17" possibly 12" The wheels had very little care and were caked with mud and brake dust. nasty.
Anyway they will be revived. Also managed to clean more of the under carriage. ![]() ![]() ![]() ![]() ![]() ![]()
"This Year ferrari's Ass is Mine" |
Banned
WOW, looks really good, and the wheels are going to be awesome!
BBS fans
No afilliation, come across this add on cl in Florida, not sure what they are or if they are still available.
PORSCHE BBS RS WHEELS
Chris 89 930, 87 930, 86 930 Ruf BTR tribute, 89 Ruf CTR tribute |
Nice - those are identical to my set, I'd be OK with $2k for mine!
What does it take to make them into 17s? Do the centres from the 16s fit into the 17" barrels?
Richard 1982 930, K27-7200, Ruf wheels, Leask WUR, Tial WG, RarlyL8 headers & single out muffler, SC cams, TK I/C 2018 GTi, 2020 AMG E53 wagon ski car 2004 BMW R1100S |
KS Roadrunner
You can check Kodiak Racing Wheels - Custom lightweight race wheels for performance and racing [Shells] for custom made halves. They are also in Canada.
Looks like they're no longer offering RRS RS replacement wheel halves
bbs
Thanks Gents
this is what I hope to achieve. Beautiful in my eyes. ![]() ![]()
KS Roadrunner
Here is my previous BBS RS 15x13 wheel.
^ both look fantastic, would kill for BBS in my sizes!
They look great, I went to the Rufs because of limited tire choice in 16" but would go back to my BBS if I could turn them into 17s cost effectively.
separated
Started working on separating these next off to the powder coater for a fresh gold coat.
The previously black centered wheel is back from the powder coater. Now i need a 3.5" outer lip.
Tinkering Pays!!
is there a seal that goes between the metal pieces? if so, can you purchase new ones when you separate?
thanks
LIVN80S - - Red '79 Porsche 930 Steel Slant Nose Conversion [in 1987] w. 46k miles 3.3L; 964 Cams; K27HF @ 1.0 BAR, with Garrettson Intercooler; Rarly Zork; CIS Flowtech Fuel Head & BL-WUR. |
no seal
I believe these where made air tight with a bead of silicone RTV of some sort, i haven't reached that point so not sure what product to use.
After the wheel is bolted together and torqued to spec, lay some masking tape on either side of the three pieces and run you bead smoothing it neatly out with a finger, peel the tape away and you will have a nice even seal. hope this helps Rod
There's no seal between the centers and rim halves on the DOT spec RS wheels. After bolting them together just apply some silicone gasket sealer of choice in the recessed groove where they came together and then wipe the silicone bead with your index finger to spread it smoothly in the groove. you have about two tries before the silicone sealent starts to dry and pull as you slide a finger over it to screet it out.
I've done it many times and never used tape or anything else. It's just like caulking around windows or in corners of walls. run a bead and wipe it once with your index finger to smooth it out and force it deeper into the crack or groove. With the BBS motorsports wheels there is an aluminum ring that takes an o ring on each side that goes in between the rim halves when you bolt the center to them. Those are supposed to go together dry but i use hylomar gasket sealer on them when I bolt those old wheels up. |
Got the 9x16 spare back together, pretty simple to do.
Are these wheels date coded
date code
possibly a date code?
If anyone is looking to buy a set set with 1' wider lips than stock send me a message. I may be looking to get out of mine. I have since changed projects.
Sorry for the thread jack.
1958 Karmann Ghia |
