Help With:- High Engine Temperature
Hello There
I owned my 1987 930 Turbo since 4 years and I just complete my car restoration, today was my first drive and I'm new to the car, I feel that my car Engine temperature is high comparing to my other cars, Do of lack of experience on 930 Turbos can any one advice me if this Temperature is Ok or No, I'm attaching 2 photos for the Engine Temperature Gage.
when the car is running Temperature is increasing when the car is stopped Temperature is down.
In my country Temperature is reaching 131 F, Can any one advice what to do? is there any extra cooling solution for this cars?
Regards,
FALNAIM
Old 06-27-2012, 04:22 AM
Plus very low oil pressure.
Time for some larger oil coolers and puller fans.
Old 06-27-2012, 06:21 AM
Banned
Why do you think the pressure is low? Just under 2bar at just under 2K rpm at that temp seems normal . . . Also, the oil temp is not too high and would not concern me if it doesn't spend much time any higher.
Old 06-27-2012, 07:01 AM
M5guy's Avatar
for that temp and those rpms that seems like very normal oil pressure.
Old 06-27-2012, 07:20 AM
I've gone native
Tt surgeon's Avatar
If you're running a little lean it will run hot as well. Oil pressure is ok.
'07 997.1tt
Blk/blk 600hp, bad to the bone
Old 06-27-2012, 08:56 AM
9dreizig's Avatar
Send a message via AIM to 9dreizig
guys,, ambient is 131 deg F ,, oil temp reflects this,, I think this is pretty normal..
"Todd"
98 Tahoe ,2007 Saturn Vue
86 930 black and stock, 80 930 blue tracdog
91 Spec Miata (yeah I race a chick car)
"life"ll kill ya" Warren Zevon
Old 06-27-2012, 09:29 AM
I've gone native
Tt surgeon's Avatar
131! I missed that line, holy crap dats hot.
'07 997.1tt
Old 06-27-2012, 09:58 AM
hot
My 1987 930 appears to run hot too. Here in Buffalo, New York we may see 90f on a very hot day and the factory gauge will start to enter the red zone. I have rebuilt the front cooler/thermostat to no avail. I suspect maybe the engine oil cooler or perhaps maybe 85k miles.
Old 06-27-2012, 04:37 PM
Brando
quattrorunner's Avatar
Engine thermostat? Crimp in lines? Fan on cooler?
Turbo powa!
1977 911s. it's cool
Old 06-27-2012, 04:54 PM
9dreizig's Avatar
First thing to do is take it out and warm it up. Then with your hand feel the lines going up front. Are they warm ? if not it's a thermostat,, if they are, that's not the problem ( which I don't think you have at 130f ambient)..still say it's normal
"Todd"
Old 06-27-2012, 05:00 PM
mark houghton's Avatar
...and the verdict is.....Normal - given the ambient temps. Unless we've mis-read you post and your reference to 130 ambient is as hot as it CAN get, and not the actual temperature you were seeing when you posted the pictures.
What does your oil pressure do when you're running not at idle?
Mark H. 1987 930, GP White, Wevo shifter, Borla exhaust, B&B intercooler, stock 3LDZ.
Old 06-27-2012, 06:37 PM
j930's Avatar
out here in phoenix its been around 115 lately, when driving my car is just above the first line. when stopped it will climb but only to the top line. never had it above but to be fair i have never had to sit in traffic long. as soon as i move out cools back down. i have a front oil cooler as well which i think helps. i just had my engine rebuilt as well and noticed a significant drop in temperature after that. it would hover dead center before that. we scrubbed and cleaned every component on the engine and the oil coolers to ensure a good airflow. hope this helps.
84 930 Slant
15 Sonata 2.0T
08 Ram 1500
15 Ram Eco Diesel
Old 06-27-2012, 07:10 PM
IIRC, That white "hash" mark that I circled is 212 degrees.
Tim
1986 930
Gone:71,2,4 914's, 70T, 71T(RS),77S
Old 06-29-2012, 07:33 AM
Tinkering Pays!!
mooney265's Avatar
If I lived in a place that sees 131F, I'd begin to question if the local ruler was a guy named Lucifer
LIVN80S - - Red '79 Porsche 930 Steel Slant Nose Conversion [in 1987] w. 46k miles 3.3L; 964 Cams; K27HF @ 1.0 BAR, with Garrettson Intercooler; Rarly Zork; CIS Flowtech Fuel Head & BL-WUR.
Old 06-29-2012, 07:53 AM
+1 on normal temps vs rpms.
However, the first picture shows close to 250* and that's just TOO hot for comfort...
"...when the car is running Temperature is increasing when the car is stopped Temperature is down..."
Is that backwards? It should be. If not, what do you do after driving it for a while...? stop and let it cool?
I believe most of us face that situation sooner or later, IMHO a front valance oil cooler is the proper solution - assuming the engine if fine. You can add scoops, air flow openings, fender oil coolers, fans... you name it... they all help a degree or two... don't waste time & $s and go with the valance oil cooler. M2c.
Old 06-29-2012, 08:07 AM
I was seeing those temps in stop and go traffic, then added a front Carrera style cooler with thermostat. Now, the temp goes up above the 212 mark, the fan comes on, brings it down to the 180-200. It will only do this several times, as if I remain in the traffic, the cooler will be over come by the heat. All the cooler really does it buy you some extra time, which is good. The minute I get back to speed, my temps come down to the first white mark (180-200).
Tim
1986 930
Old 06-29-2012, 08:35 AM
The way should be!
Old 06-29-2012, 08:56 AM
xbmwguy's Avatar
+1 on the front cooler. if you are really handy you can do what miguel did (looks great too) or buy one like i did to accomodate the cooler
Old 06-29-2012, 10:29 AM
What front bumper/valence is that?
Old 10-07-2021, 11:50 PM
16Volt's Avatar
From DP
- 86 Porsche 930 - Mr.Hyde
- 86 BMW 635CSi - Dr.Jeykell
- 2006 Infiniti M45 Sport
https://medium.com/@crashingdoor
Old 10-16-2021, 03:54 PM
