red 930's Avatar
stock boost question
I have a stock 76 930. What should be the stock boost (in mb)?
I'm running at .75 now.
Old 01-29-2013, 06:22 AM
1 bar is 14 and change if I recall. I would think .75 would be 11-12? I'm sure someone here can pinpoint it. Are you going off the original stock gauge?
63 356 So Called Outlaw
76 930
Old 01-29-2013, 09:54 AM
02fly's Avatar
No gauge in a 76.
Old 01-29-2013, 09:59 AM
Crotchety Old Bastard
RarlyL8's Avatar
Stock boost level on the intercooled 930 is 700-800mb. I believe the non-intercooled boost levels are similar as the C/R was lower on those 3.0L engines. I can pull out the manual if you need a spec range.
Old 01-29-2013, 10:21 AM
Metal Guru
911nut's Avatar
1 bar = 14.7 PSI
.75 bar = 11 PSI
Paul B.
'91 964 3.3 Turbo
Port matched, SC cams, K27/K29 turbo, Roush Performance custom headers w/Tial MV-S dual wastegates, Rarlyl8 muffler, LWFW, GT2 clutch & PP, BL wur, factory RS shifter, RS mounts, FVD timing mod, Big Reds, H&R Coilovers, ESB spring plates- 210 lb
Old 01-29-2013, 08:00 PM
