M5guy's Avatar
Guide Fork Plate - R&R
I have a small weep from the guide fork plate on the gearbox. I have a new gasket and a jug of Swepco, but two small questions.
1. Would a thin layer of gasket sealant be appropriate here, or not?
2. If I remove the plate with the gear selector in neutral and refrain from poking around in the gearbox, will the plate go back on correctly, in the sense that all four gears and reverse will be selectable when I have buttoned it up?
Thank you.
Old 09-06-2012, 08:28 AM
beancounter
jwasbury's Avatar
The plate is easy to R&R. I resealed mine over the winter due to a leak. I don't recall if I put the gear lever in neutral or not, but I definitely didn't mess with the lever while the plat was removed...I couldn't, as I was underneath the car the whole time. I used a rational amount of gasket goo (hylomar) as a sealant. No drips, no problems.
Jacob
Current: 1983 911 GT4 Race Car / 1999 Spec Miata / 2000 MB SL500 / 1998 MB E300TD / 1998 BMW R1100RT / 2016 KTM Duke 690
Past: 2009 997 Turbo Cab / 1979 930
Old 09-06-2012, 07:18 PM
M5guy's Avatar
Thanks!
SR
86 930
x: 62 356, 64 356, 76 930, 84 911 Targa, 85 ROW 911, 00 996, 07 Cayman S, 00 M5, 02 G500, 66 Shelby GT350 (x2), 64 Corvette.
Old 09-07-2012, 04:27 AM
I have to do the same thing on my 4 speed. So this can done on the car?
John- 78 Slick Top 930
"Illegitimi non carborundum"
Old 09-07-2012, 08:21 AM
beancounter
jwasbury's Avatar
absolutely. i wanted to freshen up the gear lube anyway, so did the leaky gasket fix on the access cover plate at the same time. easy peasy DIY job.
Jacob
Old 09-07-2012, 09:26 AM
Excellent! Thanks.
Old 09-07-2012, 10:03 AM
