boosted 89's Avatar
A/F readings under boost
Hey everyone
Just wondering what kind of numbers are you running at under full boost. My WB gauge is typically dropping into the high 9 area at 1 bar at full throttle. Almost feels like it's hesitating when under full boost and occasionally it hits overboost on cool mornings. Mods consist of k27 7200, B&B headers, kokeln I/C and a K&N cone filter. Has anyone encountered the same results?
Chris
Old 09-10-2012, 03:25 PM
oilonly's Avatar
Mid tens to near eleven for me. It feels great but some say my numbers are a tad rich.
'87, Modified WUR, Billet valve, 965 downpipe, Kokeln intercooler, GHL headers, Garrett T04B K27 hybrid, Tial w/.8 bar, WEGO IV, RarlyL8 dual out, LSD
Old 09-10-2012, 05:20 PM
boosted 89's Avatar
I was thinking the same with mine(pig rich). I figure high tens to mid elevens should be right with 1 bar. Can't really think whats causing such a rich mixture. The car idles right around 14.5 most days and I do have the original o2 sensor unplugged only because the lamba unit was making it go pig rich at idle. Would it possibly be too high control pressure or should I be leaning more towards a WUR
issue? Gees I guess it could be a number of things.
Old 09-10-2012, 05:33 PM
Crotchety Old Bastard
RarlyL8's Avatar
That's not unusual for a stock 20+ year old WUR. They were factory set on the rich side and get worse with age. My target is mid 11's at peak torque. Another important number is the AFR at redline under full boost. That number should be ~12.0 optimally.
A few things you can do; add an RPM switch or like device to delay the enrichment, rebuild the WUR and set back to spec, make the WUR adjustable and set to your spec, or all three.
Old 09-10-2012, 05:47 PM
boosted 89's Avatar
Thanks for the info Brian. I'll be looking to get the WUR rebuilt and modified to be adjustable. Do you rebuild and modify WURs or am I thinking of Brian L?.
Chris
Old 09-10-2012, 05:56 PM
boosted 89's Avatar
Brain ..
just saw your website..
I'll be sending it your way when the snow flys here!
Chris
Old 09-10-2012, 06:11 PM
oilonly's Avatar
Yeah I have to get my WUR adjustable also. Just a matter of when.
Old 09-10-2012, 07:20 PM
PrimeMvr's Avatar
Chris, do you have a K&N part number for the small can/filter your breathers are attached to? I have been looking for something like that.
To stay on topic, I have an adjustable, but not rebuilt, wur and similar mods. I see mid-tens at .8 bar and high-elevens at redline.
87 930 - Black - 3.4L/964 cams/K29/Powerhaus IC/6AL-2/B&B dual exhaust/MTX-L/235-315 Toyo R888/18" Kinesis wheels/Big Red brakes/LSD
10 997.2 Cab - Speed Yellow
83 SC Cab - Guards Red [SOLD]
17 NSX - Nouvelle Blue
Old 09-10-2012, 08:14 PM
boosted 89's Avatar
The catch can is something I made on my small lathe/milling machine and the filter number I can't remember exactly. K&N website has tons of different size breather filters in the universal filter section with accurate filter measurements. I get zero oil in the catch can so I would presume mounting just a filter on the end of the hose mounted higher up would work just as well.
Chris
Old 09-11-2012, 04:02 AM
