6771911esses's Avatar
AFR changes with Zork
I recently removed my Borla exhaust and installed a Zork tube. Where the car ran 11.8 AFR on the wideband with the Borla I now see 13s. I read somewhere that this can happen with turbos with no restrictive mufflers. Any thoughts on this? Should I readjust my Leaske WUR or keep it at the same settings . The AFR sensor is upstream from the turbo and most tech articles I read recommend the AFR probe to be installed downstream from the Turbo. This would be in the Zork tube. My headers have the bung in the collector under the Turbo (like the factory O2 sensor) as most other 930 headers have it. Does anyone have their AFR sensor downstream from the Turbo?
Old 09-24-2012, 08:25 PM
Groovie Ghoulie's Avatar
Bump for answer. Need to install an AFR Gauge myself, but also want to keep my zork. Interested in the answer....
Old 09-24-2012, 10:04 PM
Subscribed. Currently tuning with a zork. Curious as to why if this is the case.
John- 78 Slick Top 930
"Illegitimi non carborundum"
Old 09-25-2012, 04:12 AM
River Rat
Dave 86 930 Fl's Avatar
My AFR sensor is installed downstream of turbo ... I've never experienced a change in AFR as a result of muffler change. I'm currently running a zork and no issues with sensor performance.
1986 930 - K27-7200, Andial Intercooler, Tial Wastegate, Electronic Boost Controller, B&B headers, Bodart Zork, Leask Adjustable WUR, Full Elephant Racing Suspension w/Adustable Spring Plates and Von Shocks, Wevo Transmission Mounts, Fuel Safe Fuel Cell, Forgelines (9"/11"), Hargett Shifter, Innovate AFR, Cobra CF Seats, DAS Rollbar, Coleman Floating Rotors, Lightweight Interior, Forgeline 17" x 9"/11", 2800 lbs.
Old 09-25-2012, 04:33 AM
Crotchety Old Bastard
RarlyL8's Avatar
If you have not done so the change should be verified by putting your muffler back on.
O2 sensors located before the turbo are exposed to back pressure which can skew the reading. Locating in the tailpipe should provide consistancy to the reading nomatter what muffler/zork is used. If the muffler is restrictive the AFR's will be affected as you make more power.
Old 09-25-2012, 07:57 AM
I had the O2 sensor upstream of the turbo for a while, then installed a new straight pipe exhaust with the bung right after the turbo with no difference in readings.
I wonder if the Zork tube is too short to install the sensor downstream of the turbo allowing - under certain conditions/ back pressure - some outside air back in indicating a lean mixture...
Old 09-25-2012, 12:41 PM
Some sensors/gauges need to be recalibrated from time to time, as well. If you de installed and re installed, etc. you may need to re calibrate. It should be in your manuals if your product requires it.
Emery
1988 930 coupe - Silver Metallic
TurboKraft 3.3L 8:1 CR, SuperSC Cams, GT35R, B&B Headers, TK intercooler, Tial WG, ARP, tecGT based phased sequential EFI & ignition, Wevo shifter/coupler, ...
Old 09-25-2012, 03:03 PM
Is your's a narrow band or wide band sensor?
It's wide band sensiors that are thrown off by backpressure. Narrow band O2 sensors like the factory '86 on lambda O2 sensor don't care about backpressure.
Old 09-25-2012, 03:54 PM
RarlyL8's Avatar
It's wide band sensors that are thrown off by backpressure. Narrow band O2 sensors like the factory '86 on lambda O2 sensor don't care about backpressure.
Great point Jim, and the reason why the Lambda sensor is located before the muffler in the Carrera and the same spot in the 930. I believe Miguel has the same narrow band unit that I did in that spot. For such limited functionality it worked very well as a diagnostic tool.
Old 09-25-2012, 09:08 PM
PrimeMvr's Avatar
Back in my youth when we'd put a free-flow header and pipe on a sport bike we'd also re-jet the carbs because the decrease in back pressure made for better combustion chamber scavenging, causing a lean condition. Tuning was a riot. We didn't know crud about using a gas meter, so we changed jets based on the amount of pop when speed shifting. I'm shocked we never burned a piston!
I have my wideband just after my muffler about 18" from the tip, and it reads very consistent. Some say free air can come back up the tip and give a false lean reading, but I find that hard to believe. There is a ton of mass flowing out the pipes even at idle.
87 930 - Black - 3.4L/964 cams/K29/Powerhaus IC/6AL-2/B&B dual exhaust/MTX-L/235-315 Toyo R888/18" Kinesis wheels/Big Red brakes/LSD
10 997.2 Cab - Speed Yellow
83 SC Cab - Guards Red [SOLD]
17 NSX - Nouvelle Blue
Old 09-25-2012, 10:17 PM
Brian is right, I had a narrow band installed upstream of the turbo; then, Brian insisted on a new muffler - great guy! and I swapped the muffler with one with a different bung location downstream of the turbo - no change in AFR. After that, I got a wide band gauge and did the same back and forth with no change. BTW, with the wide band gauge, there is no need for the dyno to be able to play with the car... the way to go!
Old 09-26-2012, 05:47 AM
Don't know if this will be a help to you of not but this is how Brian
and I fabribated the Zork for the Old Sled. Note we added a heat sink
on the bung.
Cole
Cole - 80 930 "The Old Sled"
Mods: TurboKraft Custom IC, 934 Headers, GSX 61, Zork, Port Work, SC Cams, Air Mod Fuel Dist Relocated, Water Meth Injection, BL WUR, MSD 6530, Greddy EBC, Synapse Bov, Short 2nd & 3rd with 8:37 R&P, Wevo Shifter, Coupling, and Mounts, MTX-L SSI-4, Big Brakes, Rebel Coilovers, Bilstein Sports.
Old 09-26-2012, 06:25 AM
