Intercooler concern
Ok, when I get out and feel the intercooler after driving its hot.....
If you look at the picture, I have air going to the engine bay from the two scoops, and thru the tail directly, and thru the intercooler....
Now, if I wanted maximum intake cooling I would seal off the two scoops and block half the tail grill so all the air pulled in by the fan would go thru the intercooler.
Am I wrong on this or do you think the cooling is as good as it will get.
Any ideas on how to maximize cooling for the intercooler?
Signature Phrase " CATCH ME IF YOU CAN"
1988 Porsche 930 "Squerly" Built by "Porsche Doc"
1974 Porsche 911 (2003 - 2012)
2000 Boxster S (2006 - 2008)
Old 10-11-2012, 07:24 PM
Yes you are right IMO. Ducting as much air as you can through the core will enhance the ability to lower intake temperatures. I believe the 993twin turbo did this by sealing the intercooler edges to the deck lid.
Old 10-11-2012, 07:31 PM
GJF GJF is online now
Slantnose from HELL
GJF's Avatar
Blocking the intake ducts and damning the IC core to the louvers is the only way to make the air come through it. If you have EFI or are able to monitor your IAT's, and are no more than 110F on full boost I wouldn't worry about it. I shoot for 100F Max at full boost. When I have it I'm happy. If your temps are higher, then components need to be changed to control your IAT's.
It changes from time to time.....
Old 10-11-2012, 07:37 PM
Crotchety Old Bastard
RarlyL8's Avatar
I had a GT2 wing similar to yours. All the air went around the intercooler. NONE went through it. By building a shroud and partially blocking flow through the huge grill the air was forced/sucked through the intercooler. Made a HUGE difference. I left the twin air ducts open and removed the grill panel in the heat of summer but kept the shrouding. That was a worthy compromise that allowed the engine to keep cool.
Old 10-11-2012, 07:56 PM
Banned
How much time passed between you stopping the engine and putting your hand on the intercooler? I ask, because they heat soak rapidly once the engine is shut off . . .
That being said, I too belive intercooler shrouding is a good idea, and built one for my Garretson several years ago.
Old 10-12-2012, 05:12 AM
Wer bremst verliert
JohnJL's Avatar
You'd have to find a different radiator fan or change your intercooler but this works for me, I get within 3 degrees of ambient on 12psi and no heatsoak.
Scirocco twin radiator fan is switched by the ECU to relay on when certain variables are met, like temps and RPMs.
2007 911 Turbo - Not a toy
1985 911 Cab - Wife's toy
1982 911 3.2 Indiash Rot Track Supercharged track toy
1978 911 3.0 Lichtbau toy "Gretchen"
1971 911 Targa S backroad toy
Old 10-12-2012, 06:35 AM
wjfk32's Avatar
My old type intercooler(stock930) with no shroud was cool to touch after driving on the hwy..
With my andial/garretson intercooler is warm to the touch compared to the stock one..And I built a shroud etc..etc..
The fin design on the stock 930-intercooler is spaced more open and did cover(sit) the fan more compared to the tight fin design of the andial, twice as thick; doesn't sit directly over the fan like the stock one does.... (draw more air in)
My temps are still low..
Walt
Old 10-12-2012, 08:04 AM
Right after
Right after I shut the car off, it's rather warm....just below hot. I will blank off the open side and port the scoops to something useful.
Boy, I'm getting an education on turbo cars...
Old 10-13-2012, 07:37 AM
TT Gasman's Avatar
My B&B is always cool to the touch after a drive.
Doug
Houston, Texas
997 TT 550RUF
'86 930
Old 10-13-2012, 10:40 AM
oilonly's Avatar
Kokeln intercooler, no shrouding yet.
After spirited driving on 65 degree day intercooler is warm.
'87, Modified WUR, Billet valve, 965 downpipe, Kokeln intercooler, GHL headers, Garrett T04B K27 hybrid, Tial w/.8 bar, WEGO IV, RarlyL8 dual out, LSD
Old 10-14-2012, 09:14 AM
Show your intercooler
Lets see those intercoolers!
I need to get some ideas. Porting of the air from the scoops might prove to be more difficult than I thought.
Old 10-14-2012, 03:25 PM
Ken911's Avatar
The air from the scoops should go to the air box as a cold air intake. That is their intended function
88 turbo Guards red Targa slant nose, and yes I am a horsepower junkie, 3.4liter,7.5 to 1 JE pistons, Adjustable WUR, Imagine fuel head, 1 bar waste gate headers,allthe cis toys. Now apart to become the next EFI monster. fabbing my own intake, headers Individual throttle bodies, MS-3, pauter rods, Xtreme twin plugged heads, gt-2 evo cams cop's.
2019 Silverado 6.2L
Old 10-16-2012, 06:52 AM
Banned
930 Non OEM intercooler picture thread
Old 10-16-2012, 08:50 AM
Totally correct!
Old 10-16-2012, 10:02 AM
