Finding the Darn Idle Speed Screw
This is a really dumb request, but I've looked at least 5 times, and still can't see it!
I'd like to adjust my idle speed down a bit, but cannot find the screw in the mess of hoses, pipes and parts on my engine. I even have a couple of pictures of the darn thing. Any ideas that might help me find it?
1986 930, Garnet Red Metallic Previous P's: 65 911, 66 911S 63 904 (086), 63 904 (038) 70 914-6 |
Banned
The pic in post #9 of this thread shows right where it is - http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/547032-sticky-common-answers-why-my-car-doesnt-start.html
Finally found the screw! It was actually under the intercooler, out of sight. I could just see it from one specific viewing position on the left, with my cheek resting on the fender.
Not convenient, for sure. Removing the large vent hose allowed better access.
Cheek on the fender?, watch out someone might get the wrong idea. My wife often accuses me of more affection to the 930 than to her.
Anthony @ Voitureltd Bayside WI. |
+1 on that one!
Mark ![]() 1986 930 Ultra-Smith/RUF Slant Nose conversion, 3.4 BTR Spec, K-27HFS, RUF IC, TIAL .9 BAR Waste Gate, 930 4 speed transmission, RUF Front Oil Cooler, RarlyL8 Headers, RUF 4 Pipe Exhaust |
After the big hunt, catching the idle screw was anti-climactic!
I turned the screw up to 90 degrees from the initial point with no change in idle speed. Still idling about 1080 rpm when warm. How sensitive should this screw adjustment be? On the cheek to fender issue, I have always been in love with my favorite cars. My wife does not feel the least threatened!
1986 930, Garnet Red Metallic Previous P's: 65 911, 66 911S 63 904 (086), 63 904 (038) 70 914-6 Last edited by Telerding; 12-29-2012 at 05:02 PM.. |
Anthony @ Voitureltd Bayside WI. Last edited by voitureltd; 12-29-2012 at 05:40 PM.. |
Banned
The first time I had the motor out, I "hooked on" an extension to the idle adjusting screw. Got tired of contorting my arm and blindly fishing around back there with a mondo-huge long screwdriver, searching for the screw. Now I just grab the extension to the left of the IC when needed.
Once set, a 90 degree turn should give you some results...as in maybe a couple hundred rpm change. If not, you've got some air getting in there somewhere, keeping your idle high.
Mark H. 1987 930, GP White, Wevo shifter, Borla exhaust, B&B intercooler, stock 3LDZ. |
