xbmwguy's Avatar
i agree with tim. That being said ive heard the newer versions of ms will have innovates wide band built in. my mtx is spot on what tuner studio is seeing
Old 01-13-2013, 05:39 PM
Happiest when Tinkering
gsmith660's Avatar
I would want to think the gauge from innovate is accurate with the controller but like I said I have a old gas analyzer and I am going to see what it reads and which ever it is closest to wins because I think both the LS-1 and tunerstudio allow adjusting the output
Originally Posted by TimT View Post
I wonder if the math functions that Tunerstudio expects and the LM1 output are different?
I am mentioning this because I had a similar problem getting the AFR display on my Aim Pista to read the same as the display from my TechEdge WB controller display.
To get the displays to agree I had to tweak the math function on the Aim display so that it matches the displayed output from my WB controller.
You need to use one as a baseline... which do you feel comfortable believing?
" Porsche there is no substitute" I always liked that saying. Air cooled is the only way to go!
76 911 C.R.A.P. Gruppe #2 BIG time TURBO C.R.A.P. Bitz EFI/EDIS Now MegaSquirt 3
76 Blazer also restored by me
Old 01-13-2013, 06:16 PM
Ken911's Avatar
No...
If the instrument is calibrated in free air, does the output span completely from 0-5 volts? I checked the free air voltage etc, and had to adjust the math to get the numbers to match..
The output of the WB sensor is a corrected a weird curve.... each Mfg of WB units writes there own functions,
Perhaps what the MS expects is not what is output from the WB controller is contributing..
oh ok
so the algorithms are different with different sensors. so what sensor is the MS-III set up for?
88 turbo Guards red Targa slant nose, and yes I am a horsepower junkie, 3.4liter,7.5 to 1 JE pistons, Adjustable WUR, Imagine fuel head, 1 bar waste gate headers,allthe cis toys. Now apart to become the next EFI monster. fabbing my own intake, headers Individual throttle bodies, MS-3, pauter rods, Xtreme twin plugged heads, gt-2 evo cams cop's.
2019 Silverado 6.2L
Old 01-13-2013, 07:44 PM
Ken911's Avatar
has any one here got the knock sensor card and tried it out yet?
2019 Silverado 6.2L
Old 01-13-2013, 07:46 PM
Navin Johnson
TimT's Avatar
I just took a look at the LM1 docs.... I'm guessing you are using an analog out as an input to the ECU
It appears that the LM1 outputs allow all adjustments necessary '
If all these corrections are made are the values still different?
'69 911 GT-5
'75 914 GT-3
and others
Old 01-14-2013, 06:50 PM
gsmith660's Avatar
Well I finally figured it out! Got rid of innovate and installed AEM and set that in tunerstudio and imagine that they both read the same
Old 03-05-2025, 02:58 PM
