Strange Intermittent Tapping Noise
1989 930, 34k miles, stock.
There is a tapping noise at idle similar to loose rocker arm type tapping in a pushrod motor. It is not present at cold start or fully warmed up, just from about 5 minutes to 20 minutes of running. Seems to be coming from the top center of the engine but very hard to tell. Engine has had recent service with new plugs, valve adjustment etc. Leak down #'s are very good at 1-2% each cylinder. Noise was present before the service. My shop has not been able to determine cause. Engine runs great otherwise so am reluctant to tear into it looking for cause without at least a theory.
Welcome ideas on the possible cause. Thanks.
Old 01-28-2013, 07:44 AM
M5guy's Avatar
Noisy injector?
SR
86 930
x: 62 356, 64 356, 76 930, 84 911 Targa, 85 ROW 911, 00 996, 07 Cayman S, 00 M5, 02 G500, 66 Shelby GT350 (x2), 64 Corvette.
Old 01-28-2013, 08:10 AM
torresmd's Avatar
Did this noise start after the valve adjustment? If so I would have them check them again. Beautiful car and I love the wheels.
1998 993 C2S Guards Red/Black
1990 964 C2 RWB project car
2016 GT3RS White Daily driver
2018 Lamborghini Performante Gegio Telesto
Old 01-28-2013, 08:22 AM
Noise was present before valve adjustment.
Not sure what a noisy injector sounds like but the character of this noise seems to be a heavier metal on metal rotational sort of sound.
Old 01-28-2013, 08:27 AM
Might want to remove your air pump belt and see if the issue still persists, assuming as you stated that the car is still stock.
Ken
1986 930 2016 R1200RS
Old 01-28-2013, 08:42 AM
probably terminal, will cost $$$ to fix. Cut your losses and sell me the car. JK
Old 01-28-2013, 08:45 AM
Groovie Ghoulie's Avatar
are you running the proper weight oil? silly question I know, but light oils make mine have louder tapping sounds. (Was in a pinch and had to put whatever synthetic oil i could find in it to get it a few more miles for the good stuff).
Old 01-28-2013, 08:50 AM
The K-jetronic or CIS injectors that come origonal on your car don't make any clicking noise at all. They spray fuel continuosly and silently like a garden hose set to cone spray pattern and sometimes one might make a little squeak like sound.
Some old Bosch EFI injectors make a light ticking as they open and close. It's most noticable at idle speed if a quiet muffler is still on the car.
Newer EFI injectors seem pretty silent to me.
If you post a recording or video with sound maybe someone can make some educated guesses.
If your mechanic has any experience on these cars and he can't figure it out then the rest of us can only guess.
Old 01-28-2013, 11:05 AM
Forced Induction Junkie
WERK I's Avatar
How old is your fan belt? After thousands of heat cycles and millions of revolutions, the belts get hard and begin to crack. That's one area.
Exhaust leak. Linking Header/manifold gaskets will seal until things heat up and then begin "ticking". Look for carbon tracks on any of the sealing areas and joints.
Exhaust ticks sound very similar to an out of adjustment rocker arm.
Dave
'85 930 Factory Special Wishes Flachbau
Werk I Zuffenhausen 3.3l/330BHP Engine with Sonderwunsch Cams, FabSpeed Headers, Kokeln IC, Twin Plugged Electromotive Crankfire, Tial Wastegate(0.8 Bar), K27 Hybrid Turbo, Ruf Twin-tip Muffler, Fikse FM-5's 8&10x17, 8:41 R&P
Old 01-28-2013, 12:15 PM
WERK I is on to something!
Good one on the exhaust leak!
When I first got my car it had a tick tick tick noticable at idle for about 10 minutes after a cold start and then it would go away.
It was louder when sticking your head down under ths car and I could feel a little puff puff puff exhaust leak next to one of the exhaust port to header flange points.
When I removed the B&B headers that were on the car when I got it I found that one of the exhaust port studs had pulled from the head so it was leaking there and when the motor got hot the expansion of the headers sort of sealed up the leak to the point you couldn't hear it anymore.
I timeserted the 8mmx1.25 exhaust port stud threads in the head and that fixed it.
It's best to just timesert all the exhaust port stud threads as they are hardened steel so it never happens again.
I'll bet thats it!
Old 01-28-2013, 01:14 PM
Tinkering Pays!!
mooney265's Avatar
Originally Posted by M5guy View Post
Noisy injector?
I don't think our injectors make any noise... they're not electronic, but simply a nozzle for a hose... oops, just saw Post #8, sorry for duplicate response...
I would guess exhaust leak...
LIVN80S - - Red '79 Porsche 930 Steel Slant Nose Conversion [in 1987] w. 46k miles 3.3L; 964 Cams; K27HF @ 1.0 BAR, with Garrettson Intercooler; Rarly Zork; CIS Flowtech Fuel Head & BL-WUR.
Old 01-28-2013, 01:43 PM
Boost Abuser
LOWFAT's Avatar
Possibly the alternator,mine does the same thing at times. Diagnosed by removing the belt and running for a very short time.It seems to come and go but makes more noise with the lights on under more load.I replaced it with a new one and the new one does the same thing, weird.
"I can't drive 55"
Old 01-28-2013, 02:07 PM
Air Medal or two
afterburn 549's Avatar
Will it go away with clutch pedal dwn ? ??? try that
D troop 3/5 Air Cav,( Bastard CAV) and 162 Assult Helicopter Co- (Vultures) South of Saigon, U Minh Forest, Delta, and all parts in between
Old 01-28-2013, 03:55 PM
Thanks for all the responses, except for the one from kojo911 of course. I will try to make audio recording of the sound. The weird thing is how it is absent at full cold and full hot. Exhaust leak could maybe fit that characteristic, not so sure the others (alternator, air pump belts, oil viscosity). Well see.
Old 01-28-2013, 07:46 PM
