Smart quod bastardus
fredmeister's Avatar
Originally Posted by TurboKraft View Post
Ideally, a 1:1 drive ratio. For a 930 4-sp, 3rd is closer to 1:1 than 4th is.
Why is it so important for a 1 to 1 drive ratio?
I know running a higher gear gives you more time to get load and high boost on the engine, but do not understand the importance of 1 to 1 ratio in the tranny.
Fred
1979 930 Turbo....3.4L, 7.5to1 comp, SC cams, full bay intercooler, Rarlyl8 headers, Garret GTX turbo, 36mm ported intakes, Innovate Auxbox/LM-1, custom Manually Adjustable wastegate housing (0.8-1.1bar),--running 0.95 bar max
---"When you're racing it's life! Anything else either before or after, is just waiting"
Old 06-13-2013, 02:21 PM
Because gear ratio can increase or decrease output torque by a factor of the gear ratio, not accounting for friction losses.
From Wikipedia:
A gear train can be analyzed using the principle of virtual work to show that its torque ratio, which is the ratio of its output torque to its input torque, is equal to the gear ratio, or speed ratio, of the gear train.
This means that the input torque TA applied to the input gear GA and the output torque TB" on the output gear GB are related by the ratio
where R is the gear ratio of the gear train.
1986 911 Turbo
3.3L, K27HFS, Tial 46mm, TurboKraft Intercooler, 964 Cams, Monty Muffler, MS3Pro Evo, M&W Ignition, Zietronix WBO2 Data Logger, Wevo shifter, coupler and motor mounts.
Old 06-14-2013, 12:25 PM
From Wikipedia:
Got it now i feel stupid for overlooking this. I was thinking wheel horsepower and mistakenly thought gear ratio has no effect but you are right sir. So I guess the dyno does a conversion based upon the gear ratio you enter and then converts to RWHP. The of course you can back calculate HP at the crank using a good suitable tranny loss number which most people accept 12-15% for the 911.
Fred
Old 06-15-2013, 05:41 PM
