Preferred pronoun:Maestro
Norm K's Avatar
I've been out for little while, too. Golden, CO., being the hokey little town I love, had a small Christmas parade today and I drove my `49 Plymouth in it.
Anyway, to the MSD; yes, each computer recognizes the device, and to which port its connected. Trying the different USB ports hasn't seemed to help, whether the MSD is set to the matching port or not.
When in doubt, use overwhelming force.
Old 11-30-2013, 10:51 AM
DCR Rides
mdripley's Avatar
If you have a multimeter you might check the cable that was provided by MSD to ensure that it is good, I have had bad serial cables right out of the box.
wishing you quick resolution to this problem as I will soon be going your route with MSD on my 87 930 but not until I finish chasing down all of my electrical gremlins and replacing my fuse blocks with ATO style Blocks
Regards
Mike
87 930 turbo coupe 3.3L , 4Spd 930 Trans w/LSD , mostly stock for now
Old 11-30-2013, 12:09 PM
Norm K's Avatar
I finally gave up and sent the unit to MSD, figuring they'd send it back with a note telling me the problem was either me, my computer or my serial-usb adapter. To my surprise, their communication test failed (everything else was fine) so they repaired it and sent it back. When I connected it to the computer and started the software it worked exactly as it should. I love the smell of vindication in the morning ...
On the matter of dizzy locking, I found an incredibly simple way to accomplish this. No drilling, no tapping, no extra screws. For the weights, I did as others here have and simply wired them up. It was the advance plate where I strayed from what others have done and took my own approach. Took two screws the same thread diameter and pitch as those that attach the distributor cap clips to the dizzy body, but just a shade longer. Shortened them until they were maybe 2mm longer than the originals, then carefully (so as to not bugger the threads) filed them to a slight point. Installed them a couple of turns (replacing the stock ones), moved the plate to full advance and tightened them down all the way. My theory was that, being slightly longer, they'd bottom out against the advance plate, the pointed end would dig in just a bit and I'd effectively have two set screws, 180* apart holding it at full advance. Success! Got the plate locked at full advance in little more time than it took me to type this.
Old 01-21-2014, 06:12 PM
Nice. I'm going to use this method when I do the MSD swap. So are you staying with the CIS for now ?
81 Pacific Blue 930 Euro coupe slicktop on a strict diet, Rarlyl8 headers, Blowzilla turbo, Tial waste gate, Full bay I/C, Home made center out exhaust, Leask WUR, MSD 6AL, PLX wideband
Wevo shifter, LSD. Next up, Cams, Heads and port work
Old 01-21-2014, 10:08 PM
Norm K's Avatar
Nope. I'm going to drop the engine next weekend for a top-end rebuild and the efi conversion. Weather here's been unseasonably nice so I've been delaying the project because I so enjoy driving this car and hate the idea of not being able to for the several months it'll take me to finish.
Old 01-22-2014, 05:54 AM
Smart quod bastardus
fredmeister's Avatar
[QUOTE=nkowi;7868501]I finally gave up and sent the unit to MSD, figuring they'd send it back with a note telling me the problem was either me, my computer or my serial-usb adapter. To my surprise, their communication test failed (everything else was fine) so they repaired it and sent it back. When I connected it to the computer and started the software it worked exactly as it should. I love the smell of vindication in the morning ...[QUOTE]
Can I ask you if they reimbursed you to ship it back and forth to them or was that on you and how long did they take to turn it around for you.
Reason I ask is that I have had problems getting any intelligent responses out of their help line, in fact I think they suck, and wanted to know how they rated with their return/repair ticket system they seem to push on buyers when there is a problem.
Sounds like you got lucky and found your problem without more headache. Cool!
thanks,
Fred
1979 930 Turbo....3.4L, 7.5to1 comp, SC cams, full bay intercooler, Rarlyl8 headers, Garret GTX turbo, 36mm ported intakes, Innovate Auxbox/LM-1, custom Manually Adjustable wastegate housing (0.8-1.1bar),--running 0.95 bar max
---"When you're racing it's life! Anything else either before or after, is just waiting"
Old 01-23-2014, 12:15 PM
thanks,
Fred
Old 01-23-2014, 12:18 PM
Norm K's Avatar
Shipped to them on my dime, back to me on theirs.
Total time, from when I dropped it at the post office until I received it back was less than two weeks.
Old 01-23-2014, 12:20 PM
