Testing Spark Plug Connectors
I posted this in the 911 Engine Rebuilding section and got no response. Thought I would give it a try here. Is there a relatively easy way to check spark plug connectors to determine if they are good. Thanks,
Tom
1972 911T (with 3.2), 1985 930-EFI Conversion (in progress), 2016 Cayman GT4
Old 12-06-2013, 08:20 PM
There is usually an ohmage number on the side of the connector.
Bruce
Old 12-07-2013, 05:32 AM
If I recall correctly it's 4000 ohms. Check them with an ohmeter.
Old 12-07-2013, 08:06 AM
I've gone native
Tt surgeon's Avatar
One cheap trick is to pull the connector off the plug and stick an extra plug into the connector, spin the starter after shutting off fuel pumps and see if you get spark at the plug gap, repeat x5. That will grossly tell you if the wire and plug are functional to a certain degree.
'07 997.1tt
Blk/blk 600hp, bad to the bone
Old 12-07-2013, 08:52 AM
Here is a link to a thread I posted about testing and rebuilding plug end connectors - Rebuilding Beru plug connectors
Brooke
1969 911 ST 2.8SS EFI ITB (Irish Green), 1974 911 3.6 ITB (Black)
1952 MG TD with F20C
Old 12-07-2013, 09:21 AM
Thanks rswannabe. That is what I was looking for.
Tom
Old 12-07-2013, 08:47 PM
