What Material for Camshaft Extension
What material should I use when I produce a extender for my left 964 Cam.
(for use Scavenge pump Turbo with air pump drive housing) picture posted from User WERK I ![]() Oil pump drive required on SC camshaft Thank you for your help
87 930 3.4, BW EFR 7670, TK Long Neck IC, Fabspeed Headers, 964 NW`s, Ported Heads, Tial F46 (0.4Bar Spring), Turbosmart EBC, BL WUR with rpm switch /solenoid, SDS CPI Ignition, modified Muffler, and many other little mods |
Ingenieur
It is just mild steel, 1018 is fine for that. You will need to use the drive pins from the 930 cams, and make some provision to get the center of the extension aligned with the center of the cam.
Thanks Speedy
Thread Tools | |
Rate This Thread | |
