-   -   My New 1979 930 - yes, another introduction... (http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/820110-my-new-1979-930-yes-another-introduction.html)
turbo owner 10-11-2017 10:15 PM
Originally Posted by kenikh (Post 9773146)
I'm tempted to do a few rips sans air filter.
Sent from my Nexus 6P using Tapatalk
Maybe something like this
12" x 2" Aluminum Washable Chrome Top Lid Air Cleaner Oval Red Filter Lid | eBay
turbo owner 10-11-2017 10:19 PM
Give it a try, back in the old days race cars ran open velocity stacks all the time.
kenikh 10-11-2017 10:20 PM
Cut a hole in the parcel tray and feed the motor fresh, dust free interior air. [emoji23]
turbo owner 10-11-2017 10:25 PM
Remove a speaker and use that hole
smurfbus 10-12-2017 02:52 AM
What speaker and hole? No holes in my 79 but I have thought about making one big air filter over there.
1979-930 10-12-2017 06:57 AM
^^^ Ditto. No speaker holes here either. If you have them someone cut them in.
turbo owner 10-12-2017 07:04 AM
To be honest, I don't listen to the radio in either of my turbos. The 79 is at a shop 200 miles away and I'm in the hospital right now so I can't look. I was guessing cause that is where I'm use to seeing them in American cars.
16Volt 10-12-2017 07:19 AM
Since I am good friend and my car wont be done for awhile still you can borrow the air filter setup off my motor to see if it makes a difference.
And I have one of those big air raid plenums and filters sitting in my garage you could also try, the plenum pieced needs a little work but its functional.
kenikh 10-12-2017 07:34 AM
Thanks!
On this topic, I am curious what the max power anyone has pulled through a stock airbox. I am sure it is limited on an unmodified box (that hole is tiny). Modified with a larger hole (or holes), might be adequate.
flightlead404 10-12-2017 09:28 AM
Originally Posted by kenikh (Post 9773477)
Thanks!
Don't know about your harbor freight or whatever filter, but I doubt there's any restriction on any reasonable airfilter or stock airbox. There's plenty of documentation that aftermarket filters don't flow much more if anything better than stock. Otherwise why wouldn't they simply make "stock" better.
If there's any restriction in the CIS system is probably in the airflow metering setup or the intake plenum itself.
kenikh 10-12-2017 09:43 AM
I'm not sure it is reasonable. It is a pretty tiny paper element. The surface area is somewhat comical. Will see if running open has an effect.
turbo owner 10-12-2017 09:52 AM
I think you will see a difference
kenikh 10-12-2017 10:37 AM
Doesn’t hurt to test it
flightlead404 10-13-2017 10:04 AM
Ah, well, reasonableness makes the difference :D See the other alternate thread on this topic.
kenikh 10-23-2017 04:14 PM
Old filter was definitely choking it off. Finally seeing AFR above 10 approaching 7000 RPM. It's still pig rich from 4500 to 6000, but 11.5:1 @ 7K redline is much better! A little more tuning and it should be perfect. I think this turbo is right at the limit in terms of what unmodified CIS can handle with a Leask WUR.
This KN filter is cheap and fits GREAT!!!https://uploads.tapatalk-cdn.com/201...efc24f59c4.jpg
Alan L 10-23-2017 04:46 PM
That KN looks similar to the one I run. It should be washable?
What WUR WP are you running now? You could probably lean it out a bit (harden the pressure) to help deal with the 4500-6000. Presumably your Leask switch is set at 4500. At what AFR (12.5?).
You won't be running at 7k that often, but I run mine to 12.5 AFR on the track at 1 bar with no issues - so you can tweek the AFR a bit leaner yet.
Regards
Alan
