LinkBack Thread Tools Rating: Thread Rating: 2 votes, 5.00 average.
Originally Posted by kenikh View Post
I'm tempted to do a few rips sans air filter.
Sent from my Nexus 6P using Tapatalk
Maybe something like this
12" x 2" Aluminum Washable Chrome Top Lid Air Cleaner Oval Red Filter Lid | eBay
Old 10-11-2017, 10:15 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #381 (permalink)
Give it a try, back in the old days race cars ran open velocity stacks all the time.
Old 10-11-2017, 10:19 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #382 (permalink)
3 restos WIP = psycho
kenikh's Avatar
Cut a hole in the parcel tray and feed the motor fresh, dust free interior air.
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 10-11-2017, 10:20 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #383 (permalink)
Remove a speaker and use that hole
Old 10-11-2017, 10:25 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #384 (permalink)
Turbofrog
smurfbus's Avatar
What speaker and hole? No holes in my 79 but I have thought about making one big air filter over there.
10/78 930: HX40Super, MS3pro+IDX1050+044+E85, ITB, 12 Denso COPs, TrueSplit-BB/2*38WGs, Weight<1100kg
Old 10-12-2017, 02:52 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #385 (permalink)
^^^ Ditto. No speaker holes here either. If you have them someone cut them in.
Derrick
Old 10-12-2017, 06:57 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #386 (permalink)
To be honest, I don't listen to the radio in either of my turbos. The 79 is at a shop 200 miles away and I'm in the hospital right now so I can't look. I was guessing cause that is where I'm use to seeing them in American cars.
Old 10-12-2017, 07:04 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #387 (permalink)
16Volt's Avatar
Since I am good friend and my car wont be done for awhile still you can borrow the air filter setup off my motor to see if it makes a difference.
And I have one of those big air raid plenums and filters sitting in my garage you could also try, the plenum pieced needs a little work but its functional.
- 86 Porsche 930 - Mr.Hyde
- 86 BMW 635CSi - Dr.Jeykell
- 2006 Infiniti M45 Sport
https://medium.com/@crashingdoor
Old 10-12-2017, 07:19 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #388 (permalink)
kenikh's Avatar
Thanks!
On this topic, I am curious what the max power anyone has pulled through a stock airbox. I am sure it is limited on an unmodified box (that hole is tiny). Modified with a larger hole (or holes), might be adequate.
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 10-12-2017, 07:34 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #389 (permalink)
Thanks!
Don't know about your harbor freight or whatever filter, but I doubt there's any restriction on any reasonable airfilter or stock airbox. There's plenty of documentation that aftermarket filters don't flow much more if anything better than stock. Otherwise why wouldn't they simply make "stock" better.
If there's any restriction in the CIS system is probably in the airflow metering setup or the intake plenum itself.
Old 10-12-2017, 09:28 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #390 (permalink)
kenikh's Avatar
I'm not sure it is reasonable. It is a pretty tiny paper element. The surface area is somewhat comical. Will see if running open has an effect.
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 10-12-2017, 09:43 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #391 (permalink)
I think you will see a difference
Old 10-12-2017, 09:52 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #392 (permalink)
kenikh's Avatar
Doesn’t hurt to test it
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 10-12-2017, 10:37 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #393 (permalink)
Ah, well, reasonableness makes the difference See the other alternate thread on this topic.
Old 10-13-2017, 10:04 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #394 (permalink)
kenikh's Avatar
Old filter was definitely choking it off. Finally seeing AFR above 10 approaching 7000 RPM. It's still pig rich from 4500 to 6000, but 11.5:1 @ 7K redline is much better! A little more tuning and it should be perfect. I think this turbo is right at the limit in terms of what unmodified CIS can handle with a Leask WUR.
This KN filter is cheap and fits GREAT!!!
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 10-23-2017, 04:14 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #395 (permalink)
Alan L's Avatar
That KN looks similar to the one I run. It should be washable?
What WUR WP are you running now? You could probably lean it out a bit (harden the pressure) to help deal with the 4500-6000. Presumably your Leask switch is set at 4500. At what AFR (12.5?).
You won't be running at 7k that often, but I run mine to 12.5 AFR on the track at 1 bar with no issues - so you can tweek the AFR a bit leaner yet.
Regards
Alan
83 SC, 82 930 (track) - Stock except for RarlyL8 race headers, RarlyL8 Zork, K27-7006, 22/28 T bars, 007 Fuel head, short 3&4 gears, NGK AFR, Greddy EBC (on the slippery slope), Wevo engine mounts, ERP rear camber adjust and mono balls, Tarret front monoball camber adjust, Elgin cams, 38mm ported heads, 964 IC. 380rwhp @ 0.8bar Apart from above, bone stock:-)
Old 10-23-2017, 04:46 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #396 (permalink)
