setting timing
Hi
I have a 1988 turbo and I'm having trouble setting the timing. I have two lines going to my distributor advance/retard diaphragm. Which one is the vacuum line?
At idle the inner most line if removed has vacuum. Which one should be remove when setting timing at 4000 rpm?
Scott
Old 08-24-2014, 08:23 AM
oilonly's Avatar
Diagram of vac line connections with emission system removed.
'78 SC Turbo Conversion Begins
Sorry don't know which should be removed when setting timing.
'87, Modified WUR, Billet valve, 965 downpipe, Kokeln intercooler, GHL headers, Garrett T04B K27 hybrid, Tial w/.8 bar, WEGO IV, RarlyL8 dual out, LSD
Old 08-24-2014, 08:44 AM
Originally Posted by turbo930ss View Post
Hi
Scott
The outer one is vacuum advance when the throttle butterfly is opened and you're accelerating and the inner one is vacuum retard at idle and up to around 1500 rpms. That's why you feel vacuum on that one at idle and during closed throttle engine deceleration if you blip the throttle.
You remove both of them when setting maximum centrifical advance at 4000 rpms.
Old 08-24-2014, 09:11 AM
Thanks for the help.
Old 08-24-2014, 03:28 PM
