-   -   How low is too low? (http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/828139-how-low-too-low.html)
911nut 09-26-2014 03:14 PM
So none of you lowriders have bottomed out and crunched the crossover for your headers?
speednme1 09-26-2014 03:30 PM
Nope...
pkabush 09-26-2014 03:51 PM
Very good call on the wheels. Now you just need to ditch the mirrors and tail :D
EnjoySmileWavy
Les Paul 09-26-2014 06:57 PM
It has a big Garretson IC. I still get compliments on the tail. Care to guess what it is?
Les Paul 09-26-2014 08:55 PM
http://forums.pelicanparts.com/uploa...1411789776.jpg
http://forums.pelicanparts.com/uploa...1411789818.jpg
http://forums.pelicanparts.com/uploa...1411789949.jpg
http://forums.pelicanparts.com/uploa...1411790042.jpg
A few tails I could go for.
Ronnie's.930 09-26-2014 09:04 PM
^^^ WOW, those are some wood inducing rears right thar!
Ronnie's.930 09-26-2014 09:08 PM
Is it a 993 Turbo replica tail? Regardless, it looks really good on your car.
quattrorunner 09-26-2014 09:19 PM
It's a cool tail. Too much color for my car but was thinking If I ever did another tail it might be that one. But with a twist. I'd use a light coat of Bedliner from arosol can to make what looks like a rubber trim like the turbo and Carrera tails. I need more black and I did that to my all fiberglass tail. Looks real and feels good too. Honest it does. I tested it before doing it. I'm going to use it on my splitter up front too. I wonder how rubber might look on the turbo s spoiler?
Hey it's not silicone.
Ronnie's.930 09-26-2014 09:29 PM
Originally Posted by quattrorunner (Post 8280564)
and feels good too.
That's too much information, bub!
Robby can fix you up with some if you want to give it a try (will be blue, though)!!!
911nut 09-27-2014 04:50 AM
Originally Posted by speednme1 (Post 8280215)
Nope...
Rey, thanks for your detailed response :rolleyes: Anyone else had an issue?
Seems like the 930 might have a little less suspension travel than the 964T. My car is set to 964 RS height (which looks to be a tad higher than RS height of the torsion bar cars) yet I've nailed mine twice. I'm going to change it over the winter to get more clearance.
speednme1 09-27-2014 05:09 AM
Paul didn't know you wanted details:confused:..my car has coil overs (500lb spring) in the rear along with 935 spring plates and Rebel Racing bearings. Does not bottom out under load and rides pretty smooth considering how low it is.
911nut 09-27-2014 08:28 AM
Just kiddin' ya Rey. Thanks for the info.
Part of the problem is I use H&R reds that aren't as still as your springs. The pot-holed, broken up roads in Michigan won't allow the use of anything stiffer.
full quack 09-27-2014 06:04 PM
Mine rides great, I have not bottomed out the headers or pan or front cross member {tow hooks are another story...I use them as feelers, if you get my drift.}
I can get the left rear tire to just swish the inside of the fender, just inboard of the lip, if I hit an off camber dip while turning right above 70mph. This has occurred just twice in the 5 years I've been driving the car at it's present stance, with only dirt removed, no damage.
My car is at least an inch below euro spec.'s, maybe more, never really measured it, but the car sits very low.
Mark
Kevin911sc 09-30-2014 08:54 AM
http://forums.pelicanparts.com/uploa...1412087254.jpg
How the previous owner had the car set up....if you cant fully turn the wheel its too low, its now back to ~euro spec.
Les Paul 09-30-2014 11:43 AM
Any pics of it now?
jeos 09-30-2014 12:00 PM
http://forums.pelicanparts.com/uploa...1412103498.jpg
2TT930 09-30-2014 08:06 PM
Here is mine.
On ER Coils. (400/600)
Raised spindles.
Never rub scrape or touch ground ever.
http://cimg2.ibsrv.net/gimg/rennlist...e3b79b2fd9.jpg
quattrorunner 09-30-2014 08:20 PM
Wow. This is wicked if it never contacts the ground but how damped is it? How much travel? Is it still comfortabel I guess I'm asking. /\ /\
Les Paul 10-01-2014 09:30 AM
http://forums.pelicanparts.com/uploa...1412180887.jpg
http://forums.pelicanparts.com/uploa...1412180922.jpg
25 and 1/4"s front and back to the bottom of the fender lip.
kenikh 10-01-2014 09:38 AM
Originally Posted by 2tt930 (Post 8285892)
here is mine.
On er coils. (400/600)
raised spindles.
^^^ i want this
